+arcadeshopper Posted June 13, 2017 Share Posted June 13, 2017 Teeny can also be used on your Tandy for serial communication. chicken and an egg issue, he has a stock 102 and a cable for the pc Quote Link to comment Share on other sites More sharing options...
majestyx Posted June 13, 2017 Share Posted June 13, 2017 When I get a chance, I will try the info provided here: http://www.retrocomputing.net/parts/r/radio/TRS80_4/docs/trs80-10.htm Of course, being on Windows 7, Hyperterm isn't included so I'll need to grab a freeware one. Doesn't look terribly complicated so I'll try the directions and see how I fare. Quote Link to comment Share on other sites More sharing options...
majestyx Posted June 14, 2017 Share Posted June 14, 2017 I spent a few hours last night toying around with some things and was amazed that I was able to interface my Model 102 with my Windows 7 PC. Thanks to arcadeshopper for pointing the way with the cables, which are the exact ones I bought. I used Realterm to connect the two machines and was able to transfer text files between the two with that. I then needed to use DOXBOX to run the old TEENY.EXE program (thanks for the nudge SoD) and after playing around with the COM port configuration and getting that set correctly, was able to get TEENY.BA and TEENY.CO onto the 102. I figure I can use this as a stop gap until (if?) I can ever track down a TS-DOS ROM or until someone comes up with something similar to the REX or NADSBox. I'll likely mess around with this more tonight if nothing else is pressing on my time. 3 Quote Link to comment Share on other sites More sharing options...
