576XE Posted March 14, 2017 Share Posted March 14, 2017 Hello friends! I wrote a little demo of installing russian font into Atari.It's a little TSR which protects TSR program itself with bumping up LOMEM and charset with bumpimg down HIMEM.My problem is in unability to reinitialize access to charset after /RESET/./RESET/ sets CHBAS to $E0 and then I can not access my $BC (RUpage) clearly.I think that I must insert some additional re-initialisation part into TSR.But I can not realize what part.Program itself now saves only LOMEM and HIMEM.I can see saved font with monitor!I can see right value in MEMTOP and if I change CHBAS to my $BC I lost my screen.Please advice me.ez Quote Link to comment Share on other sites More sharing options...
vitoco Posted March 15, 2017 Share Posted March 15, 2017 It seems that reset is whipping out your charset from $BC when it reopens graphics mode 0. If RESET is not resetting MEMTOP, I remember a bug that clears more than required bytes at the open of graphics mode 0, which usually doesn't matter as normally there is ROM there, and this time it's your charset. Test this by moving MEMTOP a couple of pages down. I can recall a program that saved the last 1k or 2k ending at $BFFF into the RAM under OS ROM, and restored it every time reset key was pressed, just because reset always wiped out that portion of the program when the screen was reopened. Your TSR could do the same thing. I hope this helps. 2 Quote Link to comment Share on other sites More sharing options...
576XE Posted March 16, 2017 Author Share Posted March 16, 2017 Hi, there, Victor ¡muchas Gracias! The problem is solved now. Thank You! I droped the idea of protecting font with tsr at all. I decided to protect font from soft reset with APPMHI and it works! Just placed font 4 pages below display-list (formerly aligned to page bondary) and set APPMHI one byte higher then end of font. And the main problem of soft reset still stay intact... It resets all data to system values and I lose access to even intact font. This makes me to reinit all my settings and it's not my Zen. Anyway the problem solved. Best wishes from Moscow! ez Quote Link to comment Share on other sites More sharing options...
Rybags Posted March 16, 2017 Share Posted March 16, 2017 (edited) The problem with memory management is that Doses, language carts or executables can and probably will mess with your work. MEMLO is generally modified by Dos at the end of successful boot, it'll usually be bumped to allow for the DOS and buffers resident in low Ram. The consideration for modifying this with a program is that you need to cater for whatever memory Dos would want to use which can be tricky as every Dos is different and most can differ depending on how many drives and file buffers are enabled. MEMTOP is maintained by the OS, it will be set when a screen or editor is opened and should point to 1 byte before start of the Display List. RAMSIZ represents the page address of the first non-contiguos Ram address, established at cold and warmstart by the OS then copied to RAMTOP shortly after. Best not modified, use as a reference showing how much contiguous Ram is available starting from location $0000. RAMTOP represents the end +1 of screen memory. When reserving Ram above the screen for graphics or other, RAMSIZ should be used as the starting figure then RAMTOP altered immediately before re-opening the screen in order to relocate it. The reason to not use RAMTOP as initial reference is that it can cause storage creep (loss) in subsequent program runs if no warmstart occurs between runs. APPMHI represents the highest address used by the application. It's used to protect programs and variables/workspace from inadvertantly being wiped by a screen open operation. The 400/800 OS has a bug where if this is set too high the screen won't open and the machine can be rendered unusable after a warmstart. Edited March 16, 2017 by Rybags 1 Quote Link to comment Share on other sites More sharing options...
576XE Posted March 16, 2017 Author Share Posted March 16, 2017 Hi, there, Rybags! At first, thank you for reply. As you can imagine I tryed to make standalone tsr initialisation routine which has deal with memory management only. tsr part and font part are to be protected after initialisation. YES! At first, I protected too little memory and have seen Ramtop Dragon. Then after protecting 2k of memory I've seen this strange behavior of Soft RESET, when after each reset I'm needed to reinitialize font even if it was not corrupted by T-rex. I can understand that now when my font is protected from Atari???!!! by using APPMHI it's still unprotected from my own programming. But I'm not a programmer and never shell become. If you want to hear Russian (why not?) and seeing session try this: Good luck, friend!!! ez 1 Quote Link to comment Share on other sites More sharing options...
vitoco Posted March 16, 2017 Share Posted March 16, 2017 I'd like to see a picture of your Atari. Is the keyboard full of stickers? Quote Link to comment Share on other sites More sharing options...
576XE Posted March 17, 2017 Author Share Posted March 17, 2017 Absolutely right. The lettering on the screen means Hello Victor in Russian. 3 Quote Link to comment Share on other sites More sharing options...
576XE Posted March 17, 2017 Author Share Posted March 17, 2017 This picture shows another Atari dedicated bellevue. Atari itself has her own SONY PVM monitor, 576k memory module with Stereo COVOX connected to loudspeakers, IDEPlus 2.0 hard drive with SDX 4.48 onboard, XF551 floppy, Lotharek's SIO2SD, Steven's SIO2PC and her own dedicated host PC - Surface Pro 3 (from the right side) with docking station (video output goes to left big screen). Everynight dream of "My Honey" is external VBXE... May be The!Cart too... CU Quote Link to comment Share on other sites More sharing options...
576XE Posted April 15, 2017 Author Share Posted April 15, 2017 Hello, Rybags!After your kind explanation of Soft-RESET process in another post,I've successfully rewrite this routine in classic manner. There were tons of detailed font routines written in BASIC,but my personal problem was in the fact that BASIC itself carefully works on it's memory layout.Particularly this fact means that in assembly I needed to restore some data in TSR part.Once you've said that highest 1k is wiped by RESET anyway, I just protected this poor 1k and 1k for font in hi memory, then let GR0 reset screen data, and ...put new MEMTOP data cooked by system into runtime var, for moving var->MEMTOP every reset. This fact was permanently hidden by BASIC which treat his memory itself.Now program works in standard Atari manner. ; Sample program ; rudos.com .ou rudos.com ; ==================== ; Included LIBS .in syseq.mae .in macro.mae ; Program Constants select = $05 none = $07 red = $22 blu = $82 cslen = $0400 ; -------------------- ; > > > > Protected ZONE Start > > > > .or $1900 jmp start ; -------------------- ; Program Variables protlo .ds 2 prothi .ds 2 oldcon .ds 1 rupage .ds 1 enpage .ds 1 csadr .ds 2 ; ------------------- ; Set VBI as Immedate setvbi lda #$06 ldx #>vbi ldy #<vbi jsr SETVBV rts ; ------------------- ; Set Environment setenv lda COLOR4 cmp #blu bne setblu setred mib red COLOR4 mab rupage CHBAS jmp skip setblu mib blu COLOR4 mab enpage CHBAS skip rts ; ------------------- ; Set NoRESET dummy ; Fake addr tsr jsr dummy ; to be DOSINI maw protlo MEMLO ; bump up maw prothi MEMTOP ; bump dn jsr setvbi ; reinit VBI jsr setenv ; reinit env rts ; -------------------- ; Read CONSOL in VBI vbi lda CONSOL tax ; X=CONSOL ldy oldcon ; Y=oldcon ; tya ; A=oldcon cmp #none bne exit chkcon txa cmp #none beq exit txa cmp #select bne exit jsr setenv exit stx oldcon jmp SYSVBV ; < < < < Protected ZONE Finish < < < < finish = * ;This part may be deleted after running only once! ; ==================== ; Initialization start .or $2000 init miw finish protlo maw protlo MEMLO ; Protect Runtime ; lda RAMTOP ; reserve 8 pgs: 4-for font and 4 for safety sec sbc #$08 ; -------------------- ; 1. Declare new RAMTOP sta RAMTOP ; -------------------- ; 2. Call GR mode immediately ofs 6 bfa sname lda GRMODE jsr setgr ; -------------------- ; init prothi maw MEMTOP prothi ; -------------------- ; Init csadr lda RAMTOP sta csadr+1 ; MSB lda #$00 sta csadr ; -------------------- ; 4. Load font jsr gtfname jsr ldfile ; -------------------- ; 5. Declare it to ANTIC lda csadr+1 sta CHBAS ; -------------------- ; Init font pages mib $e0 enpage mab 1+csadr rupage ; MSB mib red COLOR4 ; mib none oldcon jsr setvbi ; ; Set TSR data maw DOSINI 1+tsr ; save DOSINI into tsr jump miw tsr DOSINI ; set DOSINI as tsr maw protlo MEMLO ; fill MEMLO as protlo ; rts ; Return to DOS ; ==================== ; Init DATA sname .by "S:",EOL prompt .by CLR,"ENTER D:FONTNAME.FNT TO LOAD...",EOL cr .by EOL buflen = 40 fname .ds buflen ; ==================== ; Useful Subroutines setgr pha ; Mode jsr close pla tay ; Y=Opt (AUX1) and #16+32 ; TXTWIN+NoClear eor #16 ; flip TXTWIN ora #OPUPD ; Open rw jmp open ; -------------------- gtfname ; PRINT prompt to screen ofs 0 bfa prompt bfl buflen jsr print ; Filename INPUT to buffer ofs 0 bfa fname bfl buflen jsr input rts ; -------------------- ldfile ; CLOSE 1 ofs 1 jsr close ; OPEN 1 OREAD 0 fname ofs 1 bfa fname lda #OREAD ; Mode ldy #$00 ; Option jsr open chk iferr ; BGET 1 <adr> <len> ofs 1 maw csadr BFADR,x bfl cslen jsr getby chk iferr ; CLOSE 1 iferr ofs 1 jsr close rts ; ==================== ; Included SUBS .in iolib.mae ; -------------------- ; Setup Run Address .or RUNAD .wo start ; -------------------- .en ; >>> End Of File <<< ; RUDOS.atrBest wishes from Moscow.Zhenya.(It's shortname from Eugene.) Quote Link to comment Share on other sites More sharing options...
