G7000 mod pics
grips03
G7000 RGB, power switch, standard power jack, and front mounted db9 ports (Atari).
This G7000 was setup to use external AC to DC power adapter, some models have internal AC power supply. I try to avoid the internal AC power supply models.
G7000 and Odyssey 2 have same wiring for RGB mod, so these pics can be used to help install RGB mod in O2.
The Odyssey 2 should have RGB port in the far right hand corner (when looking at the back of the console). For G7000 there is more room between the case and system board, so its more flexible on where you want to put the RGB port and power switch. Just make sure to install on the lower part of the case so voice module can be used.
  • 11 months later...
  • 2 years later...
