saboteur Posted March 20, 2017 Share Posted March 20, 2017 Right, i've started having a bash at RB+ and decided to prat about getting a lash of Mathew Smith's classic Manic Miner. I've managed to rip the original graphics from the ZX Spectrum version and have started to throw together a few experiments and will post my progress and questions in this thread. So my first question(s) : I have my Miner Willy and a guardian moving around and animated but how do I flip them when they change direction/ reach an edge of a patrol route? Do I have to have sperate left and right images or is there a flip command ? Is there a list of RB+ commands ?? Any help appreciated. Quote Link to comment Share on other sites More sharing options...
Sporadic Posted March 20, 2017 Share Posted March 20, 2017 (edited) Awesome. Can't wait to see your progress. Each object has a flip flag. So for example you can do rlist[objectnumber]. flip = R_is_flipped Or rlist[objectnumber]. flip = R_is_normal Where objectnumber is the number of the object from the object list that you want to flip. Also, this is a horizontal flip, there is no vertical. I think you can update almost all an objects properties this way. Hope that helps a bit. Typed on my phone so there could be errors. Also, in the RB+ folder there is a docs folder with a quick reference.txt and also a bcxbasic help file. Edited March 20, 2017 by Sporadic Quote Link to comment Share on other sites More sharing options...
saboteur Posted March 20, 2017 Author Share Posted March 20, 2017 Nice one Sporadic. Hope to have the first cavern layout done tonight - need to do a bit of thinking about storing layouts - but by doing 1 cavern I should come up with a plan. Also ss it possible to change the colour of a sprite - I noticed a blitter example but not sure if that will be relevant or overkill ( all of the keys on each level colour cycle ) cheers 1 Quote Link to comment Share on other sites More sharing options...
saboteur Posted March 20, 2017 Author Share Posted March 20, 2017 (edited) Nice one Sporadic. Hope to have the first cavern layout done tonight - need to do a bit of thinking about storing layouts - but by doing 1 cavern I should come up with a plan. Also ss it possible to change the colour of a sprite - I noticed a blitter example but not sure if that will be relevant or overkill ( all of the keys on each level colour cycle ) cheers Never mind - I just animated the keys by having 8 frames but changing the coliur each time Edited March 20, 2017 by saboteur 1 Quote Link to comment Share on other sites More sharing options...
ggn Posted March 20, 2017 Share Posted March 20, 2017 (edited) That's a good solution . I can also think a couple more, provided you use up to 8bpp mode for your sprite.: a) Have multiple palettes and use the sprite_CLUT attribute from raptor to change the sprite's palette. Have a look at the raptor manual for this. b) Poke the palette value with the value of the col you want to set. The basic formula is something like DPOKE CLUT+col_index*2,(red<<11)|(blue<<6)|(green)where col_index is a value from 0 to 255 that corresponds to the index you want to change, red and green are values from 0 to 31 and blue a value from 0 to 63. You can calculate col_index if you know which col index your sprite uses and which clut are you setting. (Also typed my memory so this could be off.) Lastly, big up for getting started! Edited March 20, 2017 by ggn 2 Quote Link to comment Share on other sites More sharing options...
sh3-rg Posted March 20, 2017 Share Posted March 20, 2017 A couple of times I think I imported a 16bit asset and used it as a colour palette, peek at it and poke into colour register, to save xunting around with RBG values and shifting around, just draw your palette in PSP or whatever. 1 Quote Link to comment Share on other sites More sharing options...
saboteur Posted March 20, 2017 Author Share Posted March 20, 2017 Right i'm clearly not understanding rapinit.s properly. below are two definitions, one of a 16*16 bmp, the other of an 8*8 bmp. The 16*16 all works fine but the 8*8 is all f****d up so i'm clearly getting it wrong somewhere. Any pointers ?? cheers ; Player Lives Object dc.l 3 ; (REPEAT COUNTER) ; Create this many objects of this type (or 1 for a single object) dc.l is_active ; sprite_active ; sprite active flag dc.w 20,0 ; sprite_x ; 16.16 x value to position at dc.w 220,0 ; sprite_y ; 16.16 y value to position at dc.w 0,0 ; sprite_xadd ; 16.16 x addition for sprite movement dc.w 0,0 ; sprite_yadd ; 16.16 y addition for sprite movement dc.l 16 ; sprite_width ; width of sprite (in pixels) dc.l 16 ; sprite_height ; height of sprite (in pixels) dc.l is_normal ; sprite_flip ; flag for mirroring data left<>right dc.l 0 ; sprite_coffx ; x offset from center for collision box center dc.l 0 ; sprite_coffy ; y offset from center for collision box center dc.l 16/2 ; sprite_hbox ; width of collision box dc.l 16/2 ; sprite_vbox ; height of collision box dc.l BMP_LIVES ; sprite_gfxbase ; start of bitmap data dc.l 4 ; (BIT DEPTH) ; bitmap depth (1/2/4/8/16/24) dc.l is_RGB ; (CRY/RGB) ; bitmap GFX type dc.l is_trans ; (TRANSPARENCY) ; bitmap TRANS flag dc.l 16*16/2 ; sprite_framesz ; size per frame in bytes of sprite data dc.l 16/2 ; sprite_bytewid ; width in bytes of one line of sprite data dc.l 0 ; sprite_animspd ; frame delay between animation changes dc.l 0 ; sprite_maxframe ; number of frames in animation chain dc.l ani_rept ; sprite_animloop ; repeat or play once dc.l edge_ignore ; sprite_wrap ; wrap on screen exit, or remove dc.l spr_inf ; sprite_timer ; frames sprite is active for (or spr_inf) dc.l spr_linear ; sprite_track ; use 16.16 xadd/yadd or point to 16.16 x/y table dc.l 0 ; sprite_tracktop ; pointer to loop point in track table (if used) dc.l spr_unscale ; sprite_scaled ; flag for scaleable object dc.l %00100000 ; sprite_scale_x ; x scale factor (if scaled) dc.l %00100000 ; sprite_scale_y ; y scale factor (if scaled) dc.l -1 ; sprite_was_hit ; initially flagged as not hit dc.l 0 ; sprite_CLUT ; no_CLUT (8/16/24 bit) or CLUT (1/2/4 bit) dc.l can_hit ; sprite_colchk ; if sprite can collide with another dc.l cd_keep ; sprite_remhit ; flag to remove (or keep) on collision dc.l single ; sprite_bboxlink ; single for normal bounding box, else pointer to table dc.l 1 ; sprite_hitpoint ; Hitpoints before death dc.l 2 ; sprite_damage ; Hitpoints deducted from target dc.l 16/2 ; sprite_gwidth ; GFX width (of data) ; Objects Object dc.l 1 ; (REPEAT COUNTER) ; Create this many objects of this type (or 1 for a single object) dc.l is_active ; sprite_active ; sprite active flag dc.w 100,0 ; sprite_x ; 16.16 x value to position at dc.w 100,0 ; sprite_y ; 16.16 y value to position at dc.w 0,0 ; sprite_xadd ; 16.16 x addition for sprite movement dc.w 0,0 ; sprite_yadd ; 16.16 y addition for sprite movement dc.l 8 ; sprite_width ; width of sprite (in pixels) dc.l 8 ; sprite_height ; height of sprite (in pixels) dc.l is_normal ; sprite_flip ; flag for mirroring data left<>right dc.l 0 ; sprite_coffx ; x offset from center for collision box center dc.l 0 ; sprite_coffy ; y offset from center for collision box center dc.l 8/2 ; sprite_hbox ; width of collision box dc.l 8/2 ; sprite_vbox ; height of collision box dc.l BMP_OBJECT ; sprite_gfxbase ; start of bitmap data dc.l 4 ; (BIT DEPTH) ; bitmap depth (1/2/4/8/16/24) dc.l is_RGB ; (CRY/RGB) ; bitmap GFX type dc.l is_trans ; (TRANSPARENCY) ; bitmap TRANS flag dc.l 8*8/2 ; sprite_framesz ; size per frame in bytes of sprite data dc.l 8/2 ; sprite_bytewid ; width in bytes of one line of sprite data dc.l 0 ; sprite_animspd ; frame delay between animation changes dc.l 0 ; sprite_maxframe ; number of frames in animation chain dc.l ani_rept ; sprite_animloop ; repeat or play once dc.l edge_ignore ; sprite_wrap ; wrap on screen exit, or remove dc.l spr_inf ; sprite_timer ; frames sprite is active for (or spr_inf) dc.l spr_linear ; sprite_track ; use 16.16 xadd/yadd or point to 16.16 x/y table dc.l 0 ; sprite_tracktop ; pointer to loop point in track table (if used) dc.l spr_unscale ; sprite_scaled ; flag for scaleable object dc.l %00100000 ; sprite_scale_x ; x scale factor (if scaled) dc.l %00100000 ; sprite_scale_y ; y scale factor (if scaled) dc.l -1 ; sprite_was_hit ; initially flagged as not hit dc.l 0 ; sprite_CLUT ; no_CLUT (8/16/24 bit) or CLUT (1/2/4 bit) dc.l can_hit ; sprite_colchk ; if sprite can collide with another dc.l cd_keep ; sprite_remhit ; flag to remove (or keep) on collision dc.l single ; sprite_bboxlink ; single for normal bounding box, else pointer to table dc.l 1 ; sprite_hitpoint ; Hitpoints before death dc.l 2 ; sprite_damage ; Hitpoints deducted from target dc.l 8/2 ; sprite_gwidth ; GFX width (of data) Quote Link to comment Share on other sites More sharing options...
Sporadic Posted March 20, 2017 Share Posted March 20, 2017 I have a feeling if i remember correctly, you cannot have a 4bit sprite only 8px wide. It might have to be 16 px minimum for 4 bit or 16bit and then 8px wide. One of the other guys will probably know for sure 2 Quote Link to comment Share on other sites More sharing options...
Sporadic Posted March 20, 2017 Share Posted March 20, 2017 Here's a link to a past post regarding this; http://atariage.com/forums/topic/243219-is-there-sprite-size-minimum-limit/?p=3332662 Quote Link to comment Share on other sites More sharing options...
saboteur Posted March 21, 2017 Author Share Posted March 21, 2017 Sorry for the late reply. Thanks for that - kinda makes sense So I changed my 8*8 image to 16*16 and altered the bounding box to 8*8 and all is fine. Did some more pratting around last night - got hung up on a few things so didn't acheive as much as I wanted but i'm getting there. Hope to post a vid a little later. One thing that's been running around my head is how to store room info, I thought about storing everything in data statements ( e.g x, y, block type ) and iterating through - does this make sense ?? Another thing is all of MM's platforms are made up of multiple character blocks, but in RB+ do I have to over allocate each individual block in the rapinit.s, say 100, even though I may not use them on all levels ? Anyhoo, keep on keeping on. Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted March 21, 2017 Share Posted March 21, 2017 One thing that's been running around my head is how to store room info, I thought about storing everything in data statements ( e.g x, y, block type ) and iterating through - does this make sense ?? Another thing is all of MM's platforms are made up of multiple character blocks, but in RB+ do I have to over allocate each individual block in the rapinit.s, say 100, even though I may not use them on all levels ? Anyhoo, keep on keeping on. I wouldn't load each tile up as a separate object, you will eat all the bandwidth with the ObjectProcessor processing the list. The best way would be a single image (object) that you use as the screen, and draw into it. - Or even better just have a character map in ram that you check against, but use a full 16 bit image for the entire screen, eg, store each screen as a static bitmap 320x200 and work out where you are in your character table (which isn't draw) 1 Quote Link to comment Share on other sites More sharing options...
saboteur Posted March 21, 2017 Author Share Posted March 21, 2017 (edited) I wouldn't load each tile up as a separate object, you will eat all the bandwidth with the ObjectProcessor processing the list. The best way would be a single image (object) that you use as the screen, and draw into it. - Or even better just have a character map in ram that you check against, but use a full 16 bit image for the entire screen, eg, store each screen as a static bitmap 320x200 and work out where you are in your character table (which isn't draw) OK - so if i understand correctly, draw the whole cavern as an image and then calculate where the player sprite is against the x and y's of the platform on the image ?? I can see that working but how would I handle interactive platforms - E.G the ones where they crumble away ? would these be laid over the top ? As an aside to this though this is what I came up with earlier but doesn't do as expected - just dumps all the blocks in the bottom left hand corner of the screen sub display_cavern local LVAR_brick_id%, LVAR_platform_id%, LVAR_y%, LVAR_x% dim x as short LVAR_brick_id = ID_bricks LVAR_platform_id = ID_platform LVAR_x = 20 LVAR_y = 20 for x = 0 to 199 if DATA$[x] = "1" THEN rsetobj(LVAR_brick_id, R_sprite_x, (LVAR_x<<16)) ' set x-position' rsetobj(LVAR_brick_id, R_sprite_y, (LVAR_y<<16)) ' set y-position' LVAR_x = LVAR_x + 16 LVAR_brick_id = LVAR_brick_id + 1 elseif DATA[x] = "2" THEN rsetobj(LVAR_platform_id, R_sprite_x, (LVAR_x<<16)) ' set x-position' rsetobj(LVAR_platform_id, R_sprite_y, (LVAR_y<<16)) ' set y-position' LVAR_x = LVAR_x + 16 LVAR_platform_id = LVAR_platform_id + 1 elseif DATA[x] = "x" THEN ' its the end of the line so advance y and reset x' LVAR_y = LVAR_y + 16 LVAR_x = 20 elseif DATA[x] = "0" THEN ' its a blank block so advance the x position' LVAR_x = LVAR_x + 16 endif loop '1,2,3,4,5,6,7,8,9,0,1,2,3,4,5,6,7,8,9,0' data 1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,x '1' data 1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,x '2' data 1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,x '3' data 1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,x '4' data 1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,x '5' data 1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,x '6' data 1,0,0,0,0,0,0,0,0,0,1,1,1,2,2,2,2,2,1,x '7' data 1,0,0,2,2,2,2,2,2,2,0,0,0,0,0,0,0,0,1,x '8' data 1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,x '9' data 1,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,1,x '0' end sub Cheers for all the help and advice. Edited March 21, 2017 by saboteur Quote Link to comment Share on other sites More sharing options...
saboteur Posted March 21, 2017 Author Share Posted March 21, 2017 After some jiggery pokery i've concluded that DATA[x] doesn't read anything at all which is a bit of a head scratcher. Gonna have to try something else then Quote Link to comment Share on other sites More sharing options...
Sporadic Posted March 21, 2017 Share Posted March 21, 2017 After some jiggery pokery i've concluded that DATA[x] doesn't read anything at all which is a bit of a head scratcher. Gonna have to try something else then Instead of data, you could use Set varname[] As integer 0,0,0,0,0,0,0,0. Blah blah End set 2 Quote Link to comment Share on other sites More sharing options...
ggn Posted March 21, 2017 Share Posted March 21, 2017 (edited) Instead of data, you could use Set varname[] As integer 0,0,0,0,0,0,0,0. Blah blah End set or dim map[2,20]={{1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20},{21,22,23,24,25,26,27}} as short Note: dim expects you to define number of lines first and then columns. Edited March 21, 2017 by ggn 1 Quote Link to comment Share on other sites More sharing options...
saboteur Posted March 21, 2017 Author Share Posted March 21, 2017 Instead of data, you could use Set varname[] As integer 0,0,0,0,0,0,0,0. Blah blah End set I'll give that a bash in a bit. I've also tried using an array and that failed to return anything either, so i must be doing it wrong. Quote Link to comment Share on other sites More sharing options...
ggn Posted March 21, 2017 Share Posted March 21, 2017 Also, something of lower priority for now, but this rsetobj(LVAR_brick_id, R_sprite_x, (LVAR_x<<16) can also be written as rlist[LVAR_brick_id].x=LVAR_x<<16 which will produce much faster code in general. Also: rlist[LVAR_brick_id].x_=LVAR_x<<16 can be used if the fraction part of x (i.e. the low 16 bits) is 0. Quote Link to comment Share on other sites More sharing options...
saboteur Posted March 21, 2017 Author Share Posted March 21, 2017 Yay - now where getting somewhere 8 Quote Link to comment Share on other sites More sharing options...
saboteur Posted March 21, 2017 Author Share Posted March 21, 2017 Also, something of lower priority for now, but this rsetobj(LVAR_brick_id, R_sprite_x, (LVAR_x<<16) can also be written as rlist[LVAR_brick_id].x=LVAR_x<<16 which will produce much faster code in general. Also: rlist[LVAR_brick_id].x_=LVAR_x<<16 can be used if the fraction part of x (i.e. the low 16 bits) is 0. Again, thanks for the info. Quote Link to comment Share on other sites More sharing options...
Sporadic Posted March 21, 2017 Share Posted March 21, 2017 Yay - now where getting somewhere Looking good Quote Link to comment Share on other sites More sharing options...
saboteur Posted March 21, 2017 Author Share Posted March 21, 2017 Got to redefine some of the graphics as they a bit large but it's coming along. Quote Link to comment Share on other sites More sharing options...
ggn Posted March 21, 2017 Share Posted March 21, 2017 (edited) rlist[LVAR_brick_id].x_=LVAR_x<<16 can be used if the fraction part of x (i.e. the low 16 bits) is 0. Correction: this should be rlist[LVAR_brick_id].x_=LVAR_x(thanks to Sporadic for mentioning this!) Edited March 21, 2017 by ggn Quote Link to comment Share on other sites More sharing options...
saboteur Posted March 21, 2017 Author Share Posted March 21, 2017 a bit further... Conveyor and crumbly platform graphics to do - then game logic... starting with jumping 1 Quote Link to comment Share on other sites More sharing options...
Sporadic Posted March 21, 2017 Share Posted March 21, 2017 Correction: this should be rlist[LVAR_brick_id].x_=LVAR_x<<16(thanks to Sporadic for mentioning this!) That's still the same isn't it? Quote Link to comment Share on other sites More sharing options...
ggn Posted March 21, 2017 Share Posted March 21, 2017 No it isn't 1 Quote Link to comment Share on other sites More sharing options...
