Done rotary mod but ....
Stephen g
Need a little advise guys, iv done a tempest 2000 rotary mode, everything works well, apart from buttons B & C dont work unless i press both together.
I guess iv got a trace or solder touching each other. But doesn't look like it.
Its hard to make out what the correct solder point is on my diagram for B & C so im asking kindly can anyone point me in the direction of a clear picture of the jaguar circuit board points (im using the grey button controller)..
thanks
Make sure you get a magnifying glass and look at the solder points. You can use a dentist's pick to scrap between the solder points.
EDIT: looks like that is the black button one, I will see if I have a good picture for the gray ones.
Edited by Machine
I had The same problem when I try to use the solder points as well. That's why I only use the wires connecting the two separate circuit boards. I just remove the covering of the wires a little and connect the rotary leads there.
Why didn't I think of that.. lol how easy is that. Can you share A diagrame or pic please ?
Wonder how easy it would to put a switch on that way ?
Ok, so here are a couple pics. One is of the pcbs with the correct connecting wires exposed for ground, left and right; in order from left to right. In other words 1,2 &12. The same as the solder points that would have been used.
The other pic is of the rotary/switch assembly attached. Ground from the rotary and left/right from the rotary, to the switch then to the correct wires.
Hope these help!
Hope these help!
Wow thanks, how easy is that, you don't even need to solder just use crimps..
Is this the same for the black keyed joypads ?
