Allen Schweitzer Posted April 22, 2017 Share Posted April 22, 2017 I'm going to eventually buy another 5200. Mine was lost in a flood 16 years ago. I'm just wanting some feedback from some owners on whether they would recommend a unit with 2 or 4 ports for controllers. I read somewhere a while back that there is at least 1 game that cannot be played on a 4 port controller. So in seeking counsel from the wise, I throw this out for any and all opinions. No reason one way or the other is too trivial to leave out, and I appreciate any responses. Thank you! Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted April 22, 2017 Share Posted April 22, 2017 I'm not aware of any 5200 games that aren't playable on the 4 port. However, there are 3 games that aren't playable on a 2 port. Krazy-Shootout, Mountain King, and the original Pitfall for sure. But swap out the bios chip on the 2 port with a 4 port and you're good to go. Quote Link to comment Share on other sites More sharing options...
bah Posted April 25, 2017 Share Posted April 25, 2017 (edited) 2 port won't play the 3 games above 4 port won't play the 2600 adapter unless modified. Also the 4 port requires a switch box that is often missing when the console is sold or it is broken so replacements are not common. Overall, go for 2 port but replace the bios chip for compatibility, SD multicart, and some sort of joystick adapter because many games just play better with a digital stick or pad in place of the analog no-work 5200 originals. Some games require analog though, so it is a good thing to have at least one original controller with gold contacts from Best Electronics. Edited April 25, 2017 by bah Quote Link to comment Share on other sites More sharing options...
Allen Schweitzer Posted April 26, 2017 Author Share Posted April 26, 2017 For $45 bucks or whatever with a core trade in, there is no question that I will be doing business with Best E after I get my system for the lifetime controllers!!! I'm not a fan of ANY aftermarket controller. I bought 3 gold PCB's for my 2600 controllers, and they are PRICELESS! Thanks for your input!! Quote Link to comment Share on other sites More sharing options...
David Alexander Posted July 7, 2017 Share Posted July 7, 2017 Hi Guys, we at the Atari 5200 Podcast are partial to the 4 port Quote Link to comment Share on other sites More sharing options...
7800fan Posted July 9, 2017 Share Posted July 9, 2017 I also have the 4 ports and prefer that to 2 ports. There are actually 4 different variations. The original 4 port run does not work with 2600 adapter. The 4 ports console with a * in the serial number have revised design to work with 2600 adapter properly. Then there are early 2 ports consoles that has 4 ports BIOS and will work with those 3 games, and lastly, the later 2 ports console with revised BIOS for PAL support but broke 3 games. 4 ports can easily be modified to not need switch box, console5 has a kit for just a few dollars. Basically remove 2 original parts, install new jack on the console, wire in and add 2 included parts. Then sell that switch box (if you got it) on eBay for like $25. 2 ports that don't work with 3 games can also be fixed but getting to BIOS chip is a pain in the butt job, you have to twist about 30 metal tabs to remove RF shield in order to get to the original BIOS chip. I couldn't use my 5200 without the shield, the video was very fuzzy with the shield off. Quote Link to comment Share on other sites More sharing options...
BassGuitari Posted July 9, 2017 Share Posted July 9, 2017 I'm not aware of any 5200 games that aren't playable on the 4 port. However, there are 3 games that aren't playable on a 2 port. Krazy-Shootout, Mountain King, and the original Pitfall for sure. But swap out the bios chip on the 2 port with a 4 port and you're good to go. Would that mess with 2600 Adapter compatibility? Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted July 9, 2017 Share Posted July 9, 2017 Would that mess with 2600 Adapter compatibility? Nope... AV modding a 5200 of either model will mess with 2600 adapter capability. Unless the UAV is able to leave that intact...Hmm... 1 Quote Link to comment Share on other sites More sharing options...
BassGuitari Posted July 9, 2017 Share Posted July 9, 2017 Sweet, I never knew that! I actually have two 4-ports and a 2-port--if I had known this before I probably would have done that BIOS swap years ago and sacrificed one of the 4s. Quote Link to comment Share on other sites More sharing options...
