SignGuy81 Posted April 23, 2017 Share Posted April 23, 2017 I wanted to provide a tip for anyone who has poor RF picture with a TV/Game switch and doesn't have an RCA to coax adapter or wants a fix meanwhile until you can get one. All you need is a little bit of wire, soldering gun and some solder, and some optional foil tape. I recently got two Atari 2600s, and only one switchbox came with them. When I first hooked it up one to test I noticed the RF looked horrible. I opened the switch box and checked continuity on the switch when set on Game across the leads where I was supposed to have continuity and one side I didn't have any unless I kept messing around with the switch, it was intermittent. Instead of fooling around with taking the switch off and cleaning the contacts or anything I thought since I don't need the switch anyway instead I just soldered wires across where I need them, eliminating the selector switch altogether. Then I put everything back and wrapped foil tape around the entire box to help keep out any interference. Now the picture is very clear. Quote Link to comment Share on other sites More sharing options...
