DadsGlasses Posted June 3, 2017 Share Posted June 3, 2017 Hello. I want to add an LED to my Intellivision I. (To keep me from leaving it turned on.) Anyone have a tutorial? I assume I need an LED and a resistor. Amy advice on what to get is greatly appreciated. Then I just need to know where to solder it. Thanks. Quote Link to comment Share on other sites More sharing options...
Osgeld Posted June 3, 2017 Share Posted June 3, 2017 (edited) I dunno where to solder it you just need to find a 5 volt source If there is a 7805 in there you can use pin 3 of that and for a standard though hole led 330 to 1k ohm for the resistor depending how bright the led is and how bright you want it, modern Lord's even low end ones can shoot out quite a bit of light compared to what they would have back then Edited June 3, 2017 by Osgeld Quote Link to comment Share on other sites More sharing options...
mr_me Posted June 3, 2017 Share Posted June 3, 2017 (edited) Here's some schematics and the service manual. In addition to the 7805 regulator, the third pin on the 5pin ribbon power connector should be 5v, fourth should be ground. http://spatula-city.org/~im14u2c/intv/tech/master.html https://console5.com/wiki/Intellivision Edit: sorry, its the first pin on the ribbon cable (top) that is 5v. I misread the schematic. Edited June 3, 2017 by mr_me Quote Link to comment Share on other sites More sharing options...
DadsGlasses Posted June 3, 2017 Author Share Posted June 3, 2017 Here's some schematics and the service manual. In addition to the 7805 regulator, the third pin on the 5pin ribbon power connector should be 5v, fourth should be ground. http://spatula-city.org/~im14u2c/intv/tech/master.html https://console5.com/wiki/Intellivision Thank you very much!! Quote Link to comment Share on other sites More sharing options...
DadsGlasses Posted June 6, 2017 Author Share Posted June 6, 2017 Finished this quick mod today. I was planning on just placing a single led on the bottom portion of the case. My thought was that it would preserve the integrity of the upper case, and also help with future disassembly. Unfortunately the overhang is just too deep, and the mod didn't suit my intended purpose. So I added a second led in the standard location by the power switch. I used amber leds to try and match the overall look of the console. Thanks for all of the helpful advice. In this situation, the pros of the mod outweigh the cons of messing with a pure console case. Quote Link to comment Share on other sites More sharing options...
7800fan Posted June 7, 2017 Share Posted June 7, 2017 That top LED is about the same place that Intv 3 has red power LED. Quote Link to comment Share on other sites More sharing options...
DadsGlasses Posted June 7, 2017 Author Share Posted June 7, 2017 That top spot seems to make the most sense. Quote Link to comment Share on other sites More sharing options...
