RSS Bot Posted June 20, 2017 Share Posted June 20, 2017 Reworked the stations to fire from the 2 closest pods. For that I revised the closest pod to player tests from before, it now shows the 2 pods it'll fire from as well as the targeting line from the closest pod:Additionally I finally tracked down a bug where you could shoot a station pod that you shouldn't be able to. For that I built another test build (though I forgot to save a copy of the bin, sorry) which would show the last pod destroyed, and the shot that destroyed it. I also had it show the shot further down using another missile, and once more below that using a sprite to show which collision image was used (as the image data to draw a missile is different than the image data for collision detection)*. In reviewing the results the collision didn't make sense - unless the pod image was being treated as a 2X sprite. One of the things I'd recently done was revamp the sprite state to hold flags for various things like 2x, whereas before I used a ranges of image ID values to denote things like sprite sizes. I made the change to use bits in the state variable as those are much faster to check for than a range of values: The sprite info is stored in arrays: unsigned short int gSpriteState[MAX_SPRITES+1]; // +1 is used for Station Pod collision detectionunsigned char gSpriteImageID[MAX_SPRITES+1]; // +1 is used for Station Pod collision detectionunsigned short int gSpriteX[MAX_SPRITES+1]; // +1 is used for Station Pod collision detectionunsigned short int gSpriteY[MAX_SPRITES+1]; // +1 is used for Station Pod collision detectionunsigned char gSpriteColor[MAX_SPRITES]; Lastly I created all new station arrangements for the Gamma Quadrant (these may be revised by Nathan at a later date). For Harmony or Stella (requires * This is the data to draw a horizontal shot: ShotHorizontal: .byte %11110000 .byte %11110000ShotHorizontalHeight = * - ShotHorizontal Attached thumbnail(s) Attached File(s) draconian_20170619.bin (32KB)Number of downloads: 0 draconian_20170619_closest_2_pods.bin (32KB)Number of downloads: 0 http://atariage.com/forums/blog/148/entry-13988-station-revisions/ Link to comment Share on other sites More sharing options...
