johncena1973 Posted July 25, 2017 Share Posted July 25, 2017 Hi guys, i just burned " Dungeons and Dragons" for my SEGA SATURN. Mine is already installed with modchip that can play burned game and import games. But the thing is, it doesn't have music. It still does have fx sound but just only no music. I used IMGBURN at 8x speed. Quote Link to comment Share on other sites More sharing options...
keepdreamin Posted July 25, 2017 Share Posted July 25, 2017 Did the rip you download come with MP3's as tracks? Quote Link to comment Share on other sites More sharing options...
Austin Posted July 25, 2017 Share Posted July 25, 2017 (edited) Yeah, it sounds like you may not have configured the audio tracks properly. Some games are in BIN + CUE format, and if so you need the audio tracks separate and you have to make sure they are referenced properly in the CUE file (use a text editor to modify). Saturn can be a little iffy though as there are other formats floating around as well. Edited July 25, 2017 by Austin 1 Quote Link to comment Share on other sites More sharing options...
johncena1973 Posted July 25, 2017 Author Share Posted July 25, 2017 Did the rip you download come with MP3's as tracks? No i didn't . When i downloaded it, it came with only bin and cue file Quote Link to comment Share on other sites More sharing options...
keepdreamin Posted July 25, 2017 Share Posted July 25, 2017 No i didn't . When i downloaded it, it came with only bin and cue file huh, well you could try mounting the image in a virtual drive and firing up SSF and see if there's music then. Maybe you found a bad rip. 2 Quote Link to comment Share on other sites More sharing options...
johncena1973 Posted July 25, 2017 Author Share Posted July 25, 2017 huh, well you could try mounting the image in a virtual drive and firing up SSF and see if there's music then. Maybe you found a bad rip. That's the weird thing. I tried with SSF emulator and its worked but not on the real sega saturn. Quote Link to comment Share on other sites More sharing options...
Austin Posted July 25, 2017 Share Posted July 25, 2017 Have you tried burning it again? Quote Link to comment Share on other sites More sharing options...
johncena1973 Posted July 25, 2017 Author Share Posted July 25, 2017 Have you tried burning it again? I did. But here is the weird thing, the NA games have music and sound fx. But only the Japanese game has sound fx , no music Quote Link to comment Share on other sites More sharing options...
Mindless Posted October 29, 2023 Share Posted October 29, 2023 Did you ever find a solution to this problem? I am having the same problem with Japanese games, particularly Samuri Showdown 4. Quote Link to comment Share on other sites More sharing options...
Austin Posted November 9, 2023 Share Posted November 9, 2023 On 10/29/2023 at 7:20 PM, Mindless said: Did you ever find a solution to this problem? I am having the same problem with Japanese games, particularly Samuri Showdown 4. There are a few things I can think of considering: 1. Try to track down a different rip/ISO and ensure it's different from the one you already have; re-burn. 2. Research and determine if it's a game that uses CD audio for music. If so, you may need to ensure you've got the music tracks set up correctly with your rip. It depends on the rip. You will need to look at the .CUE file in a text reader and make sure the music files match to what's in the .CUE. 3. If the game uses the Saturn's internal sound processor for music generation as opposed to CD audio, then it could be some sort of compatibility issue and you're probably out of luck. Quote Link to comment Share on other sites More sharing options...
DragonGrafx-16 Posted November 10, 2023 Share Posted November 10, 2023 On 10/29/2023 at 6:20 PM, Mindless said: Did you ever find a solution to this problem? I am having the same problem with Japanese games, particularly Samuri Showdown 4. I use a Pseudo Saturn cart and not a modchip and burnt games have music no matter the region. I've got a nice collection of burnt Japanese shoot 'em ups and all of the music works. I would try burning the games as slow as your drive supports. Quote Link to comment Share on other sites More sharing options...
