Cuttle Cart Question
up2knowgood
I own the Cuttle Cart, let's start with that. I'd like to know if there is a way to get normal ROMs like what you can download from this very site converted to the audio files that the Cuttle Cart and Super Charger use(I believe they're called binary files, but I'm not 100% on that). Supposedly there is a program that can do that on Stella Gets A New Brain, but surely that would be super outdated now, over 20 years after its initial release, and at the very least require several special plugins to get it to work on a newer computer like mine. I'm also not going to sugar coat it, I last used an emulator over 10 years ago in high school, and have never really programmed anything, so I probably face an uphill battle with this anyway.
I'm hoping there is someone out there who can help me if it is possible, I would really appreciate it.
Did you just double-clicked on the file? If so, that's the problem.
Makewav is a command line program, you need to run it from the command prompt. (search how to do that with your OS)
There's also Playbin, which will play the files directly from the audio card (without generating files on the hard drive. You can find it here:
http://atariage.com/forums/topic/247849-supercharger-and-wplaybin/?do=findComment&comment=3414680
Tried Command Prompt too, and it still didn't work, just told me it was incompatible again. However, Playbin worked flawlessly! Well...had to play around with the sound settings and volume for a bit, but other than that flawlessly. Thank you both so much! I really appreciate it. :D
