+InsaneMultitasker Posted August 11 Share Posted August 11 @Asmusr I've been applying my updated Geneve routines and loader to Flying Shark so that I can release the changes. Alas, the game now never makes it past the title screen and the music never starts. I thought the problem was in my keyboard routine, but Pinball is working with the same code. While debugging I came across four places where "shark.a99" is setting the workspace to 0 with "LWPI 0". Maybe this code isn't used? Sharing for your thoughts. See screenshots. 1 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted August 11 Author Share Posted August 11 That instruction is modified to restore the WS. 2 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted August 11 Share Posted August 11 Oh, sure enough, with fresh eyes I now see the MOV instruction following the STWP statement. Thank you! 2 Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted August 12 Share Posted August 12 With much appreciation to @mizapf, we were able to track down the root cause of my Geneve conversion problems. The first problem was one of forgetfulness: I had modified the key EQUates to represent their ASCII equivalents for use with my 2022 loader. The 2023 updated loader now uses the CRU-based row/column values, which it translates to XT state table values as needed. The wrong values had the unintended consequence of passing all keyboard requests to the 9901 CRU-based joystick routine, which then incorrectly tested CRU address 0 (9901 mode setting), and returned NEQ for all key tests. My error was compounded by a surprise: the ROM image that I am using contains all 0x000 in bank >6078. Together with the first problem, Flying Shark thought the "M" key was -always- pressed, so it dutifully passed control to bank >6078 and a host of 0x0000 instructions that the Geneve did not like. I am fairly certain that I downloaded the ROM at the same time as the source files, back in June 2022. I'll review what I have locally either tonight or tomorrow. I confirmed that my earlier release crashes if 'M' is pressed. 1 1 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted August 13 Share Posted August 13 16 hours ago, InsaneMultitasker said: With much appreciation to @mizapf ... and, of course, the Geneve emulation in MAME and its debugger. 🙂 3 Quote Link to comment Share on other sites More sharing options...
