swvcc Posted May 20, 2003 Share Posted May 20, 2003 I have a 4-switch that works fine for the first 5 minutes or so then after 5 minutes or so the screen all the sudden gets fuzzy and stays that way. The only way to fix it is to turn the unit off and back on then it works fine again for the first 5 minutes then gets fuzzy again. I just bought a new power supply (meeting exact power requirements) so I don't think that is the problem. Any ideas? The RF (is that what it's called?) cable coming out of the unit has a small tear and you can see a LITTLE bit of the wiring inside - could this be the problem? I want to give this unit as a gift and want to get it working properly. Thanks for any help you can provide. -Scott Link to comment Share on other sites More sharing options...
Tommy17 Posted June 8, 2003 Share Posted June 8, 2003 I have the same exact problem !!! If you find out what the problem is, PLEASElet me know. Thanks. Tommy #17 Link to comment Share on other sites More sharing options...
Nukey Shay Posted June 8, 2003 Share Posted June 8, 2003 He posted the same question a couple times...this thread offered a few suggestions: http://www.atariage.com/forums/viewtopic.php?p=301052 Link to comment Share on other sites More sharing options...
Archived
This topic is now archived and is closed to further replies.
