hueyjones70 Posted August 21, 2017 Share Posted August 21, 2017 My 800XL memory test stops after 40 blocks. I have not noticed any other problems and haven't yet looked at the mobo. Quote Link to comment Share on other sites More sharing options...
Rybags Posted August 21, 2017 Share Posted August 21, 2017 That's normal, it'll only check 48K maximum of the installed 64. The later XE OS will check 48K of main Ram as well as the 64K extended. 40 blocks means Basic's enabled. To test 48K either power up with no disk device powered up while holding option or from Basic type: POKE 9,0 : POKE 1016,1 Then press Reset. Then select Memory Test from the menu. Quote Link to comment Share on other sites More sharing options...
+tf_hh Posted August 21, 2017 Share Posted August 21, 2017 My 800XL memory test stops after 40 blocks. I have not noticed any other problems and haven't yet looked at the mobo. If you hold down OPTION while powering off and enter the memory test, you will see that 48 blocks are tested - 48 KB. The 16 KB under the OS-ROM space are never tested by the SELFTEST. Quote Link to comment Share on other sites More sharing options...
hueyjones70 Posted August 21, 2017 Author Share Posted August 21, 2017 My 800XL memory test stops after 40 blocks. I have not noticed any other problems and haven't yet looked at the mobo. Thanks for the info. Quote Link to comment Share on other sites More sharing options...
hueyjones70 Posted August 22, 2017 Author Share Posted August 22, 2017 I am preparing to install a Rambo 256K upgrade to my 800XL, how do I test the ram to see if I installed it correctly? Quote Link to comment Share on other sites More sharing options...
Guest Posted August 22, 2017 Share Posted August 22, 2017 (edited) there are files to test extended ram pm sent Edited August 22, 2017 by Guest Quote Link to comment Share on other sites More sharing options...
