separating lines on the commodore 64
Jackel192
i recently made a short "game", if you could call it that. it's a simple guessing game called Key and Lock. the object is two look at two objects represented by the C64's Character set and guess if it will fit the lock, represented by an x. my question is this: is there an alternative to the WAIT command for the c64. i want the program to wait for a keypress then give the result.
example:
This is a key
will the key fit the lock?
(wait for keypress)
it fits, good job
or if the key does not fit
(wait for key press)
it does not fir, too bad
also, is there a way to space out the lines so its not bunched up?
thanks in advance (p.s, i tried the IF command for a$ and got an error. i need a workaround.)
Waiting for the keypress is easy enough, use GET to read the keyboard and keep looping back if the result is null:
300 GET A$
310 IF A$="" THEN 300
Spacing out the lines can be done a couple of ways; either use PRINT on it's own between two existing lines to print out a blank line or typing the existing lines as PRINT "[hit cursor down]will the key fit the lock?" which embeds a cursor down into the PRINT statement.
I keep getting an error
if a$= "open door" goto 50
syntax error
Because the syntax is wrong; they're called IF/THEN statements for a reason and you need an IF and a THEN for it to work!
IF A$="OPEN DOOR" THEN GOTO 50
Actually, in Commodore BASIC you can skip the GOTO so...
IF A$="OPEN DOOR" THEN 50
...will work too.
If - goto constructs work on the C64, too,
if a$= "open door" goto 50,
if a$= "open door" then 50 and
if a$= "open door" then goto 50
should all do the same, the syntax error must be caused by something else. I'd check for hard to spot typos like AS instead of A$, ; instead of : or something like that.
