Atarian7 Posted September 21, 2017 Share Posted September 21, 2017 Do you put the glue on the cartridge or do you put it on back of the label? Or both? Quote Link to comment Share on other sites More sharing options...
RodLightning Posted September 21, 2017 Share Posted September 21, 2017 I use a very light dusting of 3M spray adhesive on the back of label and apply it after cleaning cartridge surface. I always stress the need to invert the can until it blows air after each use. This is probably a good reason to consider using some kind of brush-on adhesive instead. The spray cans are handy, but a new can can easily be ruined by clogging the button and tube. 1 Quote Link to comment Share on other sites More sharing options...
up2knowgood Posted September 21, 2017 Share Posted September 21, 2017 I use just small dabs of a PVC super glue in drops on the cartridge itself. Very very, little. That stuff presses out so far, but holds forever. 1 Quote Link to comment Share on other sites More sharing options...
BigO Posted September 21, 2017 Share Posted September 21, 2017 I found glue stick to be very effective and convenient. I applied it directly to the label the few times I used it. Laid the label face down on a sacrificial sheet of paper to assure that the very edges could be thoroughly covered with the glue. Probably wouldn't hurt to clean the cartridge surface with alcohol as a first step in the whole process. 3 Quote Link to comment Share on other sites More sharing options...
up2knowgood Posted September 21, 2017 Share Posted September 21, 2017 I found glue stick to be very effective and convenient. I applied it directly to the label the few times I used it. Laid the label face down on a sacrificial sheet of paper to assure that the very edges could be thoroughly covered with the glue. Probably wouldn't hurt to clean the cartridge surface with alcohol as a first step in the whole process. Really? I used a glue stick once, and it like soaked and shown through the label. 1 Quote Link to comment Share on other sites More sharing options...
CRTGAMER Posted September 21, 2017 Share Posted September 21, 2017 For labels with issues of glue soak thru, try double sided tape. Not photo tape of foam tape, the plain clear double stick works well. Place oversized to back of cart label, trim to size tghen place on cart. 1 Quote Link to comment Share on other sites More sharing options...
RamrodHare Posted September 22, 2017 Share Posted September 22, 2017 Glue sticks are the preferred method for most vintage toy enthusiasts when it comes to sticking vintage labels back without damaging the plastic. Of course if you aren't worried about keeping things vintage, reproduction labels are the best bet. While cyanoacrylates (super glue) will stick stuff together, it's not something you can easily remove, so I don't recommend it. I recently (yesterday, as a matter of fact) found a roll of tape, that isn't actual tape. It's 2 inches wide and on a roll. It looks like a dark brown wax paper. When you apply it to something, it sticks, but the brown paper can then be peeled off, leaving a nice even coat of clear adhesive. I don't know where I got it or how long I've had it, since I found it while going through some junk I had boxed up in the spare room. I figure this stuff would be excellent for adding a sticky back to any type of paper, sadly, I don't have any more info than what I've given. I have a feeling it came from a box of assorted industrial tape that a friend of mine in maintenance at a local factory gave to me a few years ago.. 1 Quote Link to comment Share on other sites More sharing options...
BigO Posted September 22, 2017 Share Posted September 22, 2017 Really? I used a glue stick once, and it like soaked and shown through the label. I thought it was a stupid idea, too. Then I tried it on a Parker Bros. Frogger cartridge, because, well everybody else was doing it and it was Frogger so I had nothing to lose. Didn't have any bleeding/soaking through problems as I expected. That was several years ago and the label is still on. Used it on a couple of Activision carts as well, if I recall correctly. If you search the forums for glue stick, you should see a number of very similar conversations. 1 Quote Link to comment Share on other sites More sharing options...
up2knowgood Posted September 22, 2017 Share Posted September 22, 2017 I thought it was a stupid idea, too. Then I tried it on a Parker Bros. Frogger cartridge, because, well everybody else was doing it and it was Frogger so I had nothing to lose. Didn't have any bleeding/soaking through problems as I expected. That was several years ago and the label is still on. Used it on a couple of Activision carts as well, if I recall correctly. If you search the forums for glue stick, you should see a number of very similar conversations. Huh, glue stick for the win then. May have to try that again sometime. Maybe use a good brand. 1 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted September 22, 2017 Share Posted September 22, 2017 UHU Purple is great. It goes on with color so you can see where it's being applied, but it dries clear. I've used it for decades. My blog has an entry on this... with supporting video. 1 Quote Link to comment Share on other sites More sharing options...
