ubersaurus Posted September 24, 2017 Share Posted September 24, 2017 I recently got my Atari pong unit's paddles cleaned up, and it works way better now... except now I don't have any sound whatsoever coming out of the speaker. There was sound prior to me opening it up to clean the paddles, but nothing now. There's no mute on this thing, right? Any idea how to fix it? Quote Link to comment Share on other sites More sharing options...
Trinity Posted September 25, 2017 Share Posted September 25, 2017 Could have broke a wire going to the speaker, Or got it loose someway. Quote Link to comment Share on other sites More sharing options...
BassGuitari Posted September 25, 2017 Share Posted September 25, 2017 Yeah, probably a cracked solder joint or broken wire. Should be a pretty simple fix. Quote Link to comment Share on other sites More sharing options...
ubersaurus Posted September 26, 2017 Author Share Posted September 26, 2017 Hm, I'll refresh the solder on the cord and see if I can check continuity (the wires are in the little plastic connector so I don't know how well the probe will fit in there), see if I can suss out the issue. If it comes down to doing something else with the wire it might be a little beyond me. Quote Link to comment Share on other sites More sharing options...
chas10e Posted September 26, 2017 Share Posted September 26, 2017 they used 2 prong plugs on everything in there .... is it back on the right spot ? there are also some very thin wires on the speaker itself I have gotten a pong unit with a bad speaker before, the spare speaker I had worked (now I haz no spare ) Quote Link to comment Share on other sites More sharing options...
ubersaurus Posted September 26, 2017 Author Share Posted September 26, 2017 they used 2 prong plugs on everything in there .... is it back on the right spot ? there are also some very thin wires on the speaker itself I have gotten a pong unit with a bad speaker before, the spare speaker I had worked (now I haz no spare ) I believe so. The three spots are labeled on the board and since the power and serve button plugs seem to work just fine it's gotta just be an issue with the wire or the connection. Quote Link to comment Share on other sites More sharing options...
ubersaurus Posted September 26, 2017 Author Share Posted September 26, 2017 (edited) Color me stumped. I checked continuity for both speaker wires and I'm getting the beep, so they seem fine. I even tried it with the wire plugged into the spot on the main board and checked continuity from the speaker to the prong and it still goes through. No idea what could be the problem. Edited September 26, 2017 by ubersaurus Quote Link to comment Share on other sites More sharing options...
