masschamber Posted October 16, 2017 Share Posted October 16, 2017 anyone know where I can get replacements of that stupid proprietary ac connector? Quote Link to comment Share on other sites More sharing options...
SignGuy81 Posted October 16, 2017 Share Posted October 16, 2017 Do you mean for on the actual Atari or for the ac adapter? Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted October 16, 2017 Share Posted October 16, 2017 Pretty sure he means the DC jack on the console. Quote Link to comment Share on other sites More sharing options...
SignGuy81 Posted October 16, 2017 Share Posted October 16, 2017 In that case probably have to find one off a donor system. That or putting some other type on there, but then you'd have to put a matching plug on the power adapter cord. 1 Quote Link to comment Share on other sites More sharing options...
chas10e Posted October 16, 2017 Share Posted October 16, 2017 I kind of wonder if something like this would work ... http://www.ebay.com/itm/10Pcs-XH2-54-2Pin-Pitch-Leads-Header-Socket-Connector-DIP-90-Degree-Angle-PCB-/262350618883?epid=1663056496&hash=item3d1550c103:g:HNUAAOSwxp9W86Tb Quote Link to comment Share on other sites More sharing options...
+H454 Posted October 16, 2017 Share Posted October 16, 2017 (edited) I kind of wonder if something like this would work ... http://www.ebay.com/itm/10Pcs-XH2-54-2Pin-Pitch-Leads-Header-Socket-Connector-DIP-90-Degree-Angle-PCB-/262350618883?epid=1663056496&hash=item3d1550c103:g:HNUAAOSwxp9W86Tb It might fit, but the OEM jack had three plastic mounting points. Just two solder points on the jack would rip out/break. Jack from best: Atari 7800 R/A Power Jack, solder pull CB101194 $12.95 best 7800 power adapter $15 I have also used this: https://www.digikey.com/product-detail/en/cui-inc/PJ-012B/CP-012B-ND/509865 I will have to glue it down to be more secure and the way the pins lined up, the center is ground. If your looking for the cord end - 15.2891 ac adapter - The adapter cord from a shark euro vacuum may work too, but the surround on the plug is rather large. Edited October 16, 2017 by H454 Quote Link to comment Share on other sites More sharing options...
masschamber Posted October 16, 2017 Author Share Posted October 16, 2017 I kind of wonder if something like this would work ... http://www.ebay.com/itm/10Pcs-XH2-54-2Pin-Pitch-Leads-Header-Socket-Connector-DIP-90-Degree-Angle-PCB-/262350618883?epid=1663056496&hash=item3d1550c103:g:HNUAAOSwxp9W86Tb I'm talking about the part that plugs into that Quote Link to comment Share on other sites More sharing options...
SignGuy81 Posted October 16, 2017 Share Posted October 16, 2017 I'm talking about the part that plugs into that Well, since you are talking about the plug on the power adapter then here is a cheap adapter http://www.ebay.com/itm/Ac-Power-Adapter-for-Atari-7800-System-/112168344158?hash=item1a1dc11a5e:g:I7IAAOSw4shYA0PD I'm going to keep looking though to see if can find just the plug. Quote Link to comment Share on other sites More sharing options...
SignGuy81 Posted October 16, 2017 Share Posted October 16, 2017 This post is about the console connector but maybe these two threads should be merged? http://atariage.com/forums/topic/203341-7800-console-power-connector-where-to-find-1/ Quote Link to comment Share on other sites More sharing options...
Stephen Moss Posted October 17, 2017 Share Posted October 17, 2017 Assuming the part number referenced in the original e-bay link is the correct part a quick search found these... http://www.sky-macau.com/Products/XH254-Connectors-C203/Page-1/ItemsPerPage-20.html https://www.alibaba.com/showroom/xh2.54.html https://www.ebay.com/sch/i.html?_nkw=xh2.54 https://www.amazon.co.uk/24AWG-XH2-54-Connector-Cable-Length/dp/B015IGEBFK/ref=sr_1_3?ie=UTF8&qid=1508224070&sr=8-3&keywords=xh2 Some are just offering one end, others both, some you need to assemble others are pre-wired so you will have to splice those wires into the existing cable. Quote Link to comment Share on other sites More sharing options...
mutterminder Posted October 17, 2017 Share Posted October 17, 2017 I put a 3.5 mm jack on one of my 7800's so I could use a readily available 2600 power supply. You could get the both the power supply and the jack for less than a replacement 7800 supply. 1 Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted October 17, 2017 Share Posted October 17, 2017 Could also get one of these and attach it to the same points as the original plug. This way, you could run this out of one of the rear vent slots on the 7800 without actually removing the original power jack. That way you can use an original still if you want. https://console5.com/store/nes-genesis-1-sega-cd-tg16-jaguar-more-female-jack-w-pigtail.html 1 Quote Link to comment Share on other sites More sharing options...
+H454 Posted October 18, 2017 Share Posted October 18, 2017 I'm talking about the part that plugs into that I have the power adapter I showed in my last post. If you want the cord (desoldered from ps), It's yours for $5 - shipping included. The end fits in the 7800 perfectly. Quote Link to comment Share on other sites More sharing options...
JimmySweatpants Posted July 7, 2019 Share Posted July 7, 2019 Splice this to a 9v DC 1000mA donor adapter. https://console5.com/store/atari-7800-pigtail-dc-cable-and-plug-for-custom-power-supply-5-foot-1-5m.html Quote Link to comment Share on other sites More sharing options...
AlwaysOnPlanetPatrol Posted August 1, 2019 Share Posted August 1, 2019 I ordered an AirTV OTA network receiver a few days ago. Arrived yesterday and the first thing that caught my eye was the plug in its (12V) AC adapter. It's a perfect match for the 7800 AC plug (well, except for the clip to hold it on the AirTV). Bit surprised to see this plug on a new device considering that outside of the 7800 I've never seen it elsewhere in all these years. Quote Link to comment Share on other sites More sharing options...
carlsson Posted August 1, 2019 Share Posted August 1, 2019 (edited) I'm not sure if it physically is identical, but at least a few models of the Philips Videopac G7000 (European version of the Odyssey^2) has a such mini two prong power connector. I couldn't find a matching female connector so I replaced it on my G7000 with a standard DC barrel jack, given the console itself had been modded/tampered with before. But interesting to see a such plug on new equipment. Perhaps it makes a better connection than any other type of plug available. I also checked how well a two prong motherboard connector, think one that goes to a LED or older type of fan, would fit and believe it could kind of work, assuming the diameter of the wires is good enough to carry 9V 1A or whichever power ratings you have. Edited August 1, 2019 by carlsson Quote Link to comment Share on other sites More sharing options...
Lynxpro Posted August 18, 2019 Share Posted August 18, 2019 On 10/17/2017 at 5:09 AM, mutterminder said: I put a 3.5 mm jack on one of my 7800's so I could use a readily available 2600 power supply. You could get the both the power supply and the jack for less than a replacement 7800 supply. Atari Inc probably didn't want people plugging in their old 2600 power supplies into their brand new 7800s. I'm assuming that's why they chose the different design for the 7800's power supply plug. Quote Link to comment Share on other sites More sharing options...
dodge ramman Posted November 10, 2019 Share Posted November 10, 2019 Best electronics has new ones I think, But i have thought of going with the SEGA port and just using the power brick from it! The voltage and amps are the the same I do believe! Quote Link to comment Share on other sites More sharing options...
CZroe Posted January 23, 2021 Share Posted January 23, 2021 On 8/1/2019 at 8:24 AM, AlwaysOnPlanetPatrol said: I ordered an AirTV OTA network receiver a few days ago. Arrived yesterday and the first thing that caught my eye was the plug in its (12V) AC adapter. It's a perfect match for the 7800 AC plug (well, except for the clip to hold it on the AirTV). Bit surprised to see this plug on a new device considering that outside of the 7800 I've never seen it elsewhere in all these years. What you have is a set top box from the same ODM that makes the Dish Network Joey with the same plug that I reported here: The one I had in hand used a Delta branded power supply but another AtariAge user ordered a replacement and got LiteOn brand. Now we see yours is "NetBit" brand so it seems that all three manufacturers have access to these components even though we still don't know what it's called or where you can order them. Bizarre! Anyway, that thread also identifies some other devices with the same plug including Brinkmann Q-Beam Max Million spotlights and the Shark Euro Pro vacuum. I couldn't find my salvaged Brinkmann pigtails last night when a game vendor friend of mine asked me for one so I trimmed another Shark one that I found at Goodwill a year ago. Threw on some mismatched black heat shrink tubing but switched to black when I found some big enough. Then I took a "GlobTek Inc AC/DC Medical Adapter" 9v 1A DC power supply and unscrewed the casing to remove the original cord... that was also a Goodwill find and struck me as particularly high quality for a 9v PSU, hence it being serviceable with screws with positive and negative were marked inside. I threw the Shark adapter brick on the concrete in my basement to crack the casing open then ripped the wires off the PCB to retain the full length and the strain relief on both ends. The strain relief was much smaller than the original GlobTek but it slotted right in perfectly. I soldered up the wires inside and then tested the polarity with my meter. +9v should be to the right of the key/ridge when looking into the cable end with the ridge oriented up. http://imgur.com/a/GjtPM5W I switched to black heat shrink in the last pic. 1 Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted January 23, 2021 Share Posted January 23, 2021 Okay, in looking and thinking about this long term.. This is basically a JST 2-conductor connector setup. So it should be possible to get such connectors with the male plug side having 90 degree bent terminal leads for soldering into a PCB. Use the female ends off of common adapters that meet the voltage and current specs. It would require having to shave down the female connector so it doesn't try and LOCK into place as they usually do but that would probably work? Wouldn't look as elegant but these connectors are basically the same. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted November 8, 2023 Share Posted November 8, 2023 On 8/1/2019 at 7:24 AM, AlwaysOnPlanetPatrol said: I ordered an AirTV OTA network receiver a few days ago. Arrived yesterday and the first thing that caught my eye was the plug in its (12V) AC adapter. It's a perfect match for the 7800 AC plug (well, except for the clip to hold it on the AirTV). Bit surprised to see this plug on a new device considering that outside of the 7800 I've never seen it elsewhere in all these years. I saw a net bit power supply just like this on Ebay. But my official 7800 supply and atariguide supply are both 9v. So 12v will be too much for the Atari 7800 won't it? And not sure what polarity this is? And 1.5amp is enough? Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted November 8, 2023 Share Posted November 8, 2023 12v is fine because an actual 7800 PSU puts out about 13v without a load and drops down to about 11- 10v into the actual console. The voltage regulator in the system can handle 12v without issue. Just build up a little more heat than usual. The amperage is also fine as the original is only a 1Amp rated output supply. So this one being 1.5A just means it is rated to put out .5A more than the OEM. The console will ONLY draw the amount of Amperage it actually needs. PSUs do not shove the full current to the systems. but... BUT if I'm reading that label right, the polarity on that Net Bit supply is reversed to what goes into the 7800. If looking at their pic on the adapter indicates the polarity on the plug itself, then it is backwards. If it is indicating the polarity with respect to the actual device it plugs into, then it it would be right. But I'm pretty sure that diagram is depicting the plug on the adapter and the polarity is reversed. So...NO you should not use that PSU without modifying the wiring on the PSU to reverse the polarity or somehow modifying the 7800 console. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted November 9, 2023 Share Posted November 9, 2023 (edited) 1 hour ago, -^CrossBow^- said: 12v is fine because an actual 7800 PSU puts out about 13v without a load and drops down to about 11- 10v into the actual console. The voltage regulator in the system can handle 12v without issue. Just build up a little more heat than usual. The amperage is also fine as the original is only a 1Amp rated output supply. So this one being 1.5A just means it is rated to put out .5A more than the OEM. The console will ONLY draw the amount of Amperage it actually needs. PSUs do not shove the full current to the systems. but... BUT if I'm reading that label right, the polarity on that Net Bit supply is reversed to what goes into the 7800. If looking at their pic on the adapter indicates the polarity on the plug itself, then it is backwards. If it is indicating the polarity with respect to the actual device it plugs into, then it it would be right. But I'm pretty sure that diagram is depicting the plug on the adapter and the polarity is reversed. So...NO you should not use that PSU without modifying the wiring on the PSU to reverse the polarity or somehow modifying the 7800 console. Where does it say polarity in the photo there? And this one is + polarity. And what polarity is the 7800 by default? https://www.ebay.com/itm/186067575697?hash=item2b527de391:g:UcoAAOSwFrFk-JtO&amdata=enc%3AAQAIAAAA4FdQNIUc13oLAITp5Lpqwr%2Bdobu16d8D%2BzWFThhsL6oeWhSmsgyVHSukEXdmsYUJgKf67VQRdS9pyrjikj1Tt74Sl01C%2B6ukQB6%2FkIqq8wTYQoKjQOfTzkOccKHJgZAY8gbKXtUvcfomagGiRPl8bLbaKYQ1YE9mNw%2FBcJeNmDzH8Em2ZR5XToab76sXjQXVt03HSbD0CE%2FXxiu%2B41L%2FjQUf0MYYrSVWIFb5%2B0d2Opp%2B4jZFxEAzdpyhW9DfpPi06Vm5Gamxm%2FuaYKfUwBECQRzfPgZ3gKIvbOVytwR%2FKQEo|tkp%3ABk9SR4Tl04z2Yg Edited November 9, 2023 by 0078265317 Quote Link to comment Share on other sites More sharing options...
+wongojack Posted November 9, 2023 Share Posted November 9, 2023 You can test with a meter to determine the polarity. One side is positive and one is negative. If the positive is on the wrong side, you can just cut the cord and re-attach the wires with the correct polarity. Or you could just put that end on any other 9V 1a supply in the correct orientation. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted November 9, 2023 Share Posted November 9, 2023 My meter is broken right now. Don't remember where my other meter is. Quote Link to comment Share on other sites More sharing options...
