0078265317 Posted October 21, 2017 Share Posted October 21, 2017 https://www.ebay.com/itm/used-sears-tele-games-light-6-switch/322839815428 Since the reset switch broke and they are too expensive in my opinion to at 10 dollars on ebay. And no where else am I seeing them. Plus my jr is good enough. So selling this. 1 Quote Link to comment Share on other sites More sharing options...
xucaen Posted October 21, 2017 Share Posted October 21, 2017 Imo the $10 to fix it is worth it. 1 Quote Link to comment Share on other sites More sharing options...
masschamber Posted October 21, 2017 Share Posted October 21, 2017 if you want a reset switch I can send you one for 6 dollars (3 for the switch 3 for shipping) 1 Quote Link to comment Share on other sites More sharing options...
0078265317 Posted October 21, 2017 Author Share Posted October 21, 2017 (edited) I wish I could find a broken switch. All I need is the pole part. But 6 is not bad. I will think about it. What is it called. What do I google for. Is there a part number. Or is it just Atari spring switch. Edited October 21, 2017 by 0078265317 1 Quote Link to comment Share on other sites More sharing options...
masschamber Posted October 21, 2017 Share Posted October 21, 2017 I don't know the name, I think best electronics also has switches but they have a minimum order Quote Link to comment Share on other sites More sharing options...
xucaen Posted October 21, 2017 Share Posted October 21, 2017 Atari 2600 / 2600A Momentary Reset / Select Switch CO10388 $2.50 each http://www.best-electronics-ca.com/2600_Tech_Tips.htm#based 1 Quote Link to comment Share on other sites More sharing options...
0078265317 Posted October 21, 2017 Author Share Posted October 21, 2017 Atari 2600 / 2600A Momentary Reset / Select Switch CO10388 $2.50 each http://www.best-electronics-ca.com/2600_Tech_Tips.htm#based That is great thanks. But never ordered from them before. I see no order button. Quote Link to comment Share on other sites More sharing options...
masschamber Posted October 21, 2017 Share Posted October 21, 2017 That is great thanks. But never ordered from them before. I see no order button. you have to email, only problem is they have a minimum or requirement Quote Link to comment Share on other sites More sharing options...
0078265317 Posted October 23, 2017 Author Share Posted October 23, 2017 I got the following reply. So looks like there is a minimum. Thank you for your E-Mail dated 10-21-17 *****. Q. I need a reset switch. A. The New Atari 2600 Momentary switches are in stock. We do have a Min. Atari order of U$D 20 plus shipping. RegardsBradley Koda Quote Link to comment Share on other sites More sharing options...
masschamber Posted October 26, 2017 Share Posted October 26, 2017 dude you are not going to believe it, I found a spare reset switch stalk/pole/whatever, the bottom half was mangled and I seperated thinking I could use it latter, if you want it all you have to do is cover shipping (like 3 dollars or so) Quote Link to comment Share on other sites More sharing options...
0078265317 Posted November 7, 2017 Author Share Posted November 7, 2017 http://mvvg.blogspot.com/2017/11/sears-telegames-repair.html Took some pictures. Not so good. Masschamber sold me a used stalk for 3 bucks. Came today in the mail. Not so good. I took some photos above link. My original stalk was closed on both sides. As you can see in the last 4 photos the masschamber stalk is open on one side so room for the spring to escape. So far not coming out. But a little slip of the spring after re assembling the switch before putting the whole atatri back together. But not totally slipping out. I tried some electrical tape to hold it in place but it just comes loose. After putting it all back together it looks great. But I am scared the spring might fall out. And it does not work. It powers on. But pulling the reset switch down makes it go down. But I have to manually pull it back up to start space invaders. It does not spring back up automatically. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted November 12, 2017 Author Share Posted November 12, 2017 Updated pictures here. http://mvvg.blogspot.com/2017/11/sears-telegames-repair.html Had another idea. Don't use game select much. So I swapped game select and reset. Now it works and I can play space invaders. Quote Link to comment Share on other sites More sharing options...
