mxpxpxpx Posted October 26, 2017 Share Posted October 26, 2017 Hello, I recently purchased a Mark III that came with 3 controllers. One of them did not work. I took it apart and nothing looks out if the ordinary. I cleaned it and polished the contacts. The only other things I can think of is the cord is bad, the db9 connection is faulty, or I need to resodder the wires on the pc. All the wires are seem to be soddered and not loose. What should my next move be? I was aware the controller was broken when I bought the Mark III. Thanks for all the help. Quote Link to comment Share on other sites More sharing options...
flo3ds Posted October 28, 2017 Share Posted October 28, 2017 Find a datasheet and check your circuit. Quote Link to comment Share on other sites More sharing options...
SignGuy81 Posted October 28, 2017 Share Posted October 28, 2017 Since none of the buttons are working the open is going to be the "common". Unplug the controller, take it apart and check from pin 8 to inside the controller to the common wire, you should have continuity, if not then it is in the cord or plug. If so then follow the trace on the board in the controller for a break or bad solder joint where the wire is soldered to the board. Quote Link to comment Share on other sites More sharing options...
SignGuy81 Posted October 28, 2017 Share Posted October 28, 2017 This should help. https://allpinouts.org/pinouts/connectors/videogame/segamaster-system-sms-and-megadrive-joystick/ The controller plug is the female plug, so go by that diagram to know where pin 8 is where you will be connecting one lead of a multimeter. Then the other lead you will put on common/gnd wire in the controller and check for continuity. Quote Link to comment Share on other sites More sharing options...
