Atari 800 Audio - Line Level?
ckrtech
"I'm sorry; the number you have reached is not in service, or temporarily disconnected. The number you have reached is not in service at this time. This is a recording."
Edited by TheTIGuy
If you mean designed to be in compliance with other
audio devices that use standardized line level inputs
and outputs, then probably not even a consideration
done by Atari. So just attenuate it to your liking
and then it will be. Just guessing here but maybe
try 500 ohm shunt to ground and if still too loud then
lower the ohm rating for the next attempt. Exact ohm
rating won't usually be in decades so just something
close that's available to you would work. 470 ohm for
example would be a fine place to start with.
https://www.amazon.com/Decade-Resistance-Box/dp/B00ALLDB86
One of these decade boxes would help find the proper
resistance a bit faster? I got mine off eBay a long time
ago for a little less but they are not there anymore and
the atlanta-robotics site seems to be offline so there may
be a chance that the cheap way can't even be had anymore.
Resistor substitution box is another search term to
use if this method appeals to you over just pick one
and try it method.
IIRC line level is standardized to be 600 ohm impedance
so 75 ohm attempt by Atari shows the level of detail
that made it to the design board - in other words nada.
They didn't care enough to even look it up. More foggy
recollections 1 V maximum peak to peak at 600 ohms?
Hmm. Interesting.
I have an audio switchbox (homemade) to switch between two inputs (normally two modern computers) as well as two outputs (computer speakers and 64ohm headphones). The Atari seems a bit hot as barely a small increase in volume from 0 results in a rather sudden "appearance" of boomy sound.
So, I figured the Atari output its audio with a bit more oomph - possibly due to the hardware (built-in speakers in a monitor?) of the time.
And that 75 ohm resistor was apparently supposed to be on the main board but isn't if I am properly reading what sup8pdct wrote.
I suppose I could look into generating a tone from the Atari and hook it up to an oscilloscope, etc., etc., (would be my first time messing with sound on a scope, actually)., but I am more likely to throw some resistance at it.
I thought perhaps some of the Atari mod guys might know the proper/relative values offhand.
Hmm. Interesting.
Uh huh (the hell you say, tee he he he)
Can we be sure that the sudden appearance of boom isn't due
to Fletcher Munson curves designed into your rendering
equipment though? Just a possibility I'm throwing in the
air to see if you'll shoot at it or not. In my experience
they shouldn't have made the Fletcher Munson volume control
as set by some arbitrary tap point because it's wrong where
it's placed and it's not adjustable when it needs to be.
Needs both amount of boost applied and where to apply it.
First one is simple, another volume control added, the
second issue will never be as easily solved as the first.
I'm constantly needing to tweak mine depending on the
source and even content, so I assume 'engineers' are
tweaking it before it's even laid down for my consumption
too. The result can then only be crazy making for the
consumer.
Negative on the first one would be my stance, we are
lucky they put in composite video out and I've never
had a religious experience rocking to the tunes on a
color TV that was most of the time the viewer for
Atari back in the day. I do remember the experience
of 'stereo' as implemented by TVs back in the day,
their artificially recreated right channel seemed to
come from about 30 feet away which cause me to holler
at the cat to get off the counter so many times when
the cat was somewhere else entirely. Poor cat had to
live with insane people yelling at her for things she
wasn't doing. No wonder she never paid us much
attention.
Can't know because I'm not him, but I'm assuming he
was thinking about the RF side where audio is
combined with the video signal coming out.
That's a wrong design point issue too, but not this
one. Looking it up myself just now to know what
line level actually is shows several opinions on
the subject with the main takeaway being that it's
not a matched system as RF lines should be, but the
mismatch is there on purpose to maintain fidelity
as the primary issue. Output around 100 ohm, input
around 1K ohm with no spec talked about as to
voltage level but I have seen 1 volt listed on the
back of a Sony minidisc player/recorder for example.
They did mention 600 ohms but that was the first
thing tossed into the hamper after they stuck a knife
into matching lines are required for audio frequencies
deal. Lot of murder and mayhem in general and no small
small amount of conflicting opinions too.
You are the very first by my count to even approach
the Line Level subject from an audiophile's viewpoint.
I would expect the output to vary from machine to machine
so much that you'll need to cook up another matching
network for every one have in your stable too.
I've taken to calling my homemade A-B switch, a
breakout box because it has so many talents. But
they used to be called A-B switches where you only
had two choices of two inputs A or B and a single
output. Mine is still single output but does have
a return loop using the front to back fader so that
I can boost a weak source if need be. Recording jacks
on all inputs with a chicken head four channel selector
on one side and TV input on the other. Has simplified
my life by a vast amount where I used to have to find
and untangle all those lines to hook them up manually.
Jeebus, what a Godsend.
Knowing what I know about it, throwing some resistors
at it is by far the better way to go and don't be
surprised when you need to throw some more at it
later either.
