eegt97 Posted December 18, 2017 Share Posted December 18, 2017 This release contains the following bug fixes and changes: * Added : RetroArch GLSL shader support * Check for shaders here: - https://github.com/libretro/glsl-shaders * Added : Redesigned sound module * -improves sound for many games * -added 48kHz Sound sample frequency * -Improves (fixes?) Linux sound using ALSA * Added : Combo Inputs * Added : User warned when input conficts occur * Added : User can make kat5200 portable * Added : -reset_config command line parameter * Added : Several conversions/homebrews to default database * Changed: -config loads alternate db3 config file * Fixed : Atari 800 Pitfall crash on start (Added LAX CPU op) * Fixed : CPU cycle counts for page crossing * Fixed : Input conflicts on 8-bit computer default profile * Fixed : Atari 800 'A' key updates not loaded * Fixed : Recall state loads incorrect video/input profiles * Fixed : Simualte Analog needs to respect Sensitivity * Fixed : Couple of potential crashes Notes: * Only supporting modern OpenGL, no shaders on Raspberry Pi When obtaining shaders from the RetroArch site above, download the zip and extract somewhere reachable by kat5200 * See Manual for portable use and importing shaders * Check version 0.7.0 for other notes Please see the website for downloads: http://kat5200.jillybunch.com Let me know of any bugs and/or suggestions. Enjoy! -Brian 2 Quote Link to comment Share on other sites More sharing options...
Orionsangel Posted December 21, 2017 Share Posted December 21, 2017 (edited) As someone who grew up with Atari 5200. It's a fantastic emulator! One of my favs. Thank you! Edited December 21, 2017 by Orionsangel Quote Link to comment Share on other sites More sharing options...
ls650 Posted December 21, 2017 Share Posted December 21, 2017 (edited) I agree - a very good emulator. Just installed this on my Win10 laptop and tried a few ROMs; it seems to run great. Edited December 21, 2017 by ls650 Quote Link to comment Share on other sites More sharing options...
Jetboot Jack Posted December 27, 2017 Share Posted December 27, 2017 Awesome - thanks for the update - love this emulator, use it a lot on my Mac! One question -are you aware of an issue with the Caverns of Mars (XL Conversion by Classics) rom - there are 8 black dashes across the screen, this is present in the previous version of the emulator too. The same Rom does into show this visual issue under OpenEmu. sTeVE Quote Link to comment Share on other sites More sharing options...
Orionsangel Posted December 31, 2017 Share Posted December 31, 2017 This emulator has the best TV effect I have ever seen in an emulator. I grew up with CRT TVs and I played Atari 5200 on them. It's very accurate and brings me back to the 80's. Quote Link to comment Share on other sites More sharing options...
eegt97 Posted December 31, 2017 Author Share Posted December 31, 2017 All, thanks for the comments, much appreciated. Jetboot, I was not aware of the issue with Caverns of Mars, I will take a look at that, thanks for letting me know. Also, there is an issue with the database for fresh installs (upgrades are ok). You will get crappy sound and/or it will crash. I am working on a fix for this. In the meantime, if you want to run it, you will have to completely uninstall (including configuration) and install 0.7.1. Run it once. Then you can upgrade to 0.8.0 and it should work. Sorry about the issue. I'll post when the fix is out. -Brian 1 Quote Link to comment Share on other sites More sharing options...
+Trebor Posted December 31, 2017 Share Posted December 31, 2017 Also, there is an issue with the database for fresh installs (upgrades are ok). You will get crappy sound and/or it will crash. I am working on a fix for this. In the meantime, if you want to run it, you will have to completely uninstall (including configuration) and install 0.7.1. Run it once. Then you can upgrade to 0.8.0 and it should work. Sorry about the issue. I'll post when the fix is out. -Brian Just about to post about experiencing both items (Crappy sound and crashing). I was going crazy trying different audio and video settings. Reverted back to an older version and no issues. Looking forward to the fix update. Quote Link to comment Share on other sites More sharing options...
eegt97 Posted January 2, 2018 Author Share Posted January 2, 2018 Just about to post about experiencing both items (Crappy sound and crashing). I was going crazy trying different audio and video settings. Reverted back to an older version and no issues. Looking forward to the fix update. Alright, the fix for this is out, let me know if it does it. Starting new thread on next version... 1 Quote Link to comment Share on other sites More sharing options...
