Sinphaltimus Posted December 27, 2017 Share Posted December 27, 2017 The side port splitter (where the PEB connects). can you connect 2 PEBS at opnce with that and only power on one that you want to use?I ask because with a PEB and a nanoPEB, could I have them both connected via the splitter and only use the PEN (keeping nano powered off) then if I want to use the nano, I won't turn on my peb and only power on the nano.Anyone know or try this before? Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted December 27, 2017 Share Posted December 27, 2017 That particular trick fails, unfortunately. The Nano continues to affect the bus signaling when connected this way. You can connect two standard PEBs, each with a Flex Cable Interface, and all works well as long as no CRUs are duplicated between the PEBs. 1 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted December 28, 2017 Author Share Posted December 28, 2017 Fuey. I suppose I'll just run my nano for now and connect the PEB when I need to do real disk or tape operations. Quote Link to comment Share on other sites More sharing options...
Shift838 Posted January 2, 2018 Share Posted January 2, 2018 I had the same thought around a year ago. I went so far to cut traces on the PEB splitter card and put in a couple of switches to enable/disable lines to see if I could get a Nano and PEB working while both connected (not powered at the same time). I did not have any luck. but I abandoned that project for now. I'm sure it's probably a line that needs to be turned off, just not sure which as of yet. Once figured out maybe a version 2 of the board can be made. 1 Quote Link to comment Share on other sites More sharing options...
sparkdrummer Posted January 2, 2018 Share Posted January 2, 2018 (edited) I went as far as having Jaime reprogram a nanoPEB to dsr 1000 - no luck - did not coexist with a Corcomp MES. Edited January 2, 2018 by sparkdrummer 1 Quote Link to comment Share on other sites More sharing options...
