+TheBF Posted February 24, 2020 Author Share Posted February 24, 2020 I published a video to demonstrate what it's like to use CAMEL99 Forth on Classic99. I am pretty happy with the usability of the system now. Compile times are pretty fast with the changes I made recently. Just need to decide on the best way to make a file editor. https://youtu.be/__PtCJ473Zk Quote Link to comment Share on other sites More sharing options...
+TheBF Posted February 28, 2020 Author Share Posted February 28, 2020 (edited) A good use for Low RAM The way Camel99 Forth is structured the 8K RAM at >2000 is treated as a HEAP. This is just a fancy name for memory that has no specific purpose but can be used by your program as needed. For example when Camel99 Forth kernel reads a file of source code it grabs an 82 byte buffer from the HEAP to read each line of the file into memory. This is done simply by adding 82 to the heap pointer variable "H". When it's finished it restores the heap pointer by subtracting 82 from H. Simple. In this example we use the MALLOC library which makes this feature a little easier to use and it only takes a couple of lines of code. : MALLOC ( n -- addr ) H @ SWAP H +! ; : MFREE ( n -- ) NEGATE H +! ; So the "good use" is to use the HEAP memory space to compile the Forth Assembler and Tools. I made COMPILE-LOW and COMPILE-HI and it seems to work nicely. The method is: Save the current dictionary pointer DP in a temp variable MALLOC a big buffer in the HEAP, move Forth's dictionary pointer to the buffer Compile the tools that you want to use The new position of the dictionary pointer is saved as the HEAP pointer (This marks that memory as not available, but makes the remainder available) Put the Forth dictionary pointer back where it used to be in High RAM. After that we have 15K of program space for our program and about 1/2 the HEAP is used up. \ LOWTOOLS puts ASSEMBLER and tools into LOW RAM Feb 27 2020 BFox NEEDS MALLOC FROM DSK1.MALLOC HEX VARIABLE SAVEDP : COMPILE-LOW ( -- ) HERE SAVEDP ! \ save the dictionary pointer 1E00 MALLOC DP ! \ get a big buffer, DP(dictionary) points to the buffer ; : COMPILE-HI ( -- ) HERE H ! \ give back what we didn't use to the HEAP SAVEDP @ DP ! \ restore DP back to original address ; COMPILE-LOW INCLUDE DSK1.ASM9900 INCLUDE DSK1.TOOLS COMPILE-HI .FREE HEX The thing I need to figure out now is how to re-link the dictionary to remove the tools from the dictionary while still keeping my program. With that feature the assembler could be loaded as needed for compiling a project, but removed from the final program. More thinking required... Edited February 28, 2020 by TheBF typo 2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted February 28, 2020 Share Posted February 28, 2020 21 minutes ago, TheBF said: The thing I need to figure out now is how to re-link the dictionary to remove the tools from the dictionary while still keeping my program. With that feature the assembler could be loaded as needed for compiling a project, but removed from the final program. More thinking required... Would you not copy the link in the first word of the temporary block of words (assembler and/or other tools) to the link in the first program word? This should link the first program word to the last word in the dictionary before the temporary block was compiled. ...lee 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted February 28, 2020 Author Share Posted February 28, 2020 25 minutes ago, Lee Stewart said: Would you not copy the link in the first word of the temporary block of words (assembler and/or other tools) to the link in the first program word? This should link the first program word to the last word in the dictionary before the temporary block was compiled. ...lee That sounds correct. I need to make a picture to see it clearly in my head. I think I can use LATEST to get the links before I start compiling the temporary code and then again when I return to high memory. I will have to create some more temp variables to remember those things I guess. My old HsForth system has the words PERMANENT and TRANSIENT which are nice sounding. Any thoughts on naming? Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted February 28, 2020 Share Posted February 28, 2020 You are not using vocabularies, are you? ...lee Quote Link to comment Share on other sites More sharing options...
+TheBF Posted February 28, 2020 Author Share Posted February 28, 2020 33 minutes ago, Lee Stewart said: You are not using vocabularies, are you? ...lee No. So it's a little less complicated in that way. Quote Link to comment Share on other sites More sharing options...
+TheBF Posted February 28, 2020 Author Share Posted February 28, 2020 So this works ... mostly \ RELINK VARIABLE TRANSLINK : TRANSIENT ( -- ) LATEST @ TRANSLINK ! ; : RELINK ( -- ) TRANSLINK @ LATEST @ NFA>LFA ! ; But if I say: : WORD1 ; TRANSIENT : WORD2 ; : WORD3 ; : WORD4 ; RELINK I still see WORD4 in the dictionary. 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted February 29, 2020 Share Posted February 29, 2020 I know in Camel99 Forth that you tick a word to get its execution token (xt). Can you then get the label field address (lfa) from the xt as can be done in fbForth through the parameter field address (pfa)? If so, the word that begins the permanent block (PROGRAM, say) could be ticked by a redefined RELINK to place TRANSLINK’s contents into PROGRAM’s lfa: RELINK PROGRAM ...lee Quote Link to comment Share on other sites More sharing options...
+TheBF Posted February 29, 2020 Author Share Posted February 29, 2020 I just sat back at the machine 5 minutes ago. I think I understand what you are getting at and it can be done. However for conversation, this is one of the weaknesses of the Camel Forth Header. *translation layer: Fig LFA = Camel Forth NFA Here is structure. \ D7 D0 \ +---------------+ \ | | byte 1 \ LINK FLD contains NFA of previous word \ |- link -| \ | | byte 2 \ +-------------+-+ \ | 0 |P| byte 3 \ P - Precedence bit, equals 1 for an IMMEDIATE word \ +-+-----------+-+ \ |S| length | byte 4 \ S - Smudge bit, used to prevent FIND from finding this word. \ +-+-------------+ \ | | byte 5 \ |- name -| \ | | ... to byte N \ ~~~~~~~~~~~~~~~~~ \ | | byte n+1 \ |- code field -| \ | | \ +---------------+ \ You can get from the name field to the link easily. You can get from the link field to the name easily. You can get from the name field to the code field easily. Getting from the code field back to the name field is awkward because it is a variable length. I made a way to do it but it is a loop that reads backwards looking for the precedence field. I mask off bit 1 and look for the zero. It works but its ugly. (to me) The real solution is something they have discussed in comp.lang.forth called FIND-NAME. I wrote one today in the hopes of adding FORGET. 30 MALLOC CONSTANT TEMP$ : FIND-NAME ( addr len -- nfa ) \ 4.4x SLOWER than ASM (FIND) TEMP$ PLACE LATEST @ BEGIN DUP 1+ TEMP$ COUNT S= 0= IF EXIT THEN NFA>LFA @ DUP WHILE REPEAT ; I It's not pretty with the TEMP$ but it works. I need to re-work it to use R stack but I need a 2R@ to do it nicely. (BTW I noticed that FORGET has made it back into the new "kind of a standard" Forth 2012. I always liked that word. Much cooler than MARKER._ I fixed the problem in my first RELINK test just now. I forgot to re-adjust LATEST to point to the new beginning of the linked list. : RELINK ( -- ) TRANSLINK @ DUP LATEST @ NFA>LFA ! LATEST ! ; So I have successfully RELINKed that simple example. It's a beginning. Thanks for the discussion. I really appreciate it. 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted February 29, 2020 Author Share Posted February 29, 2020 I fixed FIND-NAME so it doesn't need a buffer. It scans through 378 words in 0.26 seconds. S= ( addr addr len -- -1|0|1 ) is a string comparison code word in Camel Forth. Combined with the learning in RELINK, I should be able to use this to make FORGET. \ : 2OVER 3 PICK 3 PICK ; ( faster inline) : FIND-NAME ( addr len -- nfa ) LATEST @ BEGIN DUP 1+ 3 PICK 3 PICK S= 0= IF NIP NIP EXIT THEN NFA>LFA @ DUP 0= UNTIL NIP NIP ; Quote Link to comment Share on other sites More sharing options...
+TheBF Posted February 29, 2020 Author Share Posted February 29, 2020 (edited) It was easier than I thought to make FORGET. I factored out some things differently for clarity if I ever come back to this and the new words are useful in their own right. \ FORGET erase dictionary up a given word NEEDS S= FROM DSK1.COMPARE : 2OVER ( a b c d -- a b c d a b) 3 PICK 3 PICK ; : 2NIP ( a b c -- c) NIP NIP ; : FIND-NAME ( addr len -- nfa ) \ nfa is "name field address" LATEST @ BEGIN DUP 1+ 2OVER S= 0= IF 2NIP EXIT THEN NFA>LFA @ ( next name in dictionary) DUP 0= UNTIL 2NIP ; : FORGET ( <text> ) BL WORD COUNT FIND-NAME DUP 0= ?ERR DUP NFA>LFA DUP @ LATEST ! \ relink the words ( lfa ) DP ! ; \ recover the memory EDIT: Added line in FORGET to recover dictionary space. Removed NEXTNAME as a word. It was not useful enough. That's enough for tonight. Edited February 29, 2020 by TheBF 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted February 29, 2020 Share Posted February 29, 2020 Why do you need to define FIND-NAME ? Do you not have ' and ['] to find names starting with LATEST ? Once you get the execution token, then traverse the name backwards to the precedence bit and correct to the nfa. H-m-m-m... Maybe, instead, you should redefine ' and ['] in terms of FIND-NAME . But, I digress... ...lee Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 1, 2020 Author Share Posted March 1, 2020 This is so weird. Your message came in 5 minutes after I sat down here. Are you watching me? ? You are correct. I made a word called CFA>NFA the scans backwards in the header to get to the precedence bit and then adds 1. I may give that a go as well. BTW in your wisdom you have succinctly summarized endless discussions in various fora on FIND and how it needs be replaced with FIND-NAME because FIND-NAME is a better factor with which to build FIND. And FIND-NAME does not have to copy the string to HERE before it's interpreted so it is more efficient ... yada yada yada. I just made re-linking work manually and it is pretty simple as we thought. I just need to give things names and I will put it up shortly for your perusal. ( I wanted an excuse to make FIND-NAME and then code in assembler as a factor for FIND. But your suggestion of simply using tick and counting backwards is probably just a good. Luckily I don't get paid for doing this. ) 1 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 1, 2020 Author Share Posted March 1, 2020 (edited) FORGET is definitely smaller this way. \ FORGET erase dictionary up a given word : CFA>NFA ( cfa -- nfa | 0 ) 2- BEGIN 1- DUP C@ 0FE AND 0= UNTIL 1+ ; : FORGET ' CFA>NFA NFA>LFA DUP @ ( nfa) LATEST ! ( lfa ) DP ! ; Edited March 3, 2020 by TheBF Removed extra DUP in FORGET 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 1, 2020 Share Posted March 1, 2020 I do not know whether you really need it, but figForth (I think it harks back that far) used the user variable FENCE to hold the address of the last word that cannot be forgotten, i.e., it would only allow words between the address in FENCE and HERE to be forgotten by FORGET . The default for FENCE is the last word in the kernel. TI Forth and fbForth will not allow any part of the kernel to be forgotten regardless of the value in FENCE . ...lee Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 1, 2020 Author Share Posted March 1, 2020 3 minutes ago, Lee Stewart said: I do not know whether you really need it, but figForth (I think it harks back that far) used the user variable FENCE to hold the address of the last word that cannot be forgotten, i.e., it would only allow words between the address in FENCE and HERE to be forgotten by FORGET . The default for FENCE is the last word in the kernel. TI Forth and fbForth will not allow any part of the kernel to be forgotten regardless of the value in FENCE . ...lee I remember that and I will have been cogitating on it as well. Working code coming shortly for the re-linking. Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 1, 2020 Author Share Posted March 1, 2020 (edited) So this works but I had to change the kernel slightly. Like FbForth and PAD I have been using this HEAP idea alot just to kick the tires. I put the scroll buffer in a "heap-pad" ie: un-allocated memory in low RAM. But... I also was allocating and de-allocating a buffer for INCLUDED in the kernel that loads source code. The fix for this low ram compiling was to lock down the line buffer for INCLUDED so my heap now starts at >2050. Therefore this code will not work in v2.5 only this new one I have not released yet. But it was as simple as you said once I understood what was where. \ LOWTOOLS puts ASSEMBLER and tools into LOW RAM Feb 27 2020 BFox NEEDS MALLOC FROM DSK1.MALLOC HEX VARIABLE SAVEDP LATEST @ CONSTANT KEEP \ remember latest name field address \ set up low ram compiling ............. HERE SAVEDP ! \ save the dictionary pointer. 1E00 MALLOC DP ! \ get a big buffer, dictionary points to the buffer \ ======================================================================= \ *INSIGHT* \ SAVEDP holds the LINK field of the 1st new word we will create in HI RAM \ ======================================================================= INCLUDE DSK1.TOOLS INCLUDE DSK1.ASM9900 : REMOVE-TOOLS ( -- ) KEEP SAVEDP @ ! \ relink the dictionary 2050 H ! ; \ init-the heap. (80 byte buffer is at >2000) \ setup hi ram compiling .............. HERE H ! \ give back what we didn't use to the HEAP SAVEDP @ DP ! \ restore DP back to original address \ test words will remain in dictionary after REMOVE-TOOLS : WORD1 ." word1" ; : WORD2 ." word2" ; : WORD3 ." word3" ; : WORD4 ." word4" ; .FREE HEX Edited March 1, 2020 by TheBF typos Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 1, 2020 Share Posted March 1, 2020 That is very cool—except for that one time you decide to compile something other than a word definition as the first item in high memory. That is why I suggested ticking the first word in which to patch the lfa. Of course, you could install a no-op marker word as the first item of business for the new program. ...lee Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 1, 2020 Share Posted March 1, 2020 5 minutes ago, Lee Stewart said: That is why I suggested ticking the first word in which to patch the lfa. Actually, I should not take credit for that much insight. I did not think of that reason until after I figured out what you were doing in the “relink the dictionary” line of REMOVE-TOOLS . ...lee Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 1, 2020 Author Share Posted March 1, 2020 Ya I was considering how I could make a word that compiles a word when executed for that purpose. I think I can do it, but I came out of the basement to spend some time with my wife. Higher callings. Thanks again for the support. 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 1, 2020 Author Share Posted March 1, 2020 Ok so at the risk of sounding stupider than I already do... I can't think of what I could compile after I do a REMOVE-TOOLS that would make a problem except maybe trying to compile raw numbers with no CREATE <word> first, which I would never do, like this: DEAD , BEEF , Every other thing is built on the word HEADER like this: \ ======================================================================== \ D I C T I O N A R Y C R E A T I O N : HEADER, ( addr len --) ALIGN LATEST @ , 0 C, HERE LATEST ! S, ; : HEADER BL PARSE-WORD HEADER, ; \ ======================================================================== \ T A R G E T S Y S T E M D E F I N I N G W O R D S \ text runtime-action parameter \ ------------------------- --------------- ----------- : CONSTANT ( n --) HEADER COMPILE DOCON COMPILE, ; : USER ( n --) HEADER COMPILE DOUSER COMPILE, ; : CREATE ( -- ) HEADER COMPILE DOVAR ; : VARIABLE ( -- ) CREATE 0 COMPILE, ; And even ':' is defined with HEADER X: : !CSP HEADER (:NONAME) ;X So in every case the new link field will be at the high RAM address and will be stuffed with the contents of LATEST to hook the new word into the linked list. What am I missing? I am reminded of Desi Arnez in I Love Lucy. "You got some 'splainin' to do" Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 1, 2020 Share Posted March 1, 2020 3 hours ago, TheBF said: Ok so at the risk of sounding stupider than I already do... Ridiculous! 3 hours ago, TheBF said: So in every case the new link field will be at the high RAM address and will be stuffed with the contents of LATEST to hook the new word into the linked list. What am I missing? I am reminded of Desi Arnez in I Love Lucy. "You got some 'splainin' to do" Exactly what you would never do I have done quite often in fbForth with DATA[ ... ]DATA , a construct you probably do not have in Camel99 Forth. It uses up dictionary space and leaves its address and cell count on the stack. If I were to adapt REMOVE-TOOLS to fbForth, I would likely need to install that initial dummy word. ...lee Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 1, 2020 Author Share Posted March 1, 2020 51 minutes ago, Lee Stewart said: Ridiculous! Exactly what you would never do I have done quite often in fbForth with DATA[ ... ]DATA , a construct you probably do not have in Camel99 Forth. It uses up dictionary space and leaves its address and cell count on the stack. If I were to adapt REMOVE-TOOLS to fbForth, I would likely need to install that initial dummy word. ...lee Ah yes. That makes sense now. I have been noodling on perhaps using the HEADER, word to make a dummy word as part of REMOVE tools. It would need to have a way to EXIT right back to Forth. But just adding a dummy word manually in the file would be just as easy since I plan to INCLUDE DSK1.LOWTOOLS as a "package". 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 1, 2020 Share Posted March 1, 2020 4 hours ago, TheBF said: Ah yes. That makes sense now. I have been noodling on perhaps using the HEADER, word to make a dummy word as part of REMOVE tools. It would need to have a way to EXIT right back to Forth. But just adding a dummy word manually in the file would be just as easy since I plan to INCLUDE DSK1.LOWTOOLS as a "package". Yeah—perhaps a one-character word using an unused character like ‘~’ or ‘`’ would take up the least space: : ` ; \ dummy starting word ...lee 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 2, 2020 Author Share Posted March 2, 2020 All this work has also given me the tools to make a word from HsForth called BEHEAD. It allows you to compile a bunch of code and then remove the names of some of the words so that they can't be seen. Not something I urgently need but I know how to do it now. The other feature I have used in MaxForth was the word names could be compiled in a separate part of memory so you could strip them all away when the project was finished. This made the EPROM image as much as 30% smaller. That would be a cool one if I also develop a save to EA/5 image to go with it. You could build some very tight programs in Forth that way. Probably as small as ALC. Some much code so little time... 1 Quote Link to comment Share on other sites More sharing options...
