GDMike Posted March 23, 2022 Share Posted March 23, 2022 That area >6000 sure comes in handy! 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 29, 2022 Author Share Posted March 29, 2022 Sometimes I wonder why I ever thought I could make my own tools. I finally re-organized my source code with a new "make" file that is written in Forth that creates a normal RAM version and a SuperCart version. There is a weird gremlin that I have not actually caught yet that sometimes causes my builds to not interpret the DSK1.START file when the kernel boots on hardware. ??? I just found a couple of missing compiler directives in a file so maybe I was compiling code for the wrong Forth system into the image. (That's a guess right now) Anyway this one builds and loads and runs on real iron. Edit: I believe this "gremlin" was caused by making RAKE immediate in my DO LOOP code. Time will tell. It's easier to understand the order of things without all the source code in the way. Here is what it takes to make Camel99 Forth for the many thousands that are dying to know. ITCTYPES.HSF extends the compiler to understand how to compile indirect threaded dictionary headers for variable, constants, colon words etc. Then load the Forth primitive words, written in Forth Assembler. These are the backbone of the system. At this stage the compiler does not know how to do FORTH looping and branching because it needed a couple of those primitives, so we compile BOOTSTRX.HSF These words do not run on TI-99. They just work in the compiler so we can build the rest of the system. We "bootstrap" the compiler so to speak. Compile the TI-99 specific I/O primitives, which are also Forth Assembler word Finally compile the CORE ANS Forth words plus the screen and keyboard words. Inside HILEVEL.HSF there are a few other includes: TICKTOCK.HSF 9901 timer words DSRLINKA.HSF dsrlink word of course FILESYX2.HSF file system primitives (just enough to extend the system later) And finally we add ISOLOOPS.HSF which teach the TI-99 Forth how to do IF ELSE THEN BEGIN UNTIL etc. It's a primitive compiler so once the compiling is done we use the compiler's Forth interpreter to patch some important addresses in the target memory image. Then we save the the image as an EA5 program. I also realized, after all this time, that I was not doing a full "COLD" boot of the system when you typed COLD. That's fixed and will be in the next release. Spoiler \ MAKE CAMEL99 ITC Forth Mar 2022 B Fox CROSS-COMPILING \ ********************************************************************** \ compiler switches control HOW the system will be built \ ********************************************************************** TRUE VALUE ITC \ used to prevent directly compiling HILEVEL.HSF FALSE VALUE SLOWER \ TRUE saves 28 bytes FALSE VALUE HASHING \ Not working yet TRUE \ true= standard kernel ; false=non-standard kernel [IF] A000 VALUE KERNORG 2000 VALUE HEAPORG [ELSE] 6000 VALUE KERNORG \ the specific alternate load address to use 2000 VALUE HEAPORG \ initial HEAP address when kernel boots [THEN] \ ******************************************************************* \ Cross-compiler extensions, load threading mechanism words [CC] INCLUDE CC9900\SRC.ITC\ITCTYPES.HSF \ CROSS-Compiler Extensions \ ******************************************************************* \ Make Forth kernel [CC] INCLUDE CC9900\SRC.ITC\9900CODE.HSF \ ASM primitives for TMS9900 [CC] INCLUDE CC9900\SRC.ITC\BOOTSTRX.HSF \ cross-compiler looping & branching [CC] INCLUDE CC9900\SRC.ITC\TI99IO.HSF \ VDP primitives & KEY [CC] INCLUDE CC9900\SRC.ITC\HILEVEL.HSF \ CORE Forth words \ ====================================================================== \ P A T C H T H E T A R G E T S Y S T E M V A R I A B L E S [CC] XLATEST @ DUP LATEST T! ORGLAST T! ( align TARGET dictionary to compiler) T' CAMEL99 BOOT T! ( set the boot word to run ) KERNORG A000 <> [IF] THERE DP T! HEX A000 ORGDP T! ( SUPERCART must start dictionary in HI RAM ) [ELSE] THERE 2+ DUP DP T! ORGDP T! [THEN] \ ====================================================================== \ P A T C H T A R G E T I M A G E F I L E H E A D E R T' COLD >BODY BOOT-ADDRESS T! [CC] KERNORG A000 <> [IF] FILENAME: CAML99SC [ELSE] FILENAME: CAMEL99 [THEN] END. ( report compile time and stats) \ ====================================================================== \ S A V E B I N A R Y I M A G E F I L E FILENAME$ $SAVE-EA5. ( FILENAME$ was set by FILENAME: ) \ ====================================================================== \ C O P Y T O T I - 9 9 V I R T U A L D I S K .( copying binary file to TI-99 Emulator DSK1.) \ build the copy command in host Forth PAD memory by appending strings S" COPY " PAD PLACE FILENAME$ COUNT PAD +PLACE S" cc9900\CAMEL99.WIP\dsk1.itc\" PAD +PLACE CR PAD COUNT 2DUP TYPE SYSTEM \ SYSTEM calls DOS, gives it the string CROSS-COMPILING CR ." === COMPILE ENDED PROPERLY ===" QUIT \ BYE ( un-comment this to return to DOS) 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 2, 2022 Author Share Posted April 2, 2022 Sometimes it's interesting to compare our favourite computer to other machines of similar power. I found this Forth benchmark website with posts made on many different machines. The ultimate Forth Benchmark (theultimatebenchmark.org) Here are some of the benchmark programs written in Camel99 Forth with results from other machines with similar vintage or clock frequency. It's interesting to me that on some benchmarks TI-99 indirect threaded Forth is beating 6502 sub-routine threaded Forth. It also looks like the 63C09 is very efficient at running Forth. Spoiler \ 12.16 Deliano \ Ein Benchmark für 8bit Mikrocontroller, angeregt in Vierte Dimension 03/93 \ von Rafael Deliano \ A-ONE (Apple 1 Clone) mit 65C02 TaliForth 2 (STC) Deliano 0:29.0 1x \ Z79Forth (Hitachi HD63C09 3 Mhz) Deliano 7:53.0 50x \ = 0:09.46 1x \ TI-99 Camel99 Forth (ITC) Deliano 0:26.5 1x HEX 5 CONSTANT FIVE 0 VARIABLE BVAR : BENCH 100 0 DO 1 BEGIN DUP SWAP DUP ROT DROP 1 AND IF FIVE + ELSE 1- THEN BVAR ! BVAR @ DUP 0100 AND UNTIL DROP LOOP ; Spoiler \ Ultimate Forth Benchmark web site \ C64 DurexForth 1.6.1 (STC) Sieve/Prime 0:10.00 1x \ C64 6510 Audiogenic Forth-64 Sieve Bench 0:18.10 1x \ Amstrad 6128+ Z80A 4Mhz Uniforth Sieve Bench 0:12.00 1x \ TI99 Camel99 Forth (ITC) Sieve/Prime 0:12:53 1x \ [BENCHMARK] Glibreath's fixed algorithm: \ Eratosthenes' sieve from ORNL/TM10656 (Martin Marietta). INCLUDE DSK1.ELAPSE \ Camel99 doesn't have <= : <= S" 1- <" EVALUATE ; IMMEDIATE DECIMAL 8190 CONSTANT SIZE VARIABLE FLAGS SIZE 1+ ALLOT : DO-PRIME FLAGS SIZE 1+ 1 FILL 0 SIZE 0 DO FLAGS I + C@ IF I DUP + 3 + DUP I + BEGIN DUP SIZE <= WHILE 0 OVER FLAGS + C! OVER + REPEAT DROP DROP 1+ THEN LOOP DROP ; \ ELAPSE DO-PRIME Spoiler \ for camel99 Forth \ Amstrad 6128+ Z80A 4Mhz Uniforth Nesting 1Mil 3:26 \ ZX Spectrum 2+ FIG-Forth 1.1a Nesting 1Mil 3:15 \ C64 (normal) Forth64 Nesting 1Mil 6:20 \ PDP11 FIG-Forth 1.3 Nesting 1Mil 0:49 \ TI99 Camel99 Forth Nesting 1Mil 2:30 INCLUDE DSK1.ELAPSE DECIMAL : BOTTOM ; : 1ST BOTTOM BOTTOM ; : 2ND 1ST 1ST ; : 3RD 2ND 2ND ; : 4TH 3RD 3RD ; : 5TH 4TH 4TH ; : 6TH 5TH 5TH ; : 7TH 6TH 6TH ; : 8TH 7TH 7TH ; : 9TH 8TH 8TH ; : 10TH 9TH 9TH ; : 11TH 10TH 10TH ; : 12TH 11TH 11TH ; : 13TH 12TH 12TH ; : 14TH 13TH 13TH ; : 15TH 14TH 14TH ; : 16TH 15TH 15TH ; : 17TH 16TH 16TH ; : 18TH 17TH 17TH ; : 19TH 18TH 18TH ; : 20TH 19TH 19TH ; : 21TH 20TH 20TH ; : 22TH 21TH 21TH ; : 23TH 22TH 22TH ; : 24TH 23TH 23TH ; : 25TH 24TH 24TH ; DECIMAL : 1MILLION CR ." 1 million nest/unnest operations" 20th ; \ ELAPSE 1MILLION Spoiler \ Amstrad NC100 Z80 4.606Mhz VolksForth CP/M (ITC) Integer Calc 0:06.23 \ 8086 5Mhz Laxen/Perry F83 Integer Calc 0:09.0 \ C64 DurexForth 1.6.1 (STC) Integer Calc 0:37.0 \ Rockwell R1200-14, 2Mhz 65F12 RSC-Forth Integer Calc 0:31.0 \ Amstrad 6128+ Z80A 4Mhz Uniforth Integer Calc 0:17.0 \ TI99 Camel99 Forth (ITC) Integer Calc 0:14.7 \ MSP430FR5739, 8Mhz CamelForth Integer Calc 100x 02'45':10 \ Scaled to 1X 0:01.65 INCLUDE DSK1.ELAPSE DECIMAL 32000 CONSTANT INTMAX VARIABLE INTRESULT : DOINT 1 DUP INTRESULT DUP >R ! BEGIN DUP INTMAX < WHILE DUP NEGATE R@ +! 1+ DUP R@ +! 1+ R@ @ OVER * R@ ! 1+ R@ @ OVER / R@ ! 1+ REPEAT R> DROP DROP ; \ ELAPSE DOINT Spoiler \ Yodabashi Formula 1 Z80 4Mhz VolksForth CP/M (ITC) Takeuchi 0:46.0 200X \ Hitachi HD63C09 3 Mhz Z79Forth Takeuchi 0:55.0 200X \ TI99 3.3Mhz Camel99 Forth (ITC) Takeuchi 2:07.2 200x INCLUDE DSK1.ELAPSE DECIMAL : 3DUP 2 PICK 2 PICK 2 PICK ; : TAK ( X Y Z -- T ) OVER 3 PICK < NEGATE IF NIP NIP EXIT THEN 3DUP ROT 1- -ROT RECURSE >R 3DUP SWAP 1- -ROT SWAP RECURSE >R 1- -ROT RECURSE R> SWAP R> -ROT RECURSE ; : TAKBENCH ( -- ) 0 1000 0 DO DROP 18 12 6 TAK LOOP DROP ; : 200X 200 0 DO TAKBENCH LOOP ; \ ELAPSE 200X 4 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 4, 2022 Author Share Posted April 4, 2022 While reading comp.lang.forth this morning there was a link to Forth site I had never seen. I was aware of Leo Wong and some of his program postings from years ago. This page has a very nicely made tutorial for those inclined to learn some Forth. Simple Forth (murphywong.net) I also found this word to make text macros which does some things I had never considered. (I shouldn't be too shocked it was written by the late Wil Baden a Forth Guru) Passes the delimiting character argument to PARSE in interpret mode Defines words that make themselves immediate And... it forced me to figure out how to define SLITERAL which is a word I avoided up until now. SLITERAL - STRING (forth-standard.org) : SLITERAL ( ca u --) \ Not in Camel99 Forth kernel POSTPONE (S") S, ; IMMEDIATE : MACRO \ BY WIL BADEN : CHAR PARSE POSTPONE SLITERAL POSTPONE EVALUATE POSTPONE ; IMMEDIATE ; And with MACRO Leo then defines a FOR NEXT loop word set like this: \ Leo Wong 21 June 02004 02003 fyj + \ fexit fleave for next MACRO FOR " ( +U -- ) BEGIN ?DUP WHILE 1- >R" MACRO NEXT " ( -- ) R> REPEAT" MACRO FEXIT " ( -- ) R> DROP EXIT" MACRO FLEAVE " ( -- ) R> DROP 0 >R" Pretty slick. You use R@ to get the loop index. 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted April 5, 2022 Share Posted April 5, 2022 16 hours ago, TheBF said: I also found this word [ SLITERAL ] to make text macros which does some things I had never considered. (I shouldn't be too shocked it was written by the late Wil Baden a Forth Guru) Passes the delimiting character argument to PARSE in interpret mode A similar word, WLITERAL , exists in fbForth (inherited and modified from TI Forth), except that it leaves the address of a packed (counted) string on the stack: fbForth definitions follow in the spoiler: Spoiler : SLIT ( --- addr ) R> DUP C@ 1+ =CELLS OVER + >R ; : WLITERAL ( --- [] | [addr] ) ( IS: <blank-delimited string>) BL STATE @ IF COMPILE SLIT TOKEN ELSE TOKEN THEN ; IMMEDIATE ...lee 2 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 5, 2022 Author Share Posted April 5, 2022 16 minutes ago, Lee Stewart said: A similar word, WLITERAL , exists in fbForth (inherited and modified from TI Forth), except that it leaves the address of a packed (counted) string on the stack: fbForth definitions follow in the spoiler: Hide contents : SLIT ( --- addr ) R> DUP C@ 1+ =CELLS OVER + >R ; : WLITERAL ( --- [] | [addr] ) ( IS: <blank-delimited string>) BL STATE @ IF COMPILE SLIT TOKEN ELSE TOKEN THEN ; IMMEDIATE ...lee Cool. The definition of (S") is like SLIT but modified to return a stack string pair. The name is probably not ideal since it now has more uses than just in S". : (S") ( -- c-addr u) R> COUNT 2DUP + ALIGNED >R ; And S, looks like this : S, ( c-addr u -- ) HERE OVER 1+ ALLOT PLACE ALIGN ; It's interesting how many different ways you can slice these things up. I remember it took me a while to get how the heck these things worked. I can't remember now how much of this is stock Camel Forth and where I changed things based on ideas I saw in other Forth systems. 2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted April 5, 2022 Share Posted April 5, 2022 1 minute ago, TheBF said: I remember it took me a while to get how the heck these things worked. You and me both! ...lee 2 1 Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted April 5, 2022 Share Posted April 5, 2022 I second that emotion! Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 7, 2022 Author Share Posted April 7, 2022 After looking at Rich's RXB 2022 Demo and the amazing speed he is getting out of his BASIC for HCHAR and VCHAR I had to see if the Camel could run with the big dog. So I wrote the demo code and promptly discovered my HCHAR and VCHAR were not properly protected. Fortunately with micro kernel, a sloppy programmer (who shall remain nameless), can fix the external code library relatively easily. Anyway here is the result. My VCHAR is pretty slow because it is mostly Forth with a tiny wrap word written in CODE and that can be seen clearly. Since Rich's BASIC program used ONGOSUB I added one to Forth. \ 100 REM Randomize and RND test from RXB 2022 \ 110 RANDOMIZE \ 120 ON INT(RND*2)+1 GOSUB 1000,1100 \ 130 GOTO 120 \ 1000 CALL HCHAR(INT(RND*24+1),INT(RND*32+1),INT(RND*255),INT(RND*767)+1):: RETURN \ 1100 CALL VCHAR(INT(RND*24+1),INT(RND*32+1),INT(RND*255),INT(RND*767)+1):: RETURN INCLUDE DSK1.GRAFIX INCLUDE DSK1.RANDOM INCLUDE DSK1.FASTCASE DECIMAL : RNDCOL 31 RND ; : RNDROW 23 RND ; : RNDCHAR 255 RND ; : RNDSIZE C/SCR @ 1- RND 1+ ; CASE: ONGOSUB | HCHAR | VCHAR ;CASE \ :-) couldn't resist : RUN CLEAR RANDOMIZE BEGIN RNDCOL RNDROW RNDCHAR RNDSIZE 2 RND ONGOSUB ?TERMINAL UNTIL ; Here are the revised HCHAR and VCHAR Spoiler : HCHAR ( col row char cnt -- ) \ *new* added automatic size protection 2SWAP >VPOS ( -- char cnt vdp1) DUP>R ( -- char cnt vdp1) ( r: vdp1) OVER + ( -- char cnt vdp_end) C/SCR @ 1- - 0 MAX - ( char cnt' ) R> -ROT SWAP VFILL ; HEX CODE VWRAP \ 4x faster than Forth 02A1 , \ R1 STWP, 0202 , C/SCR @ 1- , \ R2 C/SCR @ 1- LI, A121 , 002E , \ 2E R1 () TOS ADD, ( C/L@ TOS + ) 8084 , \ TOS R2 CMP, 1201 , \ HI IF, 6102 , \ R2 TOS SUB, \ ENDIF, NEXT, ENDCODE : VCHAR ( col row char cnt --) 2SWAP >VPOS 1 MAX SWAP 0 DO 2DUP VC! VWRAP LOOP 2DROP ; RNDWORKOUT.mp4 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 15, 2022 Author Share Posted April 15, 2022 Over here @apersson850 mentioned making the cursor the inverted character on the screen. I had wondered about that but was always fighting with other bugs. I thought I would try dropping it into the repeating key code and it works. I was able to make the pattern copy pretty quick by copying 2 VDP bytes at once with V@ and since I had a full 16 bits INVERT makes quick work of the inversion process. There was a BLINK routine in the RKEY code that becomes the "key" (pun intended) to making this work. Where before if the 9901 time was in the upper range, it simply replace the input char (from the screen) with the cursor char, now it copies the screen char's pattern over into the cursor char's pattern and inverts that pattern and then puts the cursor char on the screen : BLINK ( char -- ) TMR@ 1FFF > \ test 9901 timer IF ]PDT PAT-BUFFER 8 VREAD \ char pattern -> RAM buffer PAT-BUFFER CURS @ ]PDT 8 VWRITE \ copy buffer cursor pattern CURS @ DUP INVERT-CHAR \ invert cursor pattern THEN VPUT ; \ put char on the screen The only other wrinkle was to select a new cursor character so that you don't mess up the pattern of the ones you like to keep. Full source with test routine below Spoiler \ Repeating key based on Nouspikel TI-99 tech pages heavily modified Brian Fox \ Apr 2002 Experimental verison with inverted char cursor \ INCLUDE DSK1.TOOLS INCLUDE DSK1.BUFFER HERE DECIMAL VARIABLE OUTKEY \ key buffer VARIABLE OLDKEY \ previous key buffer CREATE RPT 10 , \ initial delay VARIABLE SCHAR \ screen character VARIABLE INVERTED 8 BUFFER: PAT-BUFFER HEX : ]PDT ( char -- Vaddr) 8* 800 + ; \ pattern descriptor array : INVERT-CHAR ( char --) ]PDT 8 BOUNDS ( -- Vaddr-end Vaddr-start ) DO I V@ INVERT I V! \ read 16bit VDP data, invert, store back to VDP 2 +LOOP ; : BLINK ( char -- ) TMR@ 1FFF > \ test 9901 timer IF ]PDT PAT-BUFFER 8 VREAD \ char pattern -> RAM buffer PAT-BUFFER CURS @ ]PDT 8 VWRITE \ copy buffer cursor pattern CURS @ DUP INVERT-CHAR \ invert cursor pattern THEN VPUT ; \ put char on the screen : RKEY? ( -- char) SCHAR @ BLINK RPT @ >R \ delay counter to rstack BEGIN R> 1- DUP>R \ dec counter WHILE ( not expired) 83C8 ON 83CA ON \ clear key buffers 700 TICKS \ sets the speed of the loop KEY? DUP OUTKEY ! OLDKEY @ = \ compare to oldkey WHILE ( key is same) 2 RPT ! \ set fast repeats REPEAT 0A RPT ! \ set long delay (initial delay) THEN \ end time expired loop R> DROP OUTKEY @ DUP OLDKEY ! OUTKEY OFF ; : RKEY ( -- char) VPOS VC@ SCHAR ! BEGIN RKEY? DUP 0= WHILE PAUSE DROP REPEAT SCHAR @ VPUT ; HERE SWAP - DECIMAL SPACE . HEX : TEST 001B CURS ! \ unused character for the cursor BEGIN RKEY EMIT ?TERMINAL UNTIL 5F CURS ! ; \ Restore underline cursor InvertCharCursorTest.mp4 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted April 16, 2022 Share Posted April 16, 2022 Here's a link to the Programbiten newsletter from 1985, where my implementation of an adaptable cursor was published. Look at page 25. There you'll see the DEF FLIP, NOFLIP command. These two procedures enable and disable the adaptable cursor under Extended BASIC. Note that due to the daisy wheel on the printer, a command like CLR @THIS is printed as CLR 'THIS. 2 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 16, 2022 Author Share Posted April 16, 2022 3 hours ago, apersson850 said: Here's a link to the Programbiten newsletter from 1985, where my implementation of an adaptable cursor was published. Look at page 25. There you'll see the DEF FLIP, NOFLIP command. These two procedures enable and disable the adaptable cursor under Extended BASIC. Note that due to the daisy wheel on the printer, a command like CLR @THIS is printed as CLR 'THIS. Very nice code. I like the use of XOR to toggle the pattern. I will incorporate that idea and some in others in my implementation like the special case for the space character. I could probably take a lot of "as is" if I re-write in Forth Assembler. I assume that the printer char-set was for Swedish and therefore English ASCII "@" was the apostrophe to make room for the special characters? 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted April 16, 2022 Share Posted April 16, 2022 (edited) 3 hours ago, TheBF said: Very nice code. I like the use of XOR to toggle the pattern. I will incorporate that idea and some in others in my implementation like the special case for the space character. I could probably take a lot of "as is" if I re-write in Forth Assembler. I assume that the printer char-set was for Swedish and therefore English ASCII "@" was the apostrophe to make room for the special characters? I think it was Lee that explained XOR to me once upon a time as well, as I never knew. Edited April 16, 2022 by GDMike 1 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted April 16, 2022 Share Posted April 16, 2022 (edited) 5 hours ago, TheBF said: I assume that the printer char-set was for Swedish and therefore English ASCII "@" was the apostrophe to make room for the special characters? No matter what we did back then, we couldn't find a daisy wheel for our printer that would print both Swedish text and various program's source code properly. This was before laser printers, so to get a nice looking print, the newsletter was printed with a "pretty-printer". Nice to read that you appreciated the program. The rest of it was used to give a simple word processor, written in Extended BASIC, the ability to store strings in 8 K RAM. It also allows for saving these strings as a memory image. That made it possible to do some kind of word processing with TI Extended BASIC, 32 K RAM expansion and cassette player. And a printer, preferably. The DSRLNK procedure is enhanced a bit, since it can handle DSR's in both ROM and GROM. Thus it doesn't matter what kind of file name you'll throw at it. DSK2.TEXTFILE or CS1 will work just as well. It was developed for Programbiten Forth (to close the Forth circle), in order to allow that to load from cassette just as from diskette. The BASIC program was written so that it contained CALL LOAD statements to make a simple file loader. After doing OLD CS1 and RUN, the program used the CALL LOAD statements to place an assembly routine in memory. That program was called, and it immediately loaded another assembly program, the one you see in that newsletter, into memory. Then the BASIC program could start doing what it should. It was the first program I developed on the TI 99 where more than one person was working on the same project. Edited April 16, 2022 by apersson850 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 18, 2022 Author Share Posted April 18, 2022 (edited) Unfinished DTC Business A long while back I gave up trying to maintain a direct threaded system and focus on the core ITC system. As I added improvements to the kernel it became impossible to compile them into the DTC kernel "as is" so last week I started the process of re-learning all the things I forgot about how to make DTC work. I am still not convinced it's the right fit for TI-99 but it REALLY bugged me that I couldn't compile a DTC system. One of things that is not obvious is how to best use the SCRATCH-PAD RAM to hold fast primitives. With ITC it's easy. The first address of every ITC Forth word is a pointer to some native code. So you just patch the fast RAM address into the first cell of a definition and the Forth interpreter will branch to it when the time comes. Not so with Direct threading. In the direct threading model, the actual location address of the code must be compiled into a Forth definition. I now have the following words coded in fast RAM in the DTC code and I also updated the ITC code for the next release. ( I realized today that I could squeak in the code for ! which gave me DROP for free by just adding a label) l: _exit *RP+ IP MOV, l: _next* @@9: *IP+ W MOV, *W B, l: _?branch TOS DEC, TOS POP, @@2 JOC, l: _branch *IP IP ADD, @@9 JMP, @@2: IP INCT, @@9 JMP, l: _docol IP RPUSH, R11 IP MOV, @@9 JMP, l: _lit TOS PUSH, *IP+ TOS MOV, @@9 JMP, l: _@ *R4 R4 MOV, @@9 JMP, l: _! *SP+ *TOS MOV, L: _DROP TOS POP, @@9 JMP, l: _DUP TOS PUSH, @@9 JMP, l: _PLUS *SP+ TOS ADD, @@9 JMP, It turns out that for some of these it is not too hard because they are always "compiled" by the Forth compiler. The words ?BRANCH, BRANCH and LIT are not typically used by the programmer, rather the compiler uses them to do the work of IF, ELSE, WHILE, UNTIL etc. and LIT is compiled by the word LITERAL. ( EXIT is mostly compiled by the semi-colon, but there are some ways to use it in a program so it needs to be accessible too) The other programmer words @, ! , DUP , DROP and + must be able to be both interpreted and also the fast RAM address needs to compile into new definitions. In my previous DTC kernel I resorted to using a branch instruction to the fast RAM address. This negates most of the benefits of having the fast RAM code. Example: CODE DUP _DUP >HSRAM @@ B, ENDCODE * >HSRAM computes the location in fast RAM at compile time. So in this new version with my better understanding, I wrote normal RAM versions of the words for the kernel. These appear like normal code words when you boot the Forth system. I hear you asking "Does that mean the kernel is using the slow versions?" Well no. The cross-compiler has some secret incantations that let me compile the fast addresses in the kernel code as well. Once you are running the DTC kernel you need to "extend the compiler" so it knows how to decide what to do for compiling or interpreting the code in 16 bit RAM. The only answer I came up was to make "state-smart" versions of these words that do the right thing depending the "state" of the compiler. (compiling/interpreting) The first versions were naïve: : + STATE @ IF _HSPLUS , ELSE + THEN ; IMMEDIATE Then I realized each word was doing the same thing! How about we make a way to run the same code for different fast RAM addresses. Forth can do that. (It took me a minute to realize I had to add IMMEDIATE when the words are created) \ HSPRIMS.FTH Optimizing compilers for fast RAM code primitives : HSPRIM: ( addr -- ) \ <name> CREATE , IMMEDIATE \ remember the address. Make new word IMMEDIATE DOES> @ \ fetch the address STATE @ \ what is the compiler state ? IF COMPILE, ELSE EXECUTE THEN ; \ Address Name \ ------- ----- _HSDUP HSPRIM: DUP _HSPLUS HSPRIM: + _HS@ HSPRIM: @ _HS! HSPRIM: ! _HSDROP HSPRIM: DROP The DTC kernel is not much faster at compiling but on some benchmarks it shows some nice improvements. For example on this benchmark: DECIMAL 32000 CONSTANT INTMAX VARIABLE INTRESULT : DOINT 1 DUP INTRESULT DUP >R ! BEGIN DUP INTMAX < WHILE DUP NEGATE R@ +! 1+ DUP R@ +! 1+ R@ @ OVER * R@ ! 1+ R@ @ OVER / R@ ! 1+ REPEAT R> DROP DROP ; ITC 14.61 seconds DTC 12.38 seconds That's 18% faster! Edited April 19, 2022 by TheBF fixed typos 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 19, 2022 Author Share Posted April 19, 2022 DTC System Update My big issue with DTC Forth on TI-99 was the extra 8 bytes used for the entry code to each hi-level Forth word. Something that mitigates that problem a little is the SuperCart. This system now has a version that runs at >6000 nicely. There are a few things that are bugging out, but because I used the ANS Forth method of referring to memory in CELLS and using >BODY to access the data field, many things work "as is" from the ITC library. I can even do the TRANSIENT tool loading into low RAM because the dictionary structure is the same. I have one big bug to kill at the moment that involves the I word, in a DO LOOP, but only after I have loaded some other stuff first. ??? And of course wordlists and vocabularies are not working so that will be an ordeal to fix I am sure. But mostly I think this could become a useable system especially with SuperCart. The other thing DTC Forth is good for is as a way to link code words together and in that case DTC is a net memory saving. So if a project can be written in Forth Assembler mostly DTC is the preferred way to go. In theory one should be able to replace the Assembler with a Machine Forth Assembler the CODE words would still look like hi-level Forth. Things that make me say hmm...? Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 20, 2022 Author Share Posted April 20, 2022 Well this is a good feeling. I think I found the DO LOOP bug and I am now able to begin compiling the same demo programs on both systems. This Dutch Flag Demo using the Dijkstra algorithm is only about 9% faster. The demo runs in VDP RAM directly. Dijkstra DTC.mp4 Dijkstra ITC.mp4 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 20, 2022 Author Share Posted April 20, 2022 If you spend some time turning over stones ... ... yer gonna find a bug. I thought I had fixed my DO LOOP 'I' bug but I had not. Deeper dive revealed that I had made a word immediate that should not have been for a LONG time. There a bit of a comedy (tragedy?) of errors here. The reason it worked in the ITC version because I forced the initialization of the LEAVE stack when ABORT called the interpreter ( QUIT ) to make it work. The reason it acted up in the DTC version was because somehow the WARM boot word did not include a line to init the stack pointer. DUH! So it showed up in earlier in the DTC system. Bit of luck I guess since it made the old system more robust now too. Anyway, the problem word was RAKE RAKE is the word that resets the LEAVE stack, so the stack would overflow after a couple of DO LOOPs were compiled. So I now have a pretty solid DTC system (finally) and aside from fixing a few CODE words, that need to skip past those extra four bytes to get to the PFA, it works really well. Here is the code file with the word that was not supposed to be IMMEDIATE. One difference with this new system is that I don't try to shoehorn all the loops builders into the kernel. This file compiles when the system boots. It only takes three seconds extra and I load a few other words at start up anyway. Spoiler CR .( ANS/ISO Loop & Branch) \ special compilers needed for hi-speed code in scratch-pad RAM : ?BRANCH _?HSBRANCH , ; IMMEDIATE : BRANCH _HSBRANCH , ; IMMEDIATE : AHEAD ( -- addr) HERE 0 , ; : <BACK ( addr --) HERE - , ; : THEN ( addr -- ) HERE OVER - SWAP ! ; IMMEDIATE : BEGIN HERE ; IMMEDIATE : IF POSTPONE ?BRANCH AHEAD ; IMMEDIATE : ELSE POSTPONE BRANCH AHEAD SWAP POSTPONE THEN ; IMMEDIATE : UNTIL POSTPONE ?BRANCH <BACK ; IMMEDIATE : AGAIN POSTPONE BRANCH <BACK ; IMMEDIATE : WHILE POSTPONE IF SWAP ; IMMEDIATE : REPEAT POSTPONE AGAIN POSTPONE THEN ; IMMEDIATE \ CAMEL Forth LEAVE stack pointer is initialized by WARM : >L ( x -- ) ( L: -- x ) 2 LP +! LP @ ! ; : L> ( -- x ) ( L: x -- ) LP @ @ -2 LP +! ; \ -compile this- - run this now- : DO ( -- ) ?COMP POSTPONE <DO> HERE 0 >L ; IMMEDIATE : ?DO ( -- ) ?COMP POSTPONE <?DO> HERE 0 >L ; IMMEDIATE : LEAVE ( -- ) ( L: -- addr ) POSTPONE UNLOOP POSTPONE BRANCH AHEAD >L ; IMMEDIATE : RAKE ( -- ) ( L: 0 a1 a2 .. aN -- ) BEGIN L> ?DUP \ read leave stack, dup if <>0 WHILE POSTPONE THEN \ resolve branch in LEAVE REPEAT L0 LP ! ; \ reset the leave stack : LOOP ( -- ) POSTPONE <LOOP> <BACK RAKE ; IMMEDIATE : +LOOP ( -- ) POSTPONE <+LOOP> <BACK RAKE ; IMMEDIATE 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 21, 2022 Author Share Posted April 21, 2022 (edited) Direct Threaded Code is more fun than I realized. It turns out that reducing the size of the NEXT routine from 3 instructions to 2 instructions opens up new possibilities. For those not intimately familiar with the "innards" of Forth, NEXT is the name of a very small interpreter that can read a list of addresses in memory. It is cleverly organized to use the return stack so that it can read an address in memory, jump to the address to run some code there and then find it's way back to the next memory location. Thus the name "NEXT". In all the other Forth systems that I know of on TI-99 the internals used something called Indirect Threaded Code. (ITC) This means that each address in these lists is actually the address... of the address ... of some code. Thus it is "indirect". There are many advantages to this system but it does cost a bit of speed. Camel99 Forth code to do the ITC "interpreter" that reads the list of addresses is similar to all the others. ; IP is the interpreter pointer register (points to where the list is located) ; W is the "working register" kind of like a temp but also has other uses NEXT MOV *IP+,W ; Read the data at the IP location and bump the IP MOV *W+,R5 ; Read the data at the address in W into R5 (that's the indirect part) B *R5 ; finally we can jump to the address we have in R5. Every Forth routine must run this bit of code when it is finished executing. You could copy this code at the end of every Forth routine but that's 6 bytes and it gets big fast. On 9900 we mostly put the code in 16 bit RAM and put the address of NEXT in a spare register and branch through that register. Camel99 uses R10. That means we only need 2 bytes (one instruction at the end of every Forth word and NEXT runs a full CPU speed. Direct threaded code has a smaller "interpreter" MOV *IP+,W B *W This changes things in ways I didn't expect. We can now decide: Do we want to branch through a register like before or just copy this code inline after every routine? I chose to do both. I replaced the branch through R10 code in the kernel in every Assembly language word with the inline NEXT. This adds 1 extra instruction per word but DTC saves an address in the header. I also have a copy of NEXT in 16 bit RAM and since we are using direct threading I can simply copy that fast address into the end of Forth words with the semi-colon operator. How neat is that? So what you may ask? Well getting back to our little integer benchmark: DECIMAL 32000 CONSTANT INTMAX VARIABLE INTRESULT : DOINT 1 DUP INTRESULT DUP >R ! BEGIN DUP INTMAX < WHILE DUP NEGATE R@ +! 1+ DUP R@ +! 1+ R@ @ OVER * R@ ! 1+ R@ @ OVER / R@ ! 1+ REPEAT R> DROP DROP ; Timings TI99 Camel99 Forth (ITC) Integer Calc 0:14.7 (DTC) 0:12.4 (DTC) with inline next 0:11.98 22.7% speed up over ITC Full disclaimer: There is no free lunch, The DTC code is bigger if you write hi-level Forth. There is a 4 byte entry ( a BL instruction in my case) into every Forth word. For example to load my Graphics library file ( COLOR, SCREEN, HCHAR etc) on the ITC version uses 858 bytes. On the DTC kernel running almost identical source code uses 930 bytes. However if you only write ALC code words you save 2 bytes on entry with every word using DTC so the extra instruction in NEXT is a wash. I am liking it more now that it is stable. If I was having any more fun it would probably be illegal in some states. (that shall remain nameless) Edited April 21, 2022 by TheBF typo 4 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 22, 2022 Author Share Posted April 22, 2022 I forgot to link in the fast primitives that are in scratch-pad RAM. \ HSPRIMS.FTH Optimizing compilers for fast RAM code primitives : HSPRIM: ( addr -- ) \ <name> CREATE , IMMEDIATE \ remember the address. Make new word IMMEDIATE DOES> @ \ fetch the address STATE @ \ what is the compiler state ? IF COMPILE, ELSE EXECUTE THEN ; \ Address Name \ ------- ----- _HSDUP HSPRIM: DUP _HSPLUS HSPRIM: + _HS@ HSPRIM: @ _HS! HSPRIM: ! _HSDROP HSPRIM: DROP That took the time on DOINT down to 11.75. That gives DTC a 25% speed improvement on this benchmark. 4 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 25, 2022 Author Share Posted April 25, 2022 In the topic called Benchmarking languages Lee demonstrated how much little bits of extra code, inside an inner loop really affect program speed. While working on this DTC version I wondered what would happen if I could optimize the comparison operator in the byte sieve benchmark. Early on when building the Forth system I was struggling to fit it all in an 8K program space so I made the comparison operators branch to little code snippets to either set TOS to zero or set TOS to TRUE. This saved 8 bytes but it meant that the comparison operators did not end with NEXT. Not ending with NEXT meant the optimizer could not figure out where the code ended and so you could not use INLINE[ ] with <, >, U<, or U> . So I changed those comparison operators today and on the Sieve benchmark in my regular ITC Forth, the time went from 80.8 seconds to 76 seconds just by including the '<' symbol in the inlining brackets. This effectively removed only one extra pass through the 3 instruction interpreter. It made a 6% improvement because that comparison is made on every pass through the inner loop. By comparison replacing DUP + with 2* and replacing DROP DROP with 2DROP only improved the time by 0.5 seconds. For reference this code here: : DO-PRIME2 FLAGS SIZE 1 FILL ( set array ) 0 ( counter ) SIZE 0 DO INLINE[ FLAGS I + C@ ] IF INLINE[ I DUP + 3 + DUP I + ] BEGIN INLINE[ DUP SIZE < ] \ <<< this is the line WHILE INLINE[ 0 OVER FLAGS + C! OVER + ] REPEAT INLINE[ DROP DROP 1+ ] THEN LOOP CR SPACE . ." Primes" ; 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 29, 2022 Author Share Posted April 29, 2022 Direct Threaded Forth System Update I have most of the system support libraries working now on the DTC system. Turns out that things like WORDLISTs which I thought would be difficult just worked once I had all the bugs out of the kernel. That was a nice surprise. Much of the changes were around some of the recent optimizations made to graphics and sprites. I now have "TABLES" that let me define sections of memory as arrays even VDP RAM. The address calculations are in machine code using the ;CODE word. The 'W' register in DTC holds the CFA (code field address). The DATA is 4 bytes past that. So where before I could get to the data with W TOS MOV, If I used W with DTC Forth, I would have to have W 4 ADDI, W TOS MOV, But I have a secret weapon. Since all Forth words in this DTC system are called by BL, R11 automagically holds the DATA field address. (4 bytes ahead) So R11 TOS MOV, is all I needed to change. Example: Here we make TABLE4: that let's us define all the sprite data fields as byte arrays accessed with VC@ or VC!. If I had written TABLE4: with Forth CREATE/DOES> they would not need to be changed but I like the performance of these versions. ITC : TABLE4: ( Vaddr -- ) \ create a table of 4 byte records CREATE , ;CODE ( n -- Vaddr') 0A24 , \ TOS 2 SLA, ( tos = n x 4 ) A118 , \ *W TOS ADD, NEXT, ENDCODE SAT TABLE4: SP.Y SAT 1+ TABLE4: SP.X SAT 2+ TABLE4: SP.PAT SAT 3 + TABLE4: SP.COLR DTC : TABLE4: ( Vaddr -- ) \ create a table of 4 byte records CREATE , ;CODE 0A24 , \ TOS 2 SLA, ( tos = n x 4 ) A11B , \ *R11 TOS ADD, ( add base address to index in TOS) NEXT, ENDCODE SAT TABLE4: SP.Y SAT 1+ TABLE4: SP.X SAT 2+ TABLE4: SP.PAT SAT 3 + TABLE4: SP.COLR ANSFILES just worked with no changes ARRAYS were also optimized with ;CODE so the they needed the R11 tweek. ASM9900 works the same since I decided to go with NEXT in R10. (you can add inline NEXT in your own CODE words as you wish anyway.) Today was test the multi-tasker day. It required a kernel change to the word PAUSE and changes to the words SINGLE and MULTI. PAUSE now uses 4 bytes of space and by default holds the code for DTC NEXT which is SINGLE task mode. (2 instructions) For MULTI mode PAUSE is patched to hold the instruction: BL @YIELD. \ code snippets that are copied into PAUSE enable/disable multi-tasking HEX CREATE 'ILNEXT' *IP+ R5 MOV, R5 ** B, CREATE BL@YIELD 'YIELD @@ BL, \ turn multi-tasking on or off by patching the code in PAUSE : SINGLE ( -- ) 'ILNEXT' 2@ ['] PAUSE 2! ; \ disable multi-tasking : MULTI ( -- ) BL@YIELD 2@ ['] PAUSE 2! ; \ enable multi-tasking. After that it worked! The last big thing I need to fix (I think) is SAVESYS that creates E/A5 programs. Here is a cute the demo running on DTC Forth and the program source that spawns three new tasks in empty memory. Spoiler \ MYSTERIOUS EYES II Jan 21 2021 Fox \ demonstrates sprites, DATA statement, multi-tasking and saving binary program \ INCLUDE DSK1.TOOLS \ debug only INCLUDE DSK1.DATABYTE INCLUDE DSK1.MARKER \ needed for LOCK INCLUDE DSK1.MALLOC INCLUDE DSK1.GRAFIX INCLUDE DSK1.RANDOM INCLUDE DSK1.DIRSPRIT \ INCLUDE DSK1.MTASK99 DECIMAL : CHARDEF4 ( data[] ascii# -- ) PAUSE ]PDT 32 VWRITE ; \ **************************************** \ * Sprite Patterns \ **************************************** HEX CREATE EYELIDS DATA 030C,1020,4040,8080 \ 0 Wide open DATA 8080,4040,2010,0C03 DATA C030,0804,0202,0101 DATA 0101,0202,0408,30C0 DATA 030F,1F3F,4040,8080 DATA 8080,4040,2010,0C03 DATA C0F0,F8FC,0202,0101 DATA 0101,0202,0408,30C0 DATA 030F,1F3F,7F7F,8080 DATA 8080,4040,2010,0C03 DATA C0F0,F8FC,FEFE,0101 DATA 0101,0202,0408,30C0 DATA 030F,1F3F,7F7F,FFFF DATA 8080,4040,2010,0C03 DATA C0F0,F8FC,FEFE,FFFF DATA 0101,0202,0408,30C0 DATA 030F,1F3F,7F7F,FFFF DATA FFFF,4040,2010,0C03 DATA C0F0,F8FC,FEFE,FFFF DATA FFFF,0202,0408,30C0 DATA 030F,1F3F,7F7F,FFFF DATA FFFF,7F7F,2010,0C03 DATA C0F0,F8FC,FEFE,FFFF DATA FFFF,FEFE,0408,30C0 DATA 030F,1F3F,7F7F,FFFF DATA FFFF,7F7F,3F1F,0C03 DATA C0F0,F8FC,FEFE,FFFF DATA FFFF,FEFE,FCF8,30C0 DATA 030F,1F3F,7F7F,FFFF DATA FFFF,7F7F,3F1F,0F03 DATA C0F0,F8FC,FEFE,FFFF DATA FFFF,FEFE,FCF8,F0C0 \ 7 FULLY CLOSED DECIMAL : ]EYELID 32 * EYELIDS + ; CREATE PUPIL HEX DATA 0000,0000,0001,0307 DATA 0707,0301,0000,0000 DATA 0000,0000,00C0,E0F0 DATA F0F0,E0C0,0000,0000 \ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ DECIMAL 128 CONSTANT LEFTEYE 132 CONSTANT RIGHTEYE 136 CONSTANT LEFTPUPIL 140 CONSTANT RIGHTPUPIL 144 CONSTANT SCLERA ( the white part of the eye) VARIABLE FATIGUE 10 FATIGUE ! VARIABLE CALM 90 CALM ! : BLINKER FATIGUE @ MS ; : CLOSE2 ( -- ) 8 0 DO I ]EYELID DUP LEFTEYE CHARDEF4 RIGHTEYE CHARDEF4 BLINKER LOOP ; : OPEN2 ( -- ) 0 7 DO I ]EYELID DUP LEFTEYE CHARDEF4 RIGHTEYE CHARDEF4 BLINKER -1 +LOOP ; : BLINK2 CLOSE2 OPEN2 ; \ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ CREATE EYE-XY 0 , 0 , EYE-XY CONSTANT EROW EYE-XY 2+ CONSTANT ECOL : PIX.COL ( -- n) ECOL @ 8* ; : PIX.ROW ( -- n) EROW @ 8* 1- ; CHAR * CONSTANT '*' CHAR ! CONSTANT '!' : DEF.CHARS 0 ]EYELID LEFTEYE CHARDEF4 0 ]EYELID RIGHTEYE CHARDEF4 PUPIL LEFTPUPIL CHARDEF4 PUPIL RIGHTPUPIL CHARDEF4 7 ]EYELID SCLERA CHARDEF4 ( define a white circle in 4 chars ) SCLERA SET# 16 1 COLOR ( make it white) 2 MAGNIFY '*' SET# 13 1 COLOR '!' SET# 9 1 COLOR ; : .EYELIDS ( char colr x y sp# -- ) CLOSE2 128 2 PIX.COL PIX.ROW 0 SPRITE \ left eye 132 2 PIX.COL 32 + PIX.ROW 1 SPRITE \ left right ; : .PUPILS ( char colr x y sp# -- ) 136 2 PIX.COL PIX.ROW 2 SPRITE \ left pupil 140 2 PIX.COL 32 + PIX.ROW 3 SPRITE \ right pupil ; : .SCLERA ( col row --) 2DUP AT-XY 144 EMIT 146 EMIT 1+ AT-XY 145 EMIT 147 EMIT ; : .2SCLERA ( --) VROW 2@ 2>R \ save cursor position EYE-XY 2@ 2DUP .SCLERA SWAP 4 + SWAP .SCLERA 2R> AT-XY ; \ restore : .EYES ( col row -- ) EYE-XY 2! .2SCLERA .EYELIDS .PUPILS ; : HORZ ( offset -- ) DUP 2 SP.X VC! 32 + 3 SP.X VC! ; : VERT ( height -- ) DUP 2 SP.Y VC! 3 SP.Y VC! ; \ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \ TASKS : BLINKING ( -- ) BEGIN 3000 RND FATIGUE @ + MS BLINK2 AGAIN ; : LEFT/RIGHT BEGIN 2000 RND CALM @ + MS PIX.COL 9 RND 4 - + HORZ AGAIN ; DECIMAL C/SCR @ 1- CONSTANT N \ chars per screen - 1 : THING BEGIN CLOSE2 PAGE 10 10 OPEN2 .EYES N 2/ 0 DO '!' I VC! '*' N I - VC! 40 MS LOOP AGAIN ; : UP/DOWN BEGIN 3000 RND CALM @ + MS PIX.COL 9 RND 4 - + VERT ?TERMINAL UNTIL ; \ \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \ combine multi-tasking primitives to dynamically create a task : SPAWN ( xt -- ) USIZE MALLOC DUP FORK DUP WAKE ASSIGN ; HEX 83D6 CONSTANT NO-TIMEOUT DECIMAL : GO ( WARM) GRAPHICS NO-TIMEOUT ON 1 SCREEN INIT-MULTI ['] BLINKING SPAWN ['] LEFT/RIGHT SPAWN ['] THING SPAWN DEF.CHARS MULTI UP/DOWN \ console task BYE ; uhoh-demo.mp4 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 29, 2022 Author Share Posted April 29, 2022 (edited) Approaching Bug-for-Bug Compatibility I threw something harder at the DTC multi-tasker. Five tasks + console task. Still runs correctly. (This stability of the cross-compiler now that I have fixed the RAKE word is so refreshing. I used to get these weird bugs that I could not understand) Spoiler \ BILLYBALL XB256 DEMO by @Retrospect on atariage.com Nov 1 2021 \ Test harness for Camel99 forth B Fox INCLUDE DSK1.LOWTOOLS \ DEBUG ONLY INCLUDE DSK1.MARKER INCLUDE DSK1.MALLOC INCLUDE DSK1.GRAFIX INCLUDE DSK1.RANDOM INCLUDE DSK1.SOUND INCLUDE DSK1.DIRSPRIT \ direct control sprites INCLUDE DSK1.MTASK99 INCLUDE DSK1.MTOOLS INCLUDE DSK1.AUTOMOTION INCLUDE DSK1.RANDOM DECIMAL 1 CONSTANT Transparent 5 CONSTANT Blue 9 CONSTANT Red 11 CONSTANT Yellow 15 CONSTANT Gray 16 CONSTANT White \ *********************** \ task creation \ *********************** : TASK: ( n -- ) USIZE MALLOC DUP FORK CONSTANT ; \ returns PID (address) DECIMAL TASK: JOB1 \ Billy ball rotator TASK: JOB2 \ Bill ball mover TASK: JOB3 \ Bobby ball rotator TASK: JOB4 \ Bobby ball mover TASK: JOB5 \ cannon \ *********************** \ CHAR DEFINITION HELPERS \ *********************** DECIMAL : CHARDEF32 ( data[] ascii# -- ) ]PDT 32 VWRITE ; \ def 2 chars (32 bytes) \ convert long text string to 16 bit HEX numbers and \ compile each number into memory sequentially : HEX#, ( addr len --) BASE @ >R \ save radix HEX \ converting string to hex numbers BEGIN DUP WHILE \ while len<>0 OVER 4 \ used 4 digits from left end of string NUMBER? ?ERR \ convert string to number , \ compile the integer into memory 4 /STRING \ cut 4 digits off left side of string REPEAT \ keep going until string is exhausted 2DROP R> BASE ! \ restore radix ; \ ********************* \ * ASTEROID PATTERNS * \ ********************* DECIMAL CREATE ASTEROIDS S" 000F191032434964504C23100C0700000000C020501098CC1272941CF0000000" HEX#, S" 000000050A10121410181C13110D03000000F008104844CC9A12648418600000" HEX#, S" 00000001020509181F10100E07000000000000F02804E4063EE2020CF0000000" HEX#, S" 00000000031C382E212018070000000000000070888C5262828C90E000000000" HEX#, S" 0000000007182F2524150E000000000000000000E01078C4042CD80000000000" HEX#, S" 00000000000F18282F28311E0000000000000000E05844C43C0428F000000000" HEX#, S" 000000000304041D161414181108070000000000789412729A06024438C08000" HEX#, : ]ASTEROID ( n -- addr) 32 * ASTEROIDS + ; \ 0 TO 5 asteriods \ **************************************************************** \ * NOW TO HAVE AN ARRAY WITH 4 ELEMENTS, FOR THE FOUR ASTEROIDS * \ **************************************************************** \ these will keep a pattern number in them, and each one will be different CREATE AST[] 74 , 80 , 84 , 88 , : ]AST ( n -- addr) CELLS AST[] + ; \ ************************ \ * THE GROUND TO SCROLL * \ ************************ 251 CONSTANT DIRT.CHAR CREATE EARTH S" 10183C3C7E7EFFFF0000001010387CFF0000000000000FFF08080818387C7EFF" HEX#, EARTH DIRT.CHAR CHARDEF32 \ *********************** \ * BALL ANIMATION DEFS * \ *********************** \ Compile contiguos data for each frame of Ball animation CREATE BALLS ( patterns for 23 chars ) S" 00030F1F3F3C787A787F7F3C3E1F0F0300E0F8FCFE9E8FAF8FFFFF1E3EFCF8E0" HEX#, S" 00030F1F3F397175717F7F383C1F0F0300E0F8FCFE3E1F5F1FFFFF3E7EFCF8E0" HEX#, S" 00030F1F3F32626A627F7F30381F0F0300E0F8FCFE7E3FBF3FFFFF7EFEFCF8E0" HEX#, S" 00030F1F3F244455447F7F20311F0F0300E0F8FCFEFE7F7F7FFFFFFEFEFCF8E0" HEX#, S" 00030F1F3F09082A087F7F01231F0F0300E0F8FCFEFEFFFFFFFFFFFEFEFCF8E0" HEX#, S" 00030F1F3F131155117F7F03071F0F0300E0F8FCFEFEFFFFFFFFFFFEFEFCF8E0" HEX#, S" 00030F1F3F27232B237F7F070F1F0F0300E0F8FCFEFEFFFFFFFFFFFEFEFCF8E0" HEX#, S" 00030F1F3F0F4757477F7F0F3F1F0F0300E0F8FCFEFEFFFFFFFFFFFEFEFCF8E0" HEX#, S" 00030F1F3F1F0F2F0F7F7F1F3F1F0F0300E0F8FCFEFEFFFFFFFFFFFEFEFCF8E0" HEX#, S" 00030F1F3F1F1F5F1F7F7F3F3F1F0F0300E0F8FCFEFEFFFFFFFFFFFEFEFCF8E0" HEX#, S" 00030F1F3F3F7F7F7F7F7F3F3F1F0F0300E0F8FCFEFEFFFFFFFFFFFEFEFCF8E0" HEX#, S" 00030F1F3F3F7F7F7F7F7F3F3F1F0F0300E0F8FCFEFEFFFFFFFFFFFEFEFCF8E0" HEX#, S" 00030F1F3F3F7F7F7F7F7F3F3F1F0F0300E0F8FCFEFEFFFFFFFFFFFEFEFCF8E0" HEX#, S" 00030F1F3F3F7F7F7F7F7F3F3F1F0F0300E0F8FCFEFEFFFFFFFFFFFEFEFCF8E0" HEX#, S" 00030F1F3F3F7F7F7F7F7F3F3F1F0F0300E0F8FCFEFCFCFDFCFFFFFEFEFCF8E0" HEX#, S" 00030F1F3F3F7F7F7F7F7F3F3F1F0F0300E0F8FCFEFCF8FAF8FFFFFCFEFCF8E0" HEX#, S" 00030F1F3F3F7F7F7F7F7F3F3F1F0F0300E0F8FCFEF8F1F5F1FFFFF8FEFCF8E0" HEX#, S" 00030F1F3F3F7F7F7F7F7F3F3F1F0F0300E0F8FCFEF2E2EAE2FFFFF0F8FCF8E0" HEX#, S" 00030F1F3F3F7F7F7F7F7F3F3F1F0F0300E0F8FCFEE4C4D5C4FFFFE0F0FCF8E0" HEX#, S" 00030F1F3F3F7F7F7F7F7F3F3F1F0F0300E0F8FCFEC888AA88FFFFC0E2FCF8E0" HEX#, S" 00030F1F3F3F7F7F7F7F7F3F3F1F0F0300E0F8FCFE92115511FFFF82C6FCF8E0" HEX#, S" 00030F1F3F3F7E7E7E7F7F3F3F1F0F0300E0F8FCFE2623AB23FFFF068EFCF8E0" HEX#, S" 00030F1F3F3E7C7D7C7F7F3E3F1F0F0300E0F8FCFE4E475747FFFF0E1EFCF8E0" HEX#, \ expose BALLS as an array of 32 byte records \ Animate the BALL by sequencing from 0 ]BALL to 22 ]BALL OR reverse : ]BALL ( n -- addr ) 32 * BALLS + ; CREATE EXPLOSION S" 0030787C3E1C0070FCF8F83103030100000E1E1C382000071F0F8680C0E08000" HEX#, \ ******************************** \ * BILLY BALL'S MAGICAL MISSILE * \ ******************************** S" 0000000000000211AF02000000000000000000000034FDDFEFF6280000000000" 136 CALLCHAR \ ************** \ * STAR CHR'S * \ ************** DECIMAL CREATE STARS 160 , 168 , 176 , 184 , 192 , 200 , 208 , : ]STAR ( n -- addr) CELLS STARS + ; PAD CHAR . CHARPAT \ read '.' char pattern PAD 0 ]STAR CHARDEF \ assign to star characters PAD 1 ]STAR CHARDEF PAD 2 ]STAR CHARDEF PAD 3 ]STAR CHARDEF PAD 4 ]STAR CHARDEF PAD 5 ]STAR CHARDEF PAD 6 ]STAR CHARDEF \ ********************* \ Multi-Task actions must be in an endless loop. Control with WAKE/SLEEP \ ********************* HEX 50 USER SPIN \ user variable for rotation speed 52 USER SPEED \ speed of motion DECIMAL : ROTATOR ( char speed -- ) SPIN ! BEGIN 23 0 DO I ]BALL OVER CHARDEF32 SPIN @ MS PAUSE LOOP AGAIN ; \ ***************************** \ MAKE SPRITES \ ***************************** DECIMAL 2 MAGNIFY 128 CONSTANT Billy 132 CONSTANT Bobby 136 CONSTANT Missle 0 CONSTANT Bill 1 CONSTANT Bob 02 CONSTANT WEAPON DECIMAL : BOUNCER ( spr# speed --) SPEED ! \ each task has it's own bound speed BEGIN 130 10 DO I OVER SP.Y VC! SPEED @ MS LOOP 10 130 DO I OVER SP.Y VC! SPEED @ MS -1 +LOOP AGAIN ; \ INC/DEC byte in VDP RAM : +!V ( n Vaddr -- ) S" TUCK VC@ + SWAP VC!" EVALUATE ; IMMEDIATE : STOP ( pid -- ) SLEEP PAUSE ; DECIMAL : LASER-ON GEN1 121 HZ 12 DB GEN2 125 HZ 12 DB ; : LASER-OFF GEN1 MUTE GEN2 MUTE ; : FADE-BLAST 31 6 DO GEN4 I DB 50 MS LOOP ; DECIMAL : EXPLODE ( -- ) 4 NOISE 0 DB \ impact sound LASER-OFF \ kill the laser beam 100 MS 5 NOISE 16 0 DO PAUSE I DB \ fade impact noise I Bob SP.COLR VC! \ change Bobby's color 70 MS LOOP Blue Bob SP.COLOR SILENT ; : SP.X++ ( n spr# -- ) SP.X +!V ; : SPIN-RATE ( n spr# -- ) SPIN LOCAL ! ; : LAUNCHER ( sp.X sp.Y -- ) Bill POSITION WEAPON LOCATE \ Put weapon inside sprite 0 6 NOISE 0 DB \ initial shot LASER-ON 100 TICKS \ brief ontime GEN4 14 DB \ reduce noise to cruise volume. BEGIN PAUSE Red WEAPON SP.COLOR \ give it a color 4 WEAPON SP.X++ \ move the flaming shot Bob WEAPON 10 COINC \ test for collision IF ( we hit Bobby) Transparent WEAPON SP.COLOR \ weapon goes invisible 5 JOB3 SPIN-RATE \ change Bobby's spin rate EXPLODE \ make some sound and change Bobby's color 60 JOB3 SPIN-RATE \ make Bobby slowdown again MYSELF STOP THEN Yellow WEAPON SP.COLOR \ change color while fire travels WEAPON SP.X VC@ 250 > \ test for WEAPON at edge of screen UNTIL LASER-OFF FADE-BLAST 60 JOB3 SPIN-RATE \ make Bobby slowdown again Transparent WEAPON SP.COLOR Blue Bob SP.COLOR \ reset Bobby's color MYSELF STOP ; : SPIN-BILL Billy 60 ROTATOR ; : SPIN-BOB Bobby 60 ROTATOR ; : BOUNCE-BILL Bill 25 BOUNCER ; : BOUNCE-BOB Bob 15 BOUNCER ; \ faster movement, harder to hit ' SPIN-BILL JOB1 ASSIGN ' BOUNCE-BILL JOB2 ASSIGN ' SPIN-BOB JOB3 ASSIGN ' BOUNCE-BOB JOB4 ASSIGN ' LAUNCHER JOB5 ASSIGN : GO CLEAR Gray SCREEN ( char colr x y sp# -- ) Billy White 10 10 Bill SPRITE Missle 1 20 20 WEAPON SPRITE JOB1 WAKE JOB2 WAKE 2500 MS Bobby Blue 215 10 Bob SPRITE JOB3 WAKE JOB4 WAKE ; : FIRE CLEAR JOB5 RESTART 100 MS ; MULTI BillyBall-DTC.mp4 Edited April 29, 2022 by TheBF Added code spoiler 1 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 29, 2022 Author Share Posted April 29, 2022 (edited) What about SAMS in DTC you ask? SAMSINI works without changes PAGED which converts a virtual address to a real address in CPU RAM, works without changes. FAR: and ;FAR that compile definitions into SAMS memory; That required changes but due to the magic of R11 it was minimal. It really comes down to changing FARCOL that replaces DOCOL in SAMS definitions and the fact that we have have to BL to FARCOL rather than putting the address in after the HEADER of the Forth word. CREATE FARCOL \ run time executor for SAMS *DTC* colon words. IP RPUSH, R11 IP MOV, \ <<< Replace W with R11 RP DECT, LASTBNK @@ *RP MOV, \ Rpush the active bank *IP+ R1 MOV, \ fetch bank# from DATA FIELD -> R1, inc IP _CMAP @@ BL, \ & switch to SAMS page for this word *IP IP MOV, \ get SAMS DP & set new IP NEXT, : FAR: ( -- ) \ special *DTC* colon for words in FAR memory !CSP HEADER \ compile Forth header with name FARCOL @@ BL, \ <<< compile bl to farcol *DTC change* BANK# @ DUP , \ compile bank# as the DATA field DUP ]DP @ , \ compile this word's SAMS address ( ie: FAR XT) HERE SAVHERE ! \ save "normal here" DUP ]DP @ DP ! \ set dp to CSEG. Compiling goes here now ( bank#) CMAP \ map SAMS for compiling HIDE ] \ turn on the compiler ; Two lines changed and it worked as the screenshot shows. Edited April 29, 2022 by TheBF Wrong screen shot. 2 Quote Link to comment Share on other sites More sharing options...
GDMike Posted April 30, 2022 Share Posted April 30, 2022 Well, I was wondering about that, and also how cool it'd be to have a forth app running in the background on my TIPI that I could send mp3 requests from the TI and back from the pi, now that we have a pi in their and able to handle long filenames.. Quote Link to comment Share on other sites More sharing options...
