icemanxp300 Posted January 12, 2018 Share Posted January 12, 2018 I was wondering are all drive belts the same size? Like a 360 and so forth. I need a new one and while I see people selling 2 of them for like $5 https://www.ebay.com/itm/NEW-Belts-Samsing-SDG-605-XBox-Original-Drive-Repair-Part-Belt-Lot-of-2/291302927579?hash=item43d301ecdb:g:ys4AAOSwdpxUXK0y The cheap part of me knows there has to be something cheaper. I can get 5 of these for $1 They are listed for xbox 360, would they be the same? https://www.ebay.com/itm/5-Replacement-DVD-Drives-Tay-Motor-Rubber-Belt-Ring-Part-For-Xbox-360-Slim-DG/253052839224?hash=item3aeb1fe538:g:rvQAAOSwacdZbxVv The original xbox at least the one I have has a samsung sdg-605f drive in it. On a side note, my xbox tray would not open, so after cleaning it it will now open but is finicky and prefers I hole down the button while the tray ejects. Plus after opening and closing 3 times or so the next one will not open and has to run a cycle then it will open again. So would that mean the drive belt is weak. Looks like the 360 ones will work. I'll give them a shot and compare belts when they come in. https://www.reddit.com/r/originalxbox/comments/6a7ydz/can_xbox_360_disc_drive_belts_be_used_for_the/ Quote Link to comment Share on other sites More sharing options...
