.ST editor for Windows?
Partially You can use MSA Converter 2.1. I'm using it sometimes and works very good for me. In Windows You can add to zip file some Atari files like programs, folders etc. and then convert such zip to msa or st file. But I don't remember if You can edit st file... Check it out here: http://msaconverter.free.fr/index-uk.html
Edited by Mq.
So you can add them via emulator as ParanoidLittleMan said. In the emulator You can add some windows folder as hdd, I suppose. Then You can copy files You want from that folder into .st image by emulated machine.
Another way is to use the program I previously linked. I'm useing it that way, that I pack files into zip file via windows, then I convert such zip file into st file. I don't use it to edit existing st files, so I don't know how to do that, and if it works.
