_The Doctor__ Posted April 12, 2019 Share Posted April 12, 2019 how about the string method for that instead... Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted April 12, 2019 Share Posted April 12, 2019 A few examples:- from disk file into string (first 6 bytes are file header, so throw them away) this also prints the value on screen. 10000 DIM FILL$(30) 10010 OPEN #1,4,0,"D:FILL.OBJ" 10020 FOR I=1 TO 6:GET #1,A:NEXT I 10030 TRAP 10100:I=1 10040 GET #1,A:FILL$(I,I)=CHR$(A) 10050 I=I+1:? A;","; 10060 GOTO 10040 10100 CLOSE #1 One important point with strings in your listing is if the string contains the double quote character, something like A$="123456"989009" that quote in the middle will cause problems you can get round this using;- 100 A$="HUy654sjdo":A$(len(A$)+1)=CHR$(34):A$(LEN(A$)+1)="sjdjsjh7w" I tended to use USR routines to clear blocks of memory (for..loops take so long) and things like VBL routines which obviously you can't do in BASIC 2 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted May 29, 2023 Share Posted May 29, 2023 you can also keep you binaries as load in snippets on the disk and load them in quite quickly and easily, compounded binaries as well... I figured there was similar question in the past, and I figure cross posting will help the searchers out. Just enter this in, my first post did not appear as I wished so. ENTER there you go, load away, changing F$="filename.ext" in line 100 to whatever filename your binary is named. Change POKE 5534,0 to 5534,192 in line 100 in order to LOAD and INIT but not RUN USR is doing PLA, JMP $15A9 and that calls the DOS routine that dup.sys Menu option L. utilizes. -----------------you can paste either of these into your emulator and then fix the paste up as noted------------------------------- 100 DIM F$(16):F$="D:BIN.OBJ":F$(LEN(F$)+1)=CHR$(155):POKE 5534,0:POKE 5535,192 110 X=ADR(F$):Y=INT(X/256):POKE 853,Y:POKE 852,X-256*Y:X=USR(ADR("hL) ")) 100 DIM F$(16):F$="D:BIN.OBJ":F$(LEN(F$)+1)=CHR$(155):POKE 5534,0:POKE 5535,192 110 X=ADR(F$):Y=INT(X/256):POKE 853,Y:POKE 852,X-256*Y:X=USR(ADR("hL{inv}){inv}{^}U")) The control characters are a pain in the ass on this forum so just press the inverse key (FUJIkey) where {inv} is so inverse shift 0 and then inverse again to turn that back off and then {^} is Control U in the X=USR part of the basic code. Quote Link to comment Share on other sites More sharing options...
