easmith Posted June 26, 2018 Author Share Posted June 26, 2018 Ok finally solved the issue . Kind of . After replacing all three IC s , resoldering all pins on left controller port , and swapping out a few capacitors , what ended up working was applying slight upward pressure on the controller port . So a small wooden shim underneath the J202 port did the trick . Perhaps just flexing the board brought helped a bad trace connect better ? Anyway , a bit anti climactic but a low tech solution in the end . Quote Link to comment Share on other sites More sharing options...
