Tickled_Pink Posted June 4, 2003 Share Posted June 4, 2003 I'm trying to come up with a piece of hardware that connects to the joystick ports. However, I'm a little puzzled as to how they work. When I tried the ports on my XL, I discovered that when set to input mode, the direction pins generate a voltage while they don't when set to output. How exactly do the joystick ports work? How does the machine know what direction the joystick is moving in? Link to comment Share on other sites More sharing options...
Watson2112 Posted June 10, 2003 Share Posted June 10, 2003 Imagine if the I/O chip didn't output anything when it was in input mode, and the joystick had to send +5vdc on a line to pull it high when the player pushed it in a certain direction. That would work, but what about an adapter like the one that let's Colecovision users use Atari joysticks? It also lets you plug in a Coleco controller. What if you pushed "up" on both controllers at the same time? Both would be pushing +5vdc on the same line and the I/O chip would die in a puff of blue smoke. Atari-style joystick ports are "open collector". In input mode, each line is pulled high (+5vdc) by a pull-up resistor inside the I/O chip, and the joystick connects a line to ground ("sinking" the current) when pushed in a direction. It seems backwards, but it's great because it doesn't matter if 1, 2, or even 20 devices are pulling the line to ground -- the I/O chip is only going to output so much current, and all of it gets grounded one way or another. The interrupt line on the CPU works the same way, BTW. 8 devices can pull the line low at the same time. All the CPU knows is that the line is low. It then has to ask every device that could have caused an interrupt if it did. Hope that helped! Link to comment Share on other sites More sharing options...
Archived
This topic is now archived and is closed to further replies.
