Xuel Posted November 30, 2019 Author Share Posted November 30, 2019 On 11/26/2019 at 3:56 PM, fox said: Something's wrong with the RAM option. I convert a ~40 second MP3 changing just the frequency to 15kHz. The!Cart plays fine, but RAM XEX is trimmed (just the beginning of the audio plays) and with high noises. I'm testing on Altirra 3.20 XE PAL 320K Rambo and both files are ~230KB. Thanks for the report! Looks like I need to read up on Rambo. It currently works with Compy up to 1088K. Quote Link to comment Share on other sites More sharing options...
tane Posted December 6, 2019 Share Posted December 6, 2019 Sometimes some options work, sometimes not... Metallica - Wherever I May Roam pdm14 mono 31200Hz thecart pal.car 1 Quote Link to comment Share on other sites More sharing options...
phaeron Posted December 6, 2019 Share Posted December 6, 2019 Probing the hardware some more -- I've confirmed that volume bit 3 is definitely slower than bits 0-2. The gates for bits 0-2 can pull down within half a cycle, bit 3 takes almost two cycles. The rising edges are more similar. The difference in fall rates and the asymmetrical edges is unnoticeable for most audio, but for PDM the truncated response to fine volume bit 3 shifts half of the levels. This effect is more pronounced than the jitter in high-pass timing, which can barely be seen in the second falling-edge image as the double curves to the same volume levels. Thus, removing some of the fine volume levels from the middle instead of the high end might be more effective. 2 1 Quote Link to comment Share on other sites More sharing options...
Xuel Posted December 7, 2019 Author Share Posted December 7, 2019 FujiConvert 0.3.1 https://lybrown.github.io/fujiconvert/ Changes Added PDM Presets: PDM16 - Original full dynamic range method PDM8 - Hardware Bit 3 mitigation? Avoids flipping bit 3 of the fine channel PDM14+bump - Sounds good with Altirra 3.20. Eliminates pops due to volume 0 on fine channel. PDM8+bump - Maybe a way to simulate PDM8 in Altirra 3.20. Eliminates pops. Added Bump setting. Fine channel is allowed to play levels X through X+Y where X is Bump and Y is Fine Levels. I'm curious how PDM8 sounds on real hardware as it may avoid the bit 3 latency issue that phaeron describes. I really need to find time to pull my own hardware out of storage! 5 Quote Link to comment Share on other sites More sharing options...
Xuel Posted December 7, 2019 Author Share Posted December 7, 2019 FujiConvert 0.3.2 https://lybrown.github.io/fujiconvert/ Changes Added Coarse Levels setting Changed presets to: 16 16 0 - Full dynamic range 8 8 0 - Hardware bit 3 mitigation 16 14 1 - Good for Altirra 8 8 1 - Simulation of 8 8 0 in Altirra Ack! I realized after my last post that the bit 3 issue would affect both coarse and fine levels, so preset "8 8 0" should mitigate this at the cost of reducing the dynamic range to 6 bits instead of the original 8. I remember several years ago reading about some folks who figured out a way to play 16-bit digital sound on an old game console (I can't remember which) which didn't have a proper DAC. I think they had to deal with similar timing issues. I think they ended up doing a brute force search through all possible bit pattern transitions to find the best sequence of register writes to reproduce a given sound waveform. Maybe we could do something similar here. For example, if we know that bit 3 is slow on falling transitions, then we should write an adjusted value to bits 0-2 to account for the latency. 4 Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted December 7, 2019 Share Posted December 7, 2019 Hmmm, I now have one problem though: So many choices! I am sorry, but stupid as I am, I do not know what all of the configurations and selections mean, e.g.: Preset (4 selections), DC Offset (16 selections), Coarse Levels (16 selections), Fine Levels (16 selections), Bump (4 selections), Non-Linear Pulse (no clue what can be input there), Linear Pulse (again, no cue what can be input there). So all in all we have 4 x 16 x 16 x 16 x4 x X x Y available selections. I do not want to test all possibilities (more than 65,535) to get a good result, so can you suggest some selections for a good PDM result ?!? 1 Quote Link to comment Share on other sites More sharing options...
Xuel Posted December 7, 2019 Author Share Posted December 7, 2019 2 minutes ago, CharlieChaplin said: Hmmm, I now have one problem though: So many choices! I am sorry, but stupid as I am, I do not know what all of the configurations and selections mean, e.g.: Preset (4 selections), DC Offset (16 selections), Coarse Levels (16 selections), Fine Levels (16 selections), Bump (4 selections), Non-Linear Pulse (no clue what can be input there), Linear Pulse (again, no cue what can be input there). So all in all we have 4 x 16 x 16 x 16 x4 x X x Y available selections. I do not want to test all possibilities (more than 65,535) to get a good result, so can you suggest some selections for a good PDM result ?!? Heh. Yeah, it's getting pretty confusing. You can just choose one of the presets. Notice that when you choose a preset it sets all of the other PDM settings automatically. For Altirra, I recommend "16 14 1". For real hardware, I don't know. Maybe "8 8 0" or "16 16 0", whichever sounds better to you. I have not personally tested any settings on real hardware unfortunately. Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted December 8, 2019 Share Posted December 8, 2019 ...this is what it sounds like, when doves cry... Errm no, this is what the real Atari sounds like when playing PDM soundfiles. Did a few recordings with my real A8, sound output was via monitor port (mono-only) connected via cinch-cables with my Hifi CD-Recorder. I always created four PDM versions using the given presets and therefore made four recordings. Version 1: PDM 8 8 1, Altirra; (named PDM8, Altirra) Version 2: PDM 8 8 0; (named PDM8) Version 3: PDM 16 14 1, Altirra; (named PDM14, Altirra) Version 4: PDM 16 16 0; (named PDM16) Note: I used a real Atari 800XL (PAL) for playback and NOT Altirra. All recordings were made with the same volume/recording volume, but of course PDM 14 and 16 are much louder than PDM 8 (eight bit is simply louder than six bit). And to me, the non-Altirra versions always sound better than the Altirra versions. Furthermore I think, PDM8 sounds quite awful and not really worth doing any conversions, PDM14 sounds better and PDM16 sounds best on the real A8. (Besides, I made the recordings via A8 monitor out, since my Lotharek stereo-enhancement seems to be buggy, it is approx. 2x louder but alas, it has 10x more noise and also an awful lot of distortion which makes it sound worse than the PDM8 recordings here. Why this only happens with PDM sounds and no other sounds is a mystery to me, especially, since the stereo enhancement is switched to mono and thus the same Pokey chip plays the sound via stereo enhancement / via monitor port...) Anyways, here are two songs converted into various PDM formats: DitW (1977/1978) and CD (1965/1966), recorded on CD and then back-converted into WAV. I did not record the full songs, just a small excerpt (somewhere between 53 and 61 seconds), but this is enough to hear the differences. And errm, just as an example, I also recorded a minute of sound of a 50fps video (I turned up the recording volume, so you should hear the awful whistling/buzzing noise there - this noise is present in all 50fps videos). CD_PDM.zip DitW_PDM.zip Mfn_50fps_AVF.zip Quote Link to comment Share on other sites More sharing options...
phaeron Posted December 8, 2019 Share Posted December 8, 2019 I would suggest trying 16 steps on coarse channel and 8 steps on fine channel. The ramp on/off speed for volume bit 3 shouldn't matter for the coarse channel due to the much longer pulse time. We should be able to recover fine steps as well, it just takes estimation for the effective amplitude at each level. Latest Altirra test version has a fix for the volume 0 high-pass bug, btw, so recommend not trying to work around that. 2 Quote Link to comment Share on other sites More sharing options...
Xuel Posted December 9, 2019 Author Share Posted December 9, 2019 FujiConvert 0.3.3 https://lybrown.github.io/fujiconvert/ Changes Replaced "8 8 1" preset with "16 8 0" preset. "16 8 0" will produce 16 coarse levels and 8 fine levels as phaeron suggests. @CharlieChaplin It sounds like you might have a ground loop in your audio recording setup. So it's a bit hard to gauge the quality of the output with the distortion that adds. It sounds like the fine levels are working. The waveforms look OK. I don't hear much difference between "PDM16" and "PDM14" which is good. That means the fine channel is properly calibrated for each scenario. The Mfn video sound is quite nice but in addition to the ground hum, it has the 15KHz carrier which drowns out some noise you might otherwise hear. The PWM method probably has the most linear response curve out of PWM, PDM and PCM since it doesn't depend on POKEY's volume levels. It just alternates between the lowest and highest volumes at X kHz and varies the duty cycle. FujiConvert has special handling for PWM at 8kHz, 15kHz and 31kHz to sync to the scan line which should avoid jitter from RAM refresh cycles. Quote Link to comment Share on other sites More sharing options...
pseudografx Posted December 9, 2019 Share Posted December 9, 2019 (edited) If any audio recordings from an Atari would come in handy, I can provide them, from my dual-POKEY 800XE with Ultimate and SIDE2 cartridges, connected to my PC's sound card. Edited December 9, 2019 by pseudografx Quote Link to comment Share on other sites More sharing options...
phaeron Posted December 10, 2019 Share Posted December 10, 2019 Some more info about what's going on in POKEY: Imperfect volume bit ratios cause glitches on the transition between coarse and fine channels. It's a bit hard to measure them precisely with the equipment I have and due to nonlinearity, but rough ratios of volume bits: 0.12V, 0.26V, 0.56V, 1.12V. The jump between bits 0-1 and 2-3 is mainly responsible for the gaps and clearly visible in the ramp. Re-measured the nonlinear curve with the digital scope and the best fit I've been able to come up with is a linear region into an exponential curve. The linear region goes up to around total volume level 12 before the curve starts becoming visible, so it's not too bad for PDM. Have a model that fits the scope graph pretty well but need to double-check the slope at the transition point. Channels 1 and 2 are delayed from channels 3 and 4 by about 100ns due to the high-pass XOR. Very rough volume bit timings are 100ns for volume bits to turn off (1->0 internally, high signal out of POKEY), 200ns for v0/v1 to turn on (0->1 internally, low signal out of POKEY), 340ns for v2 to turn on, 600ns for v3 to turn on. Turn-on is a hockey stick shaped curve, so the signals have transitioned by about 90% in half this time. Turn-off is an S-shaped curve, more symmetrical, about 67% in the middle 50ns. High-pass channels take different amounts of time to transition depending on whether the low channel (1/2) is transitioning 0->1 or 1->0. Going from 1->0 delays the transition starting by ~176ns. This is the primary reason for the even/odd instability on fine volume levels 8-15, because it alternates how much time and how far the signal for volume bit 3 can slew. Perhaps not coincidentally, this is just about the time for volume bits 0-2 to complete the fast portion of their transitions, which implies a possible connection to general gate propagation times. High-pass turn off from ch3/4 is aligned with regular ch3/4 transitions. It's the ch1/2 transition that therefore results in the short pulse, as it gets delayed 100ns + 176ns = 276ns before getting turned off again at the end of the 560ns machine cycle. When a volume bit is switched, any transition in progress on that bit is truncated and the signal for that bit begins reversing almost immediately. Attached is a capture from the scope of a relatively quiet section of a song intro, encoded to 16/8/0 PDM at 31KHz. The original.wav is the relevant portion of the original WAV file, pre-downsampled to 31KHz; sampled.wav is the capture from the scope, with the left channel being POKEY's output and the right channel being the RCA output. It's a 500KHz WAV file, don't try to play it in a regular media player! I recommend bringing it into Audacity. You'll need to lower the project sampling rate to 100KHz or so for it to actually play. I can capture higher sampling rates with correspondingly shorter times, but sound editors don't seem to like 2MHz tracks much. Comparing the waveforms, I'd say that the high-pass effects in the amplifiers are still a problem -- they're overemphasizing the fine channel's output. hicapture.7z 3 Quote Link to comment Share on other sites More sharing options...
Triads Posted November 25, 2020 Share Posted November 25, 2020 Hopefully someone can point me in the right direction.. Guess im about a year late to this game but im having an issue with Fujiconvert .3 Using most out of box settings, changing to NTSC and output type, but still gets stuck at the same point every time. Tried in Firefox, Chrome & IE with same results. I do have the latest Java Runtime installed.. The source MP3 is a typical low end 128 file.. I waited about 10 minutes, figured that was long enough. Using Windows 10 Pro Thanks Quote Link to comment Share on other sites More sharing options...
Xuel Posted November 25, 2020 Author Share Posted November 25, 2020 @Triads, how big is the mp3 file? Maybe try converting it to WAV first and/or truncating it before loading it into FujiConvert? Can you try opening the browser console window while it's stuck to see if there are any error messages? Quote Link to comment Share on other sites More sharing options...
Triads Posted November 25, 2020 Share Posted November 25, 2020 Yes there is an error - Security Error: Content at file:///I:/Altirra%20Test/fujiconvert-0.3/index.html may not load data from file:///I:/Altirra%20Test/fujiconvert-0.3/resample.js. Is there a fix for this? thanks Quote Link to comment Share on other sites More sharing options...
Xuel Posted November 25, 2020 Author Share Posted November 25, 2020 (edited) 6 minutes ago, Triads said: Yes there is an error - Security Error: Content at file:///I:/Altirra%20Test/fujiconvert-0.3/index.html may not load data from file:///I:/Altirra%20Test/fujiconvert-0.3/resample.js. Is there a fix for this? thanks I see. That means you're accessing the tool through a file:// URL instead of http://. That won't work because certain web APIs that the tool uses don't work with file:// URLs. If you download the code, then you need access it through an http server. But you can also just use the latest version (v0.3.3) directly at this URL with no need to download it: https://lybrown.github.io/fujiconvert/ I've updated the github latest release to point to v0.3.3 as well. Thanks for the heads up! Edited November 25, 2020 by Xuel Quote Link to comment Share on other sites More sharing options...
Triads Posted November 25, 2020 Share Posted November 25, 2020 Your link worked great.. I'll try a web server soon... I used to have a home made Parrot back in the late 80's.. Doesn't co me close to this.. Thanks for the help.. 1 Quote Link to comment Share on other sites More sharing options...
+Stephen Posted April 21, 2021 Share Posted April 21, 2021 On 11/25/2020 at 3:58 PM, Xuel said: I see. That means you're accessing the tool through a file:// URL instead of http://. That won't work because certain web APIs that the tool uses don't work with file:// URLs. If you download the code, then you need access it through an http server. But you can also just use the latest version (v0.3.3) directly at this URL with no need to download it: https://lybrown.github.io/fujiconvert/ I've updated the github latest release to point to v0.3.3 as well. Thanks for the heads up! I have no idea how I missed the Covox option before! Is there a way to easily provide different address decoding though? The convertor is only letting me use $D600 but my Covox is installed at $D700 since VBXE2 is at the other. Thanks. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 22, 2021 Share Posted April 22, 2021 On 11/25/2020 at 3:58 PM, Xuel said: I see. That means you're accessing the tool through a file:// URL instead of http://. That won't work because certain web APIs that the tool uses don't work with file:// URLs. If you download the code, then you need access it through an http server. But you can also just use the latest version (v0.3.3) directly at this URL with no need to download it: https://lybrown.github.io/fujiconvert/ I've updated the github latest release to point to v0.3.3 as well. Thanks for the heads up! so if not internet, no joy... unless you run your own HTTP server and do your own intranet rendition. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 22, 2021 Share Posted April 22, 2021 On 5/29/2018 at 7:21 PM, Xuel said: left 0 left 256 right 0 right 256 left 1 left 257 right 1 right 257 This saves me asking the question I was about to ask. Finally about to actually take advantage of this. Quote Link to comment Share on other sites More sharing options...
StickJock Posted April 22, 2021 Share Posted April 22, 2021 3 hours ago, flashjazzcat said: On 5/29/2018 at 1:21 PM, Xuel said: left 0 left 256 right 0 right 256 left 1 left 257 right 1 right 257 3 hours ago, flashjazzcat said: This saves me asking the question I was about to ask. Finally about to actually take advantage of this. At first glance, I thought that this was the Konami code! ? 1 Quote Link to comment Share on other sites More sharing options...
+Stephen Posted April 22, 2021 Share Posted April 22, 2021 4 hours ago, flashjazzcat said: This saves me asking the question I was about to ask. Finally about to actually take advantage of this. Dunno what this means, but if you're working on the PDM player, I was gonna ask if the 1088XEL / SIDE player you made has COVOX support. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 22, 2021 Share Posted April 22, 2021 33 minutes ago, Stephen said: Dunno what this means, but if you're working on the PDM player, I was gonna ask if the 1088XEL / SIDE player you made has COVOX support. It doesn't, and the stand alone PDM Player is long neglected. I'm actually working on the SIDE3 loader, which now has built in PDM support. Gonna add stereo, jog, pause, etc. Might be able to update the stand alone player after I get the massive firmware drop done. 1 1 Quote Link to comment Share on other sites More sharing options...
Mathy Posted April 22, 2021 Share Posted April 22, 2021 Hello guys On 4/21/2021 at 10:36 PM, Stephen said: Is there a way to easily provide different address decoding though? The convertor is only letting me use $D600 but my Covox is installed at $D700 since VBXE2 is at the other. Thanks. And some of us prefer their Covox to be at $D280, since $D6xx is taken by PBI devices and VBXE has to live at $D7xx. Sincerely Mathy 1 Quote Link to comment Share on other sites More sharing options...
+Stephen Posted April 23, 2021 Share Posted April 23, 2021 2 hours ago, Mathy said: On 4/21/2021 at 4:36 PM, Stephen said: Is there a way to easily provide different address decoding though? The convertor is only letting me use $D600 but my Covox is installed at $D700 since VBXE2 is at the other. Thanks. And some of us prefer their Covox to be at $D280, since $D6xx is taken by PBI devices and VBXE has to live at $D7xx. Sincerely Mathy I agree - any program that uses Covox, should allow D280, D600, D700. All three are valid and at times, all 3 address ranges are in use. 1 Quote Link to comment Share on other sites More sharing options...
