canadianatari Posted June 5, 2018 Share Posted June 5, 2018 So here's what happened: I bought an Atari 2600 joystick. It worked fine, but there was a rattle inside. Open it up, nothing in the main chassis. Then I realise the boot is the part that's making the rattling noise. I take out the plastic stick, and out falls four pieces of what looks like a black plastic ring. From what I researched, this is probably the retaining ring. However, after reassembling the controller, it still works, and it works better than it did before! If what I did was wrong, let me know. Quote Link to comment Share on other sites More sharing options...
jaybird3rd Posted June 6, 2018 Share Posted June 6, 2018 Welcome to AtariAge! The retaining ring (which holds the rubber boot in place) snaps in place on the outside of the CX-40 joystick, so it would seem odd that pieces of it would end up on the inside. The center hole in the top of the joystick—the one the handle is inserted through—has a thin raised "lip" around it, underneath the rubber boot and retaining ring, and I suspect that this broke off due to age or use, or both. I've had the same thing happen with several of my joysticks, but I haven't noticed any adverse affects; in fact, I've noticed that some joysticks—perhaps later revisions—omitted this "lip" entirely. 1 Quote Link to comment Share on other sites More sharing options...
canadianatari Posted June 6, 2018 Author Share Posted June 6, 2018 Wow, didn't know that! Good to know my controllers aren't missing vital pieces. Thanks for the help! Quote Link to comment Share on other sites More sharing options...
