jbay-75 Posted June 5, 2003 Share Posted June 5, 2003 I'm working on some of my old 2600 joysticks and decided I needed some of the slide-on connectors that join the joystick cable to the PCB board as some of them seemed to be making bad connections with the wire in the cable. I thought I could re-use the old ones after pulling them off and re-stripping the wire but the insulation is stuck in them. Does anyone know where to find these? I've looked around a bit on best-electronics and at RadioShack with no luck. Is this a common part or was it made just for the joysticks? As usual, any help is much appreciated Link to comment Share on other sites More sharing options...
Nukey Shay Posted June 5, 2003 Share Posted June 5, 2003 How would they be making a bad connection? You could just pry them open with an xacto knife and re-crimp them around the wire...right? Or even solder the bare wires right to the circuit board. Link to comment Share on other sites More sharing options...
jbay-75 Posted June 5, 2003 Author Share Posted June 5, 2003 It's the prying open part I had trouble with.... I've lost any of the connectors I pulled off by now and I'd rather they look and work like an orignal so I'd rather not solder them to the board. But is that the only option at this point? Link to comment Share on other sites More sharing options...
Nukey Shay Posted June 5, 2003 Share Posted June 5, 2003 The connectors were manufactured for the joysticks specifically I think. Those are the options unless you'd want to get them from another stick. I suppose you could bend up some aluminum and make your own. I still don't understand about them being loose...you could have just bent the edges of the connectors closer to give a tighter fit around the circuit board or crimped the end to bite better on the wire Link to comment Share on other sites More sharing options...
jbay-75 Posted June 7, 2003 Author Share Posted June 7, 2003 The connectors in question were crimped around nothing but insulation. It looked like at one point a few strands of wire had come out of the end and made contact with the connector but they had since broken off. Oh well. I'll come up with something. I don't have any complete controllers for those cables to go with anyway as I had to scrap some broken parts etc. so it's no emergency. Just would have been nice to be able to buy a little box of those things. Thanks for your help though Nukey. Link to comment Share on other sites More sharing options...
CPUWIZ Posted June 7, 2003 Share Posted June 7, 2003 You should be able to find those connectors in an automotive shop. Link to comment Share on other sites More sharing options...
Archived
This topic is now archived and is closed to further replies.
