StanJr Posted June 19, 2018 Share Posted June 19, 2018 Can you explain what you are doing to exploit this glitch? I cannot reproduce it on actual hardware. A few updates for me. Raft Rider is really dragging me down... Raft Rider 3988 Shark Attack 139 Lost Luggage 4112 (had a killer game, no idea how Leto got 7K. That's madness) Quote Link to comment Share on other sites More sharing options...
AtariWarlord Posted June 19, 2018 Share Posted June 19, 2018 I'VE GOT BLISTERS ON ME FINGERS! Seriously, those were eight hard-earned points. Pele's Soccer Game 52BB 8-15 Quote Link to comment Share on other sites More sharing options...
Leto27 Posted June 19, 2018 Share Posted June 19, 2018 Can you explain what you are doing to exploit this glitch? I cannot reproduce it on actual hardware. A few updates for me. Raft Rider is really dragging me down... Raft Rider 3988 Shark Attack 139 Lost Luggage 4112 (had a killer game, no idea how Leto got 7K. That's madness) Raft Rider is really easy as soon you get how to stop the movement one rail to another, as the game manual says: you can tap left to stop the raft or if you calculate really well you can get the money bags between the movement from one rail to another, every three bags you get one extra life, the enemy here is boredom. as for Shark attack, I use Stella 3.4.1 and 4.7.3 and the page free80sarcade and neither I can get the glitch to work, probably is a glitch only present in Stella 5.0.1. In lost luggage there are some levels that require no effort to pass, just stand in the middle and the all the way up, and all the suitcases will go directly to you Quote Link to comment Share on other sites More sharing options...
nads Posted June 19, 2018 Share Posted June 19, 2018 (edited) Can you explain what you are doing to exploit this glitch? I cannot reproduce it on actual hardware. A few updates for me. Raft Rider is really dragging me down... Raft Rider 3988 Shark Attack 139 Lost Luggage 4112 (had a killer game, no idea how Leto got 7K. That's madness) Raft Rider is really easy as soon you get how to stop the movement one rail to another, as the game manual says: you can tap left to stop the raft or if you calculate really well you can get the money bags between the movement from one rail to another, every three bags you get one extra life, the enemy here is boredom. as for Shark attack, I use Stella 3.4.1 and 4.7.3 and the page free80sarcade and neither I can get the glitch to work, probably is a glitch only present in Stella 5.0.1. In lost luggage there are some levels that require no effort to pass, just stand in the middle and the all the way up, and all the suitcases will go directly to you This glitch has been done on Hardware as well I'm assuming the part that you cant get to work is the disappearing Shark? That's the hardest to accomplish, it does take patience. Follow the video, that includes the configuration of pearls at the start. To get the rapid pearls just gently tap up to the pearl from underneath and if done correctly the counter will spin. Cash them in in, the head to the top, as the Shark passes go through the exit and keep going until you hear the sound. Another glitch I discovered to day is the octopus? He can get stuck in the maze and cant get out, then you just get the perks! Good Luck Edited June 19, 2018 by nads Quote Link to comment Share on other sites More sharing options...
+stephena Posted June 19, 2018 Share Posted June 19, 2018 I use Stella 3.4.1 and 4.7.3 and the page free80sarcade and neither I can get the glitch to work, probably is a glitch only present in Stella 5.0.1. If you see a 'glitch' in Stella 5.x and not in older versions, more likely than not it's a problem in your code, not in Stella. Yes, Stella 5.x really is that much better than older versions. You really shouldn't be using anything older than the 5.x versions for testing during ROM development. The improvements in the latest versions are extreme. The same goes for testing with other emulators. If you see something happening (or not) in Stella 5.x and not in other emulators, you should definitely look into it. The improvements in Stella 5.x are massive, and in several cases more accurate than any other emulator out there (except Stellerator, the TIA core upon which Stella is based). 3 Quote Link to comment Share on other sites More sharing options...
Novastar Posted June 19, 2018 Share Posted June 19, 2018 (edited) Pele: 13 - 14 Edited June 19, 2018 by Novastar Quote Link to comment Share on other sites More sharing options...
+KaeruYojimbo Posted June 19, 2018 Share Posted June 19, 2018 Lost Luggage - 2,397 Soccer - 4-7 Quote Link to comment Share on other sites More sharing options...
Hank Rearden Posted June 19, 2018 Share Posted June 19, 2018 Raft Rider 11,022 Lost Luggage 2,539 Shark Attack 115 Quote Link to comment Share on other sites More sharing options...
G-type Posted June 19, 2018 Share Posted June 19, 2018 (edited) Pele = 3 -10 Lost Luggage = 1796 Shark Attack = 74 Raft Rider = 3486 These games are all pretty bad. Don't think I will want to suffer through them more than I already did. Edited June 19, 2018 by G-type Quote Link to comment Share on other sites More sharing options...
S.BAZ Posted June 19, 2018 Share Posted June 19, 2018 Raft Rider: 4,631 Shark Attack: 107 Pele's: 6-10 Lost Luggage: 1,014 ok I'm on the board 1 Quote Link to comment Share on other sites More sharing options...
S.BAZ Posted June 20, 2018 Share Posted June 20, 2018 Raft Rider improvement! 14,771 Quote Link to comment Share on other sites More sharing options...
AtariWarlord Posted June 20, 2018 Share Posted June 20, 2018 Raft Rider 11,973 Game 1BB. I've given up on trying to get the gold nuggets; for me it's a suicide mission. Quote Link to comment Share on other sites More sharing options...
AtariWarlord Posted June 20, 2018 Share Posted June 20, 2018 These games are all pretty bad. Don't think I will want to suffer through them more than I already did. I kind of like Pele's Soccer and Lost Luggage but I agree: Raft Rider is pretty bad and Shark Attack is one of the most infamously awful games in the Atari 2600 library. It's too bad because the basic idea is strong but the execution is terrible. Quote Link to comment Share on other sites More sharing options...
G-type Posted June 20, 2018 Share Posted June 20, 2018 I'll admit it's kind of cute when the luggage opens up to reveal all the miscellaneous clothing. It's still a very, very, poor-man's Ka-boom. Eggomania is better too. Pele's soccer had a little bit of potential but the controls just were so clunky, and the graphics are just blobs... might have worked better as a foosball game. Shark Attack, could have potentially been fun if it had been programmed better. I liked the idea of having to drop off the diamonds in the middle. a nice little risk/reward mechanic: go for it? or drop off what you got so far? Quote Link to comment Share on other sites More sharing options...
toiletunes Posted June 20, 2018 Share Posted June 20, 2018 Getting better Quote Link to comment Share on other sites More sharing options...
StanJr Posted June 21, 2018 Share Posted June 21, 2018 Man, I like crappy games. With the exception of Raft Rider, I enjoy all three of the remaining games on this list. Sure, they aren't Pitfall! Ii, but they ain't Mythicon games either... 1 Quote Link to comment Share on other sites More sharing options...
+KaeruYojimbo Posted June 21, 2018 Share Posted June 21, 2018 but they ain't Mythicon games either... I'd take Sorcerer over Shark Attack 1 Quote Link to comment Share on other sites More sharing options...
toiletunes Posted June 21, 2018 Share Posted June 21, 2018 that's a trash tossup (I like both) Quote Link to comment Share on other sites More sharing options...
toiletunes Posted June 21, 2018 Share Posted June 21, 2018 Quote Link to comment Share on other sites More sharing options...
5x7 Posted June 22, 2018 Share Posted June 22, 2018 (edited) Soccer ug tough game 2-9 Shark Attack would be fun with better navigation 73 Lost luggage fun and cute 2296 Raft Rider... interesting 4469 Edited June 22, 2018 by 5x7 Quote Link to comment Share on other sites More sharing options...
nads Posted June 22, 2018 Share Posted June 22, 2018 Improvement Soccer Soccer Game 52: 11 Goals Quote Link to comment Share on other sites More sharing options...
Vocelli Posted June 22, 2018 Author Share Posted June 22, 2018 Vocelli: Been busy with work. Couldn't play as much. Raft Rider: 8734 I like this game... relaxing and it doesn't kill my hands/wrists. Shark Attack: 122 I like this game... I don't mind the sticking to the walls. Lost Luggage: 3222 Hard on the hands... The game needs something more. Pele: 2-5 I dont like this game... Very hard on my hands/wrist. Quote Link to comment Share on other sites More sharing options...
Lauren Tyler Posted June 22, 2018 Share Posted June 22, 2018 I admit I haven't submitted any more scores. That's because of issues at the store causing me to log more hours than I expected I would have to. Unfortunately, since we're near the end, I don't think I'm going to try submitting any more. Quote Link to comment Share on other sites More sharing options...
classicgamer_27330 Posted June 22, 2018 Share Posted June 22, 2018 for the first time I took a 1-0 lead, but slowly went down hill and the 2nd half sucked Quote Link to comment Share on other sites More sharing options...
Novastar Posted June 23, 2018 Share Posted June 23, 2018 Can't seem to do better at lost luggage. 1264 Quote Link to comment Share on other sites More sharing options...
