+xucaen Posted June 28, 2018 Share Posted June 28, 2018 (edited) Sorry for the newbie question. I found an 800xl on ebay and want to get an A/V cable for it. (My TV is a large CRT with several A/V inputs). The INTERNET seems to be full of discussions about s-video and video mods and such. I am just looking for a standard A/V cable for the 800xl. Where is the best place to buy one? (I'm in Massachusetts) I looked on ebay and could only find this one: https://www.ebay.com/itm/Color-Composite-Video-A-V-Monitor-Cable-Atari-DIN-to-RCA-for-800-XL-XE-6-New/130888382784?hash=item1e798e3940:g:dU4AAMXQbcRQ4zp6 If this is the one I need I'll buy it, just looking for some advice. Thanks! \\//, Edit: I also found it on Best Electronics, I am thinking this is the one I should get> CB101280E2 Atari Enhanced 2nd Generation Composite Video Cable $17.95 http://www.best-electronics-ca.com/power%20guide.htm#Composite Edited June 28, 2018 by xucaen Quote Link to comment Share on other sites More sharing options...
SS Posted June 28, 2018 Share Posted June 28, 2018 (edited) This is the exact one that I use and it makes everything look fantastic on my 720p TV. Great seller too. https://m.ebay.com/itm/6-Atari-Video-A-V-TV-Cable-Composite-Video-Audio-800-800XL-65XE-130XE-/232541246443 EDIT- That BEST cable should fit your needs quite nicely as well. Edited June 28, 2018 by SS 2 Quote Link to comment Share on other sites More sharing options...
256 colors Posted June 28, 2018 Share Posted June 28, 2018 I got my bits from here https://lotharek.pl/very happy with the fast shipping non hassles PWR3 - ATARI 8bit HQ power supplyHQ audio/video cableSIO2SD cased black hope that helps 1 Quote Link to comment Share on other sites More sharing options...
SS Posted June 28, 2018 Share Posted June 28, 2018 Sorry for the newbie question. I found an 800xl on ebay Just out of curiosity, which eBay auction did you win? I have been watching a few 800XLs recently and wonder if you got one of them. Quote Link to comment Share on other sites More sharing options...
Paul Westphal Posted June 28, 2018 Share Posted June 28, 2018 It's the one from Hercules workshop in Canada. " 6' Atari Video A/V Cable ( composite Video + audio ) - 800, 800xl... Paul 1 Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted June 28, 2018 Share Posted June 28, 2018 (edited) Keep in mind that a stock NTSC 800XL only has Audio, Composite and Luma (greyscale) output, and is missing Chroma. For Luma+Chroma (SVideo) internal mods are needed... If all you need is Audio+Composite, you'll be fine. Edited June 28, 2018 by Nezgar 1 Quote Link to comment Share on other sites More sharing options...
+xucaen Posted June 28, 2018 Author Share Posted June 28, 2018 Keep in mind that a stock NTSC 800XL only has Audio, Composite and Luma (greyscale) output, and is missing Chroma. For Luma+Chroma (SVideo) internal mods are needed... If all you need is Audio+Composite, you'll be fine. When I was searching for a cable I ran into a lot of this kind of information. I have no idea what chroma is it why I would want it. If audio+composite will give me sounds and a color picture on my tv then that's what I want. Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted June 28, 2018 Share Posted June 28, 2018 When I was searching for a cable I ran into a lot of this kind of information. I have no idea what chroma is it why I would want it. If audio+composite will give me sounds and a color picture on my tv then that's what I want. Yep, composite will work just fine, and is still much much better than the RF channel 2/3 output. Luma+chroma (s-video) just improves the picture quality/sharpness further, which is optional, and as you mentioned don't need anyway. 1 Quote Link to comment Share on other sites More sharing options...
BillC Posted June 28, 2018 Share Posted June 28, 2018 (edited) When I was searching for a cable I ran into a lot of this kind of information. I have no idea what chroma is it why I would want it. If audio+composite will give me sounds and a color picture on my tv then that's what I want. Chroma + Luma(AKA s-video) is normally better quality video than composite. 8-Bit Classics sells several video cables for the Atari8, with 2 giving the option of composite & s-video, the chroma/luma output can be mini-DIN4(normal s-video) or dual RCA(Commodore 1702 monitor) Their cables including s-video only cost $2 more than their composite only cable, and allow the option of getting the better quality video if you connect chroma to the monitor port of your 800XL. Composite + dual mono audio: $9.99 + S&H Composite + mini-DIN4 s-video + dual mono audio $11.99 + S&H Composite + dual-RCA chroma/luma + dual mono audio: $11.99 + S&H Edited June 28, 2018 by BillC 1 Quote Link to comment Share on other sites More sharing options...
Wilheim Posted July 1, 2018 Share Posted July 1, 2018 I have one A/V composite cable I recently made for sale. 10 ft long and works great! 25 USD, shipping costs included, and it takes about 2-3 weeks to arrive the USA aprox. Regards! Quote Link to comment Share on other sites More sharing options...
Level42 Posted July 1, 2018 Share Posted July 1, 2018 (edited) You can buy any run-of-the-mill 5pin DIN male to 4x RCA cable for about 3 or 4 dollars or euros and it will work fine. Just don't expect the yellow connector to be the composite video, it's probably another one. Simply try all connectors and you'll get a picture from one, and sound from another. https://www.ebay.com/itm/0-5M-1-5M-5-PIN-MIDI-DIN-PLUG-to-4-RCA-PHONO-MALE-PLUGS-AUDIO-CABLE-LEAD-CORDS/282487178472?hash=item41c58c44e8%3Am%3AmG0XSi5bFO4zoh6rkmLlHSg&var=581636762418 (Be sure to get a long enough one, 0,5m is usually too short, 1,5m is usually OK. Edited July 1, 2018 by Level42 1 Quote Link to comment Share on other sites More sharing options...
