tyranthraxus Posted June 7, 2003 Share Posted June 7, 2003 Could you use the dual fire buttons on a Colecovision or 7800? John Link to comment Share on other sites More sharing options...
Brad2600 Posted June 7, 2003 Share Posted June 7, 2003 The Colecovison and Intellivison have their own versions of the Wico. They're just harder to find. I don't believe the 5200 version is compatible..though you can research just to be sure. Link to comment Share on other sites More sharing options...
Video Posted June 8, 2003 Share Posted June 8, 2003 Coleco and Intellivision are both 9pin ports. The 5200 is 15 pin. If you know the pinouts on both systems and the 5200 however, you should be able to build an adaptor. Then again, Wico's for 5200 are analog aren't they? The intellivision and colecovision are both digital. Unless you had something kind of like a reversed masterplay circut, it'd still not work. Unless you just really wan't to undertake the task of porting the controller, it's probably not worth it. Link to comment Share on other sites More sharing options...
tyranthraxus Posted June 8, 2003 Author Share Posted June 8, 2003 Well I was wondering if it would be possible to mod it for a Coleco Y adapter. I am searching for 2 button joysticks other than the 7800's that might be useable on the CV. It sounds like too much work now. John Link to comment Share on other sites More sharing options...
badbrad Posted June 8, 2003 Share Posted June 8, 2003 Remember, the 5200 Wico is still an analog joystick. The other consoles are digital. Link to comment Share on other sites More sharing options...
Video Posted June 11, 2003 Share Posted June 11, 2003 Oh, forgot to mention, in addition to both systems being digital, the Intellivision is also a 16 position controller rather than the typical 8. Of course, if you just want the two fire buttons, that should be easy, but you'd have to hold two stics, and moving a stick onehanded is kinda difficult (especially with the coleco's stubby thing) Link to comment Share on other sites More sharing options...
Archived
This topic is now archived and is closed to further replies.
