candiru Posted June 7, 2003 Share Posted June 7, 2003 I recently acquired a 4-port 5200. I knew these things were big, but I was simply not prepared for the sheer bulk of this monster. It is complete except that the plug that should go from the power supply to the switchbox has been neatly snipped off. I bought the necessary plug from Radio Shack and wired it in. Unfortunately that's were my progress has stopped. Smoke began curling out of the switchbox as soon as I hooked the system up and ran power through it. I've attached a photo of the circuit board and circled the component that burned. It doesn't appear to have damaged anything else. I'm not too experienced with repairing electronics so I was wondering if replacing this component will likely solve my problem or if there is an underlying fault that caused this piece to get hot. Thanks in advance for any advice you can give. Link to comment Share on other sites More sharing options...
liquid_sky Posted June 7, 2003 Share Posted June 7, 2003 smoking switchbox eh? sounds like you got the method man edition Link to comment Share on other sites More sharing options...
CPUWIZ Posted June 7, 2003 Share Posted June 7, 2003 I don't know if it will fix the problem if you replace the component but this is what you need to replace it: 2N3906 PNP Switching Transistor Link to comment Share on other sites More sharing options...
Albert Posted June 7, 2003 Share Posted June 7, 2003 Funny, I had a four port switchbox smoke on me a few days ago as well. I haven't opened it yet to see what particular component fried, but it would be nice to repair it if possible, as those switchboxes aren't exactly easy to come by.. ..Al Link to comment Share on other sites More sharing options...
CPUWIZ Posted June 7, 2003 Share Posted June 7, 2003 I just cracked one of my broken ones open to verify the transistor part number and noticed that it's quite different. Check it out. Link to comment Share on other sites More sharing options...
Dantaipan Posted June 7, 2003 Share Posted June 7, 2003 Sounds like you wired the PS plug wrong. How do I know this? I did the same thing! Doh! Good news is it probably didn't harm the console itself. Double check the wires are connected right before trying/frying another switch. Link to comment Share on other sites More sharing options...
candiru Posted June 7, 2003 Author Share Posted June 7, 2003 You may be right yodan. The plug I bought is the 2 part type where you buy the tip and it has 2 little prongs on the back side. Then you insert the prongs into another piece with wire leads that you attach to the power supply. (am I making any sense?) Upon closer inspection it seems that the tip is (+) or (-) depending on which direction you plug it in. I disconnected it earlier so I don't know which way I had it hooked up when it smoked. Must be more observant from now on. Oh well, hopefully it will be set right with the new piece. @CPUWIZ, that's weird I guess not all of them were 300 ohm input equipped. It also appears that part of my circuitry more closely resembles a log of bologna than yours. Link to comment Share on other sites More sharing options...
candiru Posted June 8, 2003 Author Share Posted June 8, 2003 Just so I don't screw this thing up more than I have, will this component work properly? Radio Shack part #276-1604 Link to comment Share on other sites More sharing options...
CPUWIZ Posted June 8, 2003 Share Posted June 8, 2003 Probably, although it doesn't say equivalent, it says similar. Link to comment Share on other sites More sharing options...
Pitfall Harry Posted June 8, 2003 Share Posted June 8, 2003 The original 2N3906 PNP transistor is rated for 500mW power dissipation. The suggested replacement transistor is only rated for 350 mW. So, it might work or it might burn out, depending on how much the game console downloads the ciruitry. It will "probably" work. But if you could find a transistor that was rated for 500 mW, then you'd know for sure. Ben Link to comment Share on other sites More sharing options...
Archived
This topic is now archived and is closed to further replies.
