tearex Posted June 9, 2003 Share Posted June 9, 2003 Hi "techies", I have a problem with my six-switcher PAL 2600: The circuit that produces the 6 MHz sound subcarrier is constantly detuning itself. I already drilled a hole into the bottom of the case so that I can adjust the tunable inductivity (L2, I think, in the AtriAge provided schematic) with a match or so, without opening the case. However, it's getting worse and worse and sometimes I can't tune it at all. This means the "real sound" will be soft to nonexistent and there will be lots of humming and noise. If I let the console run for a few hours then I can normally tune it after that, but when it's still cold it is very problematic. Do you know of a fix for this problem? I can handle soldering and I can read schematics, but I'm not enough of a "buff" to know an answer myself. Thanks a lot in advance, Link to comment Share on other sites More sharing options...
Pixellated Ghost Posted June 15, 2003 Share Posted June 15, 2003 There's a transistor near that coil that is connected to it, try replacing that. I can't say for sure exactly what it is, other than that it's NPN. While troubleshooting mine I replaced it with one from my parts bin so the type probably isn't horribly important. Link to comment Share on other sites More sharing options...
tearex Posted June 16, 2003 Author Share Posted June 16, 2003 Somehow, someway, bending the capacitors in that part of the circuit back and forth a bit did it for me. Suddenly the noise disappeared. A hair-width tear in one of the capacitor's maybe? Well, whatever it was it has worked flawlessly for some days now, even some good knocks didn't start the problem again. I also fixated that darn coil with some glue once and for all after careful fine-tuning as the core was already getting quite loose from so much "tuning" attempts. And I also learned a new fact, the subcarrier is actually 5.5MHz here in continental Europe, not 6Mhz as it is in the UK. So... NTSC = Never Twice the Same Color, PAL = never twice the same norm, it seems. Link to comment Share on other sites More sharing options...
Archived
This topic is now archived and is closed to further replies.
