RSS Bot Posted August 27, 2018 Share Posted August 27, 2018 The Suburban Chicago Atarians (S.C.A.T.) is represented on the Pooldisk with a couple hundred disks from their public domain library. As with much of the Pooldisk, there is some identifiable bitrot in a small number of the disks. In particular, checking the file integrity found four disks with simple single empty sector in the chain. 039.atr: Sector 217 empty (CREAPCAV.BAS). I found this game also on Thumpnugget's ANTIC disk archive, so we'll use that to fix it. 056.atr: Sector 17 empty (DOS.SYS). The DOS is damaged, we can fix it using the DOS from another disk. 094_b.atr. Sector 634 empty (STARTUP.BAS). The menu program is damaged, we can fix it using the menu on 095.atr. 101.atr: Sector 351 empty (SPECIAL0.DEL). The sector missing looks like it should be all zeros, which I confirmed after finding the same file on Bellcom disk 218. The fixes are all a simple application of the tool we developed in earlier posts: Attached File(s) scat1.zip (156.13KB)Number of downloads: 0 http://atariage.com/forums/blog/734/entry-14993-some-scat-disk-fixes/ Link to comment Share on other sites More sharing options...
