RevEng Posted September 30, 2018 Share Posted September 30, 2018 Moving this conversation to it's own thread. You can do a minikernel (mostly) in bB. I don't know if thats helpful or just trying to dodge things that should be confronted head on. ie you don't really need to know much assembly but you still need to know nuts and bolts (and you need enough assembly to understand what you get from bB anyway) This code example wouldn't compile for me, not sure if I broke something in my bB setup? got the error : old value: $f699 new value: $f69c old value: $00c6 new value: $00c9 segment: fffc vs current org: 10004 2190 bytes of ROM space left D:\Applications\2600Development\Projects\Examples\x6_1_5.bas.asm (2841): error: Origin Reverse-indexed. It works for me - I get the report due to shifting rom - but the compiled rom works. The values reported are slightly different for me. Are you using the latest bB? I forget at which release it happened, but the dasm included with the my bB has fixes specifically related to shifting ROM. I'm using 1.1dreveng41 Quote Link to comment Share on other sites More sharing options...
RevEng Posted September 30, 2018 Author Share Posted September 30, 2018 Interesting. Is this on Windows, OSX, or Linux? What version does DASM report during the bB compile output? Quote Link to comment Share on other sites More sharing options...
+Muddyfunster Posted September 30, 2018 Share Posted September 30, 2018 Windows 10,DASM is version 2.20.11 20140304 (also using VBB) Quote Link to comment Share on other sites More sharing options...
RevEng Posted September 30, 2018 Author Share Posted September 30, 2018 Huh. This is very weird territory. I'm using the same, but on Linux. Apparently that's making the difference. When I get a chance, I'll check it out on my Windows 7 box. [edit] can I get a copy of your x6_1_5.bas.asm and x6_1_5.bas.lst files? Also, your D:\Applications\2600Development\Projects\Examples\ directory doesn't have any other assembly files, does it? i.e. custom bB files. Quote Link to comment Share on other sites More sharing options...
bogax Posted September 30, 2018 Share Posted September 30, 2018 (edited) for what it's It works the the same for me with bB.1.1d.reveng41 (which I just downloaded, had been using 37) on Windows 8.1 Get the same warnings but the .bin works (I haven't actually looked at the code produced) I don't use VBB Edited September 30, 2018 by bogax 1 Quote Link to comment Share on other sites More sharing options...
+Karl G Posted September 30, 2018 Share Posted September 30, 2018 It works for me on Mac with v1.01dreveng40. I didn't know I was one version behind. 1 Quote Link to comment Share on other sites More sharing options...
+Muddyfunster Posted October 3, 2018 Share Posted October 3, 2018 Huh. This is very weird territory. I'm using the same, but on Linux. Apparently that's making the difference. When I get a chance, I'll check it out on my Windows 7 box. [edit] can I get a copy of your x6_1_5.bas.asm and x6_1_5.bas.lst files? Also, your D:\Applications\2600Development\Projects\Examples\ directory doesn't have any other assembly files, does it? i.e. custom bB files. I moved the file to it's own empty project folder and the issue remained. The path you noted above was also clear of anything odd or custom. requested files attached, thanks for looking into it. x6_1_5.bas.asm x6_1_5.bas.lst Quote Link to comment Share on other sites More sharing options...
bogax Posted October 4, 2018 Share Posted October 4, 2018 I moved the file to it's own empty project folder and the issue remained. The path you noted above was also clear of anything odd or custom. requested files attached, thanks for looking into it. looks like you've got extra characters in the score graphics 1 Quote Link to comment Share on other sites More sharing options...
