MemberAtarian Posted October 5, 2018 Share Posted October 5, 2018 Hi guys. I just realized this week that you can use the ST Mouse with the VCS and I was amazed, so I got one and started coded (I use bB). I disassembled the mouse, so I could figure out how it determinates movement of the ball. So the joy0up and joy0down are the horizontal way of movement, so let's take the example. I understand that there is a rotation, for one way, it's 00 >> 01 >> 11 >>10 and 00 >> 10 >> 11 >> 01 for the other direction. So I made my code: if !joy0up && !joy0down && !a{0} && !a{1} then a{0} = 0: a{1} = 0: a{2} = 0 : a{3} = 0 : goto Dir if !joy0up && !joy0down && a{0} && !a{1} then a{0} = 0: a{1} = 0: a{2} = 1 : goto Dir if !joy0up && !joy0down && !a{0} && a{1} then a{0} = 0: a{1} = 0: a{3} = 1 : goto Dir if joy0up && !joy0down && a{0} && !a{1} then a{0} = 1: a{1} = 0: a{2} = 0 : a{3} = 0 : goto Dir if joy0up && !joy0down && a{0} && a{1} then a{0} = 1: a{1} = 0: a{2} = 1 : goto Dir if joy0up && !joy0down && !a{0} && !a{1} then a{0} = 1: a{1} = 0: a{3} = 1 : goto Dir if joy0up && joy0down && a{0} && a{1} then a{0} = 1: a{1} = 1: a{2} = 0 : a{3} = 0 : goto Dir if joy0up && joy0down && !a{0} && a{1} then a{0} = 1: a{1} = 1: a{2} = 1 : goto Dir if joy0up && joy0down && a{0} && !a{1} then a{0} = 1: a{1} = 1: a{3} = 1 : goto Dir if !joy0up && joy0down && !a{0} && a{1} then a{0} = 0: a{1} = 1: a{2} = 0 : a{3} = 0 : goto Dir if !joy0up && joy0down && !a{0} && !a{1} then a{0} = 0: a{1} = 1: a{2} = 1 : goto Dir if !joy0up && joy0down && a{0} && a{1} then a{0} = 0: a{1} = 1: a{3} = 1 : goto Dir Dir if player0x>15 && a{3} then player0x=player0x-1 if player0x<138 && a{2} then player0x=player0x+1 So joy0up sets a{0} and joy0down set a{1}, if it's the same as it was in the previous turn, there is no movement, if it's changed, depending on that rotation, the cursor have to move. I would do the same with the vertical movement. This could work, but it only does if you are really careful with moving the mouse, else, it nudges back and forth. Can you tell we what I should change? 1 Quote Link to comment Share on other sites More sharing options...
MemberAtarian Posted October 6, 2018 Author Share Posted October 6, 2018 (edited) rem batari Basic Program rem created 2018.10.05. 20:28:39 by Visual bB Version 1.0.0.568 set romsize=4k set tv = ntsc player0x=70: player0y=60 Arrow player0: %000110 %101110 %111100 %111111 %111110 %111100 %111000 %110000 %100000 end if player0x<15 then player0x=15 if player0x>138 then player0x=138 if player0y<10 then player0y=10 if player0y>88 then player0y=88 SSSS if !joy0up && !joy0down then goto Dir1 if joy0up && !joy0down then goto Dir2 if joy0up && joy0down then goto Dir3 if !joy0up && joy0down then goto Dir4 Dir1 if !a{0} && !a{1} then a{0} = 0: a{1} = 0: a{2} = 0 : a{3} = 0 : goto Dir if a{0} && !a{1} then a{0} = 0: a{1} = 0: a{2} = 1 : a{3} = 0 : goto Dir if !a{0} && a{1} then a{0} = 0: a{1} = 0: a{2} = 1 : a{3} = 1 : goto Dir if a{0} && a{1} then a{0} = 0: a{1} = 0: a{2} = 0 : a{3} = 0 : goto Dir Dir2 if a{0} && !a{1} then a{0} = 1: a{1} = 0: a{2} = 0 : a{3} = 0 : goto Dir if a{0} && a{1} then a{0} = 1: a{1} = 0: a{2} = 1 : a{3} = 0 : goto Dir if !a{0} && !a{1} then a{0} = 1: a{1} = 0: a{2} = 1 : a{3} = 1 : goto Dir if !a{0} && a{1} then a{0} = 1: a{1} = 0: a{2} = 0 : a{3} = 0 : goto Dir Dir3 if a{0} && a{1} then a{0} = 1: a{1} = 1: a{2} = 0 : a{3} = 0 : goto Dir if !a{0} && a{1} then a{0} = 1: a{1} = 1: a{2} = 1 : a{3} = 0 : goto Dir if a{0} && !a{1} then a{0} = 1: a{1} = 1: a{2} = 1 : a{3} = 1 : goto Dir if !a{0} && !a{1} then a{0} = 1: a{1} = 1: a{2} = 0 : a{3} = 0 : goto Dir Dir4 if !a{0} && a{1} then a{0} = 0: a{1} = 1: a{2} = 0 : a{3} = 0 : goto Dir if !a{0} && !a{1} then a{0} = 0: a{1} = 1: a{2} = 1 : a{3} = 0 : goto Dir if a{0} && a{1} then a{0} = 0: a{1} = 1: a{2} = 1 : a{3} = 1 : goto Dir if a{0} && !a{1} then a{0} = 0: a{1} = 1: a{2} = 0 : a{3} = 0 : goto Dir Dir if player0x>16 && a{2} && a{3} then player0x=player0x-2 if player0x<137 && a{2} && !a{3} then player0x=player0x+2 if !joy0left && !joy0right then goto Dir5 if joy0left && !joy0right then goto Dir6 if joy0left && joy0right then goto Dir7 if !joy0left && joy0right then goto Dir8 Dir5 if !a{4} && !a{5} then a{4} = 0: a{5} = 0: a{6} = 0 : a{7} = 0 : goto DirX if a{4} && !a{5} then a{4} = 0: a{5} = 0: a{6} = 1 : a{7} = 0 : goto DirX if !a{4} && a{5} then a{4} = 0: a{5} = 0: a{6} = 1 : a{7} = 1 : goto DirX if a{4} && a{5} then a{4} = 0: a{5} = 0: a{6} = 0 : a{7} = 0 : goto DirX Dir6 if a{4} && !a{5} then a{4} = 1: a{5} = 0: a{6} = 0 : a{7} = 0 : goto DirX if a{4} && a{5} then a{4} = 1: a{5} = 0: a{6} = 1 : a{7} = 0 : goto DirX if !a{4} && !a{5} then a{4} = 1: a{5} = 0: a{6} = 1 : a{7} = 1 : goto DirX if !a{4} && a{5} then a{4} = 1: a{5} = 0: a{6} = 0 : a{7} = 0 : goto DirX Dir7 if a{4} && a{5} then a{4} = 1: a{5} = 1: a{6} = 0 : a{7} = 0 : goto DirX if !a{4} && a{5} then a{4} = 1: a{5} = 1: a{6} = 1 : a{7} = 0 : goto DirX if a{4} && !a{5} then a{4} = 1: a{5} = 1: a{6} = 1 : a{7} = 1 : goto DirX if !a{4} && !a{5} then a{4} = 1: a{5} = 1: a{6} = 0 : a{7} = 0 : goto DirX Dir8 if !a{4} && a{5} then a{4} = 0: a{5} = 1: a{6} = 0 : a{7} = 0 : goto DirX if !a{4} && !a{5} then a{4} = 0: a{5} = 1: a{6} = 1 : a{7} = 0 : goto DirX if a{4} && a{5} then a{4} = 0: a{5} = 1: a{6} = 1 : a{7} = 1 : goto DirX if a{4} && !a{5} then a{4} = 0: a{5} = 1: a{6} = 0 : a{7} = 0 : goto DirX DirX if player0y>11 && a{6} && a{7} then player0y=player0y-2 if player0y<87 && a{6} && !a{7} then player0y=player0y+2 if joy0fire then COLUBK=$1e: COLUP0=$00 else COLUBK=$80: COLUP0=$0e if b{0} then return PF0=%11111111 b{0} =1 drawscreen b{0} =0 goto Arrow vblank goto SSSS Okay, I scan the mouse in vblank as well, now it's a lot better! The only problem I can't do it during drawscreen without hacking the kernel assembly. Edited October 6, 2018 by MemberAtarian 4 Quote Link to comment Share on other sites More sharing options...
azure Posted October 8, 2018 Share Posted October 8, 2018 Playing Missile Command would be interesting with a mouse. Also, have you thought about trying a PC mouse with a PC to ST adapter? Quote Link to comment Share on other sites More sharing options...
Swami Posted October 8, 2018 Share Posted October 8, 2018 Playing Missile Command would be interesting with a mouse. Also, have you thought about trying a PC mouse with a PC to ST adapter? If you do a search on the forum, you'll see both of these have been done, plus a lot more. Not being snotty, just no time to hunt down links tonight. right now. Quote Link to comment Share on other sites More sharing options...
azure Posted October 9, 2018 Share Posted October 9, 2018 (edited) If you do a search on the forum, you'll see both of these have been done, plus a lot more. Not being snotty, just no time to hunt down links tonight. ok Edited October 9, 2018 by azure Quote Link to comment Share on other sites More sharing options...
Swami Posted October 9, 2018 Share Posted October 9, 2018 ok http://atariage.com/forums/topic/243453-atari-2600-trak-ball-games/?fromsearch=1 I guess it is a little confusing because, for some historical reasons, TB and cx80 may refer to the ST mouse and a small number of cx80s while TB and cx22 may refer to the standard cx22 and most cx80 trackballs. You can find info about the TOM2 usb to Atari adapter by searching TOM2 in the overall 2600 forum. Im not sure I would recommend the Tom2 it seemed to have some issues for multiple people, especially with firmware updates, that made some controllers unusable, although I dont think they affected mouse operation. Quote Link to comment Share on other sites More sharing options...
Swami Posted October 9, 2018 Share Posted October 9, 2018 ok Sorry, major pain when you only have your phone. Now I have the computer. Actually try here for the TOM2 with usb mouse: http://atariage.com/forums/topic/271113-tom-rev2-usb-to-db9-converter-review-for-xegs-800xl-2600-and-7800/?p=3870385 and here, for its updating issues: http://atariage.com/forums/topic/268147-use-usb-gamepad-on-atari-2600/page-2?hl=%2Btom2&do=findComment&comment=3873032 There are a couple others, the Rhys MkII from the Amigastore, and Retrofun, Retrocable on eBay. There also another one on eBay from Norway. https://www.ebay.com/itm/Amiga-Atari-PS2-mouse-Adapter-USB-version/263927878152?hash=item3d7353d208:g:uPwAAOSwY3tbTdIH:rk:6:pf:0 and Greece: https://www.ebay.com/itm/Amiga-usb-PS-2-mouse-adapter/153210575505?hash=item23ac0fda91:g:Ki4AAOSwi3ta4ZOW:rk:6:pf:0 I'm not sure how any of these stack up. The nice thing about the TOM+, although it may have the same issues as the TOM2, is that you can switch between mouse and joystick without unplugging them. Quote Link to comment Share on other sites More sharing options...
Swami Posted October 9, 2018 Share Posted October 9, 2018 ok http://atariage.com/forums/topic/243453-atari-2600-trak-ball-games/?fromsearch=1 I guess it is a little confusing because, for some historical reasons, TB and cx80 may refer to the ST mouse and a small number of cx80s while TB and cx22 may refer to the standard cx22 and most cx80 trackballs. You can find info about the TOM2 usb to Atari adapter by searching TOM2 in the overall 2600 forum. Im not sure I would recommend the Tom2 it seemed to have some issues for multiple people, especially with firmware updates, that made some controllers unusable, although I dont think they affected mouse operation. BTW, the zip files just say TB on them, but they have hacks for cx22/80, ST mouse (as CX80) and Amiga mouse in the zip file. Way back when, when Stella or Stelladaptor was first being set up, the designer had a cx80 that was modified to behave as an ST mouse. Thinking this was the norm, this ST mouse configuration became know as "cx80" in Stella, the Stella-daptor and, for consistency, I suppose, the 2600-daptor. Quite a few cx80's, although a small percentage overall, had been modified to act like ST mice in the 80s and 90s at some uncertain point in the manufacturing/retail/customer continuum. Apparently, in some regions of Europe, cx80s modified to act like ST mice were the norm. Quote Link to comment Share on other sites More sharing options...
