E474 Posted October 31, 2018 Share Posted October 31, 2018 Hi, I recently received some Tandon drive mechanisms for a 1050, and to my horror discovered a drive mechanism the like of which I had not seen before. Whoooooo dares to identify this Spooky 1050 Tandon Drive Mechanism (2nd picture)? Quote Link to comment Share on other sites More sharing options...
Nezgar Posted October 31, 2018 Share Posted October 31, 2018 I have a full working 1050 with a mech like your bottom picture. I'll see if I can find it. Pretty sure that one was also an ebay acquisition so won't know it's true origin. Maybe some markings/date labels will give some clues. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted October 31, 2018 Share Posted October 31, 2018 I've got one floating around somewhere.. but my drive handle didn't have the cover pulled off and the pin reversed in it. Unless maybe I reversed it myself. Spooky feeling when you can't remember if you did a thing... Quote Link to comment Share on other sites More sharing options...
Nezgar Posted October 31, 2018 Share Posted October 31, 2018 That backwards lever is definitlely supposed to be the other way like every other mech. Probably just messed up from loose banging around in a box. Hopefully it wasnt caused by force and breaking something... highly possible with for parts mechs. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted October 31, 2018 Share Posted October 31, 2018 (edited) closer look at jacket catch eject reveals an issue.... force was involved...careful TLC can save it... now I wonder where he bought/received the mech... I've seen this.... Edited October 31, 2018 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
xrbrevin Posted November 1, 2018 Share Posted November 1, 2018 does it use the disk index hole perhaps? Quote Link to comment Share on other sites More sharing options...
Nezgar Posted November 1, 2018 Share Posted November 1, 2018 Found my drive with this mech. Some observations of this drive: - ROM Rev J EPROM . There are known to be E/F/H/J/K/L for Tandon - placing this in the earlier side of the ROM versions, and probably the earliest mass produced ROM. H was only discovered and dumped recently from a pre-production PCB. More details about this in this thread. I didn't feel like removing the metal cage, but used the macro lens to show the "J" written on the EPROM label through the grille holes. - most small LS IC's are soldered direct to the motherboard. Especially the ones near the front, are usually socketed in most other boards I have. - WDC2793 controller date code 8316 (16th week 1983) - This oddball Tandon mech "Top Assy No." is 211014.001 - Most are 210524-0019 - The drives serial # ends in "364" meaning 36th week of 1984. Most of my 1050's have a Rev on the underside of the PCB that can be read through the grille holes. This one says "Rev C2". Seems to be an oddball indicator - E1 in 83, and C2 in 84?? looking at a sampling of 5 drives: 413 - Week 41 1983 - E1 104 - Week 10 1984 - D1 364 - Week 36 1984 - C2 524 - Week 52 1984 - E1 135 - Week 13 1985 - E1 Here's some high res shots of my drive. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted November 1, 2018 Share Posted November 1, 2018 (edited) forgotten, found in the raiders of the Atari Ark warehouse, slight touches to make sure they could be sold and off they went... or as happens was re-cased?... look for repair center marks or numbers if any... Edited November 1, 2018 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted November 1, 2018 Share Posted November 1, 2018 There are a few versions of the Tandon mech. I have one that has an oddball metal plate bolted to the side for some reason. The major differences I see in the two at the top of the thread is the location of the drive door switch was moved, as well as a change to how the alignment spindle is dropped. Quote Link to comment Share on other sites More sharing options...
