anrygraf Posted December 10, 2018 Share Posted December 10, 2018 Hello everyone, I have problem with load games on the Atari MEGA ST2 with monitor SM124.After run game from floppy I get GEM interface without any errors or just a black screen.Diskettes with games tested.Mega ST2 compatible with 520/1040 ST?May be problem with RAM/ROM, how do check it?Any ideas... Quote Link to comment Share on other sites More sharing options...
tjlazer Posted December 10, 2018 Share Posted December 10, 2018 Are the games mono compatible? Most games are for a color monitor and won’t work on your mono monitor. Quote Link to comment Share on other sites More sharing options...
anrygraf Posted December 10, 2018 Author Share Posted December 10, 2018 Are the games mono compatible? Most games are for a color monitor and won’t work on your mono monitor. About mono compatible of games I don't know, but also no any audio from games. Mega ST2 can detect connected monitor? Quote Link to comment Share on other sites More sharing options...
Atari_Falcon Posted December 11, 2018 Share Posted December 11, 2018 The connected monitor type is detected by a Pin/resistor in the cable afaik. That's why you can only select "high" resolution with the sm124 connected (and "Low" and "mid" with a color Screen). You could try for example chrystal castles or Battlezone. These also support black and White. I can send you the files if you want. Best regards, Chris 1 Quote Link to comment Share on other sites More sharing options...
anrygraf Posted December 11, 2018 Author Share Posted December 11, 2018 The connected monitor type is detected by a Pin/resistor in the cable afaik. That's why you can only select "high" resolution with the sm124 connected (and "Low" and "mid" with a color Screen). You could try for example chrystal castles or Battlezone. These also support black and White. I can send you the files if you want. Best regards, Chris Thank you Chris Yes, please send me this files, if possible in the .st file format. Quote Link to comment Share on other sites More sharing options...
Ayreon Posted December 11, 2018 Share Posted December 11, 2018 http://www.atarimania.com/game-atari-st-battlezone_8685.html http://www.atarimania.com/game-atari-st-crystal-castles_9026.html 1 Quote Link to comment Share on other sites More sharing options...
anrygraf Posted December 11, 2018 Author Share Posted December 11, 2018 http://www.atarimania.com/game-atari-st-battlezone_8685.html http://www.atarimania.com/game-atari-st-crystal-castles_9026.html Thanks! I can do sort games at www.atarimania.com or other site by screen resolution? Quote Link to comment Share on other sites More sharing options...
Ayreon Posted December 12, 2018 Share Posted December 12, 2018 I have no connections to/with Atarimania. I couldn't see a filter for the resolutions, but they put the info in the extra game information so maybe they can add a filter if one does a request for it Quote Link to comment Share on other sites More sharing options...
tjlazer Posted December 13, 2018 Share Posted December 13, 2018 Most Sierra games work on mono too. There is a list of all mono compatible games... http://8bitchip.info/atari/allmonocg.html Quote Link to comment Share on other sites More sharing options...
