+Propane13 Posted June 16, 2003 Share Posted June 16, 2003 In the Atari 7800 BIOS, there's some code that helps to put the the 7800 into 2600 mode, by cleaning out regs, RAM, etc. (I found a copy here: http://kontek.net/pp/technical/a7800/bios7800.asm.txt) I see this code, but it confuses me: BIT RSYNC BMI LF813 LF80A: LDA #$02 STA COLUBK STA LF112 BNE LF831 LF813: BIT WSYNC BMI LF823 Obviously, RSYNC ($03) and WSYNC ($02) are write-only. So, what does the read-only value pull? Is it some sort of shadow-reference to one of the collision or INPT registers? Thanks, -John K. Harvey Link to comment Share on other sites More sharing options...
DEBRO Posted June 17, 2003 Share Posted June 17, 2003 Obviously, RSYNC ($03) and WSYNC ($02) are write-only. So, what does the read-only value pull? Is it some sort of shadow-reference to one of the collision or INPT registers? Thanks, -John K. Harvey Read addresses $02 = CXP0FB ... collision between P0 and PF (D7) P0 and Ball (D6) $03 = CXP1FB ... collision between P1 and PF (D7) P1 and Ball (D6) Link to comment Share on other sites More sharing options...
Archived
This topic is now archived and is closed to further replies.
