Charlie_ Posted October 19, 2001 Share Posted October 19, 2001 Im looking for a 4 port RF on ebay. I see a lot of them that do not have the "2 screw" flat wire hookup. Thats OK, I don't need that but I saw one auction that confussed me. It claims to be for a 2 port system but it looks just like a 4 port RF. Here it is: 2 port RF Question is, did the 2 port have a similar RF with the difference being you don't need to plug the power in to it? Also, when I (i hope) someday get a 2 port system can you use a standard "slide switch" RF with it that you would use with a 2600? Charlie [ 10-19-2001: Message edited by: Chazbeenhad ] Quote Link to comment Share on other sites More sharing options...
Tempest Posted October 19, 2001 Share Posted October 19, 2001 The one in the picture labeled 2 port RF is really a 4 port RF box. The 2 port model used a regular switch box, although it did come with an "offical Atari" version. The 4 Port RF came in two styles, one with the two screws and one without. If you need one I have two extra's. e-mail me if your interested. Tempest Quote Link to comment Share on other sites More sharing options...
Gunstar Posted October 19, 2001 Share Posted October 19, 2001 I know the 4port rf won't work with any other systems (at least not my 7800, XE, C64, pong, video pinball), but I do have a regular manual tv switch box hooked up to the 4port rf and have all my rf systems hooked up that way. Don't worry guys, I did not attempt to test it with the 5200 powerpack plugged in. Quote Link to comment Share on other sites More sharing options...
NoahsMyBro Posted May 6, 2002 Share Posted May 6, 2002 Tempest, correct me if I'm wrong, but I assume he meant has the standard RF swtichbox connected to the Antenna input on the 4-port automatic switchbox. If the 4-port system is turned off, the 4-port switchbox will channel the antenna input to the TV. In this case, the traditional RF switchbox will not come into play and determine what is displayed on the screen. Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted May 6, 2002 Share Posted May 6, 2002 Doesn't matter as the auction has been pulled...and doesn't appear to be there anymore. I suspect it was a 2 port 5200 being auctioned with a 4 port switchbox...simply because the seller was unaware. I am sure you could attach a 4 port switchbox to a standard console of that era using RF. But then how would the switch over occur? I know that I am using the cable in on my 4 port switchbox to connect my Intv through. That way...when the 5200 is off...I get INTV...when I turn the 5200 on...I get Atari Fuji... Quote Link to comment Share on other sites More sharing options...
Room 34 Posted May 7, 2002 Share Posted May 7, 2002 quote: Originally posted by Gunstar: But I do have a regular manual tv switch box hooked up to the 4port rf and have all my rf systems hooked up that way. So what you're saying is that a 4-port 5200 CAN use a regular manual RF switchbox? I am currently bidding on a 5200 on eBay that looks to be a 4-port that's missing the switchbox, because the seller says they couldn't figure out how to hook it up. Am I going to need to get a special cable, or does the 5200 have a built-in cable like the 2600, that I could just connect to one of my existing RF switchboxes? Quote Link to comment Share on other sites More sharing options...
