HOME AUTOMATION Posted January 30, 2019 Share Posted January 30, 2019 (edited) Slight problem with above... loses the top line...New improved version saves 23 lines!Also the code didn't post correctly. 100 A=0 110 E=2 120 B=168 130 D=1 140 A=A+1 150 E=E+1 160 IF E<>31 THEN 190 170 E=3 180 D=D+1 190 CALL GCHAR(D,E,C) 200 A$=CHR$(C) 210 B$=B$&A$ 220 IF A<>B THEN 140 230 T$(F)=B$ 240 F=F+1 250 B$="" 260 IF A=672 THEN 290 270 B=B+168 280 GOTO 140 290 CALL CLEAR 300 OPEN #1:"CS1",OUTPUT,FIXED 192,INTERNAL 310 FOR Z=0 TO 3 320 PRINT #1:T$(Z) 330 NEXT Z 340 END 350 OPEN #1:"CS1",INPUT,FIXED 192,INTERNAL 360 FOR X=0 TO 3 370 INPUT #1:T$(X) 380 NEXT X 390 FOR W=0 TO 2 400 PRINT T$(W) 410 NEXT W 420 T$(3)=SEG$(T$(3),1,140) 430 PRINT T$(3) 440 GOTO 440 How to use:1) Type on screen...use FCTN 4 instead of ENTER.2) Type RUN3) Wait... about 120 sec.4) Follow recording cassette prompts. SAVED!To recover:1) Type RUN 3502) Follow playing cassette prompts.3 Previously saved screen displays The bottom line can not be used. screencapture.wavscreencapture.dsk Edited January 30, 2019 by HOME AUTOMATION 4 Quote Link to comment Share on other sites More sharing options...
