WaverBoy Posted June 18, 2003 Share Posted June 18, 2003 So, I'm looking for a Sega Power Base Adapter to play SMS carts on my Genesis, and I seem to hear that there is an often-missing screw that helps hold the unit in place on the Genesis. Is it possible to use the unit without this screw, if I can't find one that includes it? Link to comment Share on other sites More sharing options...
ussexplorer Posted June 18, 2003 Share Posted June 18, 2003 My power base converter game in a box but the screw was missing. It works just fine. Fit snug on the genesis. Keep in mind you need the original Genesis or genesis I. It is possible to play the power base converter on the genesis II if you pull the board out of the case. I read in england their was a power base II? that would allow you to plug it into the Genesis II. The genesis 3 does not work with the power base. As for games. I read two games needed to have the original Master System controller. I have not ran into these games yet. So I couldn't tell you if that is true or not. I asume it is. Also it will not work on top of the 32x adaptor. I tried. Thought it would be cool since it did fit. So I had to search around for a genesis one. Later, Josh Link to comment Share on other sites More sharing options...
BoOchan! Posted June 18, 2003 Share Posted June 18, 2003 You can use this Adaptor (The Auction in the link) (Not Mine!) on the Genesis II Which were made by Australian Suplliers HES. http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...7&category=3642 Link to comment Share on other sites More sharing options...
Ze_ro Posted June 18, 2003 Share Posted June 18, 2003 Also it will not work on top of the 32x adaptor. I tried. Thought it would be cool since it did fit. Did you try it under the 32X? Might work better that way. --Zero Link to comment Share on other sites More sharing options...
WaverBoy Posted June 18, 2003 Author Share Posted June 18, 2003 Thanks guys! I'll put this nifty item on my list right away then! Oh wait...one more question: can you use SMS-exclusive peripherals with the Power Base converter, like the 3-D setup and the light gun? Link to comment Share on other sites More sharing options...
video game addict Posted June 18, 2003 Share Posted June 18, 2003 Yes the Power Base adapter has a card slot so you can use the 3D glasses. The light gun works just like any other controller, it plugs into the controller port. And there are some games that don't work right with Genesis controllers, you'd get the same result if you tried to use Genesis pads on a real SMS. Penguin Land is one that comes to mind, there are others, I think Bomber Raid, and some imports as well. I'd recommend buying a couple SMS pads to go along with it, for when you do pick up those games. And a Power Base adapter will not work under a 32x either. I don't think that would even give you enough pins for the 32x. But it's a breeze to pull out one and slide the other back in. Link to comment Share on other sites More sharing options...
ubersaurus Posted June 18, 2003 Share Posted June 18, 2003 If you have a CDX, The Power Base Convertor works perfectly fine with that. Fits nicely, although you can't screw it on, as long as you aren't jostling the system it shouldn't be a concern. Link to comment Share on other sites More sharing options...
Raijin Z Posted June 18, 2003 Share Posted June 18, 2003 My PBC never comes off my Genesis.. I have more SMS games than Genesis. Link to comment Share on other sites More sharing options...
MegaManFan Posted June 18, 2003 Share Posted June 18, 2003 Shanghai won't work with a Genesis controller, for some odd reason. You have to plug in the SMS pad. Link to comment Share on other sites More sharing options...
JerseyDevil Posted June 18, 2003 Share Posted June 18, 2003 Alien Syndrome and Wonder Boy in Monster Land also need the SMS controller. Link to comment Share on other sites More sharing options...
SS Posted June 18, 2003 Share Posted June 18, 2003 My PBC never comes off my Genesis.. I have more SMS games than Genesis. I can't recall the last time that I took mine off either. My Genesis carts just sit and gather dust these days. SMS games, on the other hand, are still in heavy rotation. Link to comment Share on other sites More sharing options...
WaverBoy Posted June 19, 2003 Author Share Posted June 19, 2003 Thanks everyone! All the info I needed. Interesting about some games requiring the SMS pads...I would have thought that, since the Genesis pads have more buttons than the SMS pads, they would have been able to cover everything. Guess I'll have to pick up a couple. Anyway, I'm really excited about checking out the SMS games...I've never ever played them before. Nobody I knew had a SMS when I was younger--everyone had the big NES. From what I've been hearing, I think I really may have been missing out on a great system. Link to comment Share on other sites More sharing options...
ubersaurus Posted June 19, 2003 Share Posted June 19, 2003 Try out the following SMS games Power Strike Zillion Choplifter Double Dragon Rampage Sonic the Hedgehog(you may have to get a UK cart, US one is pretty rare). All are top notch quality. On that note, does anyone know how much a PBC should go for loose? I want to pick one up and I want to know what price range I'm looking at. No room to keep the sms hooked up seperate, ya see. Link to comment Share on other sites More sharing options...
ussexplorer Posted June 19, 2003 Share Posted June 19, 2003 I read the 3d glasses don't work with the power base. I guess the website I ran into was wrong. Can't remeber if I got around to plugging them into a power base yet. I just use them on the Sega Master System itself. Later, Josh Link to comment Share on other sites More sharing options...
snorlaxnut Posted June 19, 2003 Share Posted June 19, 2003 From Jeff Bogumil's SMS FAQ guide, http://www.gamefaqs.com/console/sms/game/22669.html these games won't work with the Genesis controller on the converter: Great Volleyball Shanghai Alien Syndrome Wonder Boy in MonsterLand Where in the World is Carmen San Diego? Montezuma's Revenge Bomber Raid Tennis Ace Also the game card F-16 Fighting Falcon won't work with the converter. Link to comment Share on other sites More sharing options...
Raijin Z Posted June 19, 2003 Share Posted June 19, 2003 Man, I NEED to get Double Dragon. It was my first Master System game. Link to comment Share on other sites More sharing options...
MegaManFan Posted June 19, 2003 Share Posted June 19, 2003 Man, I NEED to get Double Dragon. It was my first Master System game. Dude, I think I have a spare on my trade list (prolly minus instructions though, but boxed). Link to comment Share on other sites More sharing options...
SS Posted June 19, 2003 Share Posted June 19, 2003 these games won't work with the Genesis controller on the converter: Great Volleyball Shanghai Alien Syndrome Wonder Boy in MonsterLand Where in the World is Carmen San Diego? Montezuma's Revenge Bomber Raid Tennis Ace I'd recommend picking up a Sega Control Stick to use with those games. It's a good, comfortable feeling controller and I can use it with my thumb the same way that I use a 2600 stick. Link to comment Share on other sites More sharing options...
Raijin Z Posted June 20, 2003 Share Posted June 20, 2003 GADS! It's LEFT-HANDED! *shokku* What I meant was I need to FIND Double Dragon. Me = broke. Link to comment Share on other sites More sharing options...
video game addict Posted June 20, 2003 Share Posted June 20, 2003 Actually I think it's Right-handed. The controller part is on the Right, buttons are on the left. It's the same as 2600 sticks. I personally started off with the 5200, and it's ambidextrous controls. From there I hit the NES, and have been use to that design ever since. Coming back to Atari and then the 2600, I found the original sticks quite odd, and have never really liked them too much. I always use the Tac-2 as it's got buttons on both sides which makes it easier on me. I have one of these Sega Control Sticks as well, I don't use it thou. Maybe if there was a way to turn the controls around inside, maybe just swaping the wires. Then you could turn the controller upside down and play. Link to comment Share on other sites More sharing options...
ussexplorer Posted June 20, 2003 Share Posted June 20, 2003 When I picked up a dead genesis. I picked up one of those command sticks. have yet to really try it. Thought the large knob was a little strange. Later, Josh Link to comment Share on other sites More sharing options...
ussexplorer Posted June 21, 2003 Share Posted June 21, 2003 Also it will not work on top of the 32x adaptor. I tried. Thought it would be cool since it did fit. Did you try it under the 32X? Might work better that way. --Zero The reason for trying it on top of the 32x adaptor was because I only had an Sega Genesis 2 at the time. Later, Josh Link to comment Share on other sites More sharing options...
JB Posted June 22, 2003 Share Posted June 22, 2003 The Power Base Converter fits a Gen2 QUITE well... Well, mine does. I grant that this is because the previous owner took a Dremel and cut the back tab off to MAKE it fit, but... And I love the Control Stick. It's a tad lightweight, but any controller that puts the directionals back under my dominant hand where they belong is good by me. Link to comment Share on other sites More sharing options...
Archived
This topic is now archived and is closed to further replies.
