+therealbountybob Posted February 22, 2019 Share Posted February 22, 2019 I use MAC/65 Assembler on the Atari. This time I have a GR.7 screen from MAD Studio, it supplies the data file and the BASIC source code to load this which works fine: 10 GRAPHICS 7+1620 CLOSE #130 OPEN #1,4,0,"H1:SCREEN01.GR7"40 SCR=PEEK(88)+PEEK(89)*25650 FOR I=0 TO 383960 GET #1,BYTE70 POKE SCR+I,BYTE80 NEXT I ... MAC/65 will not import (enter) the SCREEN01.GR7 file, tried various modes, also tried converting end of line using Memopad. Sounds like it goes through the motions but nothing, or truncated record if EOL changed - guess as one big block of data. For a long winded workaround, I loaded the file in BASIC, did a Binary Save from DOS, and then I have someone else's BASIC utilis that convert this to a string and then to data statements -or - I could use my Byte Buster Utility I did also try a BLOAD in MAC/65 which brings the data in ok, but this is only from the command prompt (not part of the assemble) Is there another file conversion utility? or I did ponder if it was possible to load a dummy data file into assember, then bload the screen01.gr7 somewhere else in RAM and then write a program to copy the bytes over the existing data statements - then I could save the file? or some other (better) way of doing this e.g. in BASIC? Hope this makes sense Thanks 2 Quote Link to comment Share on other sites More sharing options...
Rybags Posted February 22, 2019 Share Posted February 22, 2019 Raw data can't be imported into Mac-65 so easily. Another possibility is you could just alter the Basic program to generate source code with .BYTE directives. Mac-65 can live without line numbers so you don't need to worry there. You could even give the program some intelligence - .BYTE with quoted text can handle most byte codes except $9B which is Return. To get such codes you just close off the quote then put ,$9B in the output. Alternately you could do .DBYTE which is less efficient than Ascii strings but more efficient than single bytes. Or you could generate a binary load file but the disadvantage there is that it becomes fixed location. Quote Link to comment Share on other sites More sharing options...
Alfred Posted February 24, 2019 Share Posted February 24, 2019 Here's a program I got off a web site. It's an analog program to convert a data file into basic DATA statements. Should be easy enough to fix to turn the data into .BYTE statements instead. Works with either a plain data file or a binary loadfile. I patched it up to work with Basic XE, but there's nothing special about, so it should be easy enough to turn back into normal Basic. BOFFO.bas 3 Quote Link to comment Share on other sites More sharing options...
+therealbountybob Posted February 25, 2019 Author Share Posted February 25, 2019 Here's a program I got off a web site. It's an analog program to convert a data file into basic DATA statements. Should be easy enough to fix to turn the data into .BYTE statements instead. Works with either a plain data file or a binary loadfile. I patched it up to work with Basic XE, but there's nothing special about, so it should be easy enough to turn back into normal Basic. Thanks but!... after changing the EndOfLine chars with Memopad this (listed) copy also has lowercase text so won't import, I did try pasting the text into altirra which gets around this but there are other spurious characters giving errors - I'm guessing it's been reformatted on a PC editor perhaps (or BASIC/XE did it?) Has anyone got another copy of BOFFO, it's on Analog Disk #24 (not findable!)? Don't make me type it in! Also looking for other data manipulation programs from the past if anyone has any - I guess each programmer had a bunch of their own stashed away. Quote Link to comment Share on other sites More sharing options...
Alfred Posted February 25, 2019 Share Posted February 25, 2019 (edited) You can get the original program from ksquiggles website. Edit: https://ksquiggle.neocities.org/boffo.htm Edited February 25, 2019 by Alfred 1 Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted February 25, 2019 Share Posted February 25, 2019 (edited) 10 TRAP 40000:? "}ASSEMBLY-TO-BASIC DATA CONVERTOR":? "By Tom Hudson, ANALOG Computing" 20 DIM FILE$(15),FI$(17),D$(1),HX$(16),DH$(1),CK$(1),OD$(1),ODMSG$(6):HX$="0123456789ABCDEF" 30 POSITION 2,5:? "œœ ÏBJ/ÄATA file";:INPUT OD$:IF OD$="O" THEN ODMSG$="OBJECT":GOTO 60 40 IF OD$<>"D" THEN 30 50 ODMSG$=" DATA" 60 POSITION 2,7:? "œœ";ODMSG$;" filename";:INPUT FILE$:TRAP 120:IF LEN(FILE$)=1 THEN 90 70 IF FILE$(2,2)=":" THEN FI$=FILE$:GOTO 100 80 IF FILE$(3,3)=":" THEN FI$=FILE$:GOTO 100 90 FI$="D:":FI$(3)=FILE$ 100 OPEN #1,4,0,FI$:IF OD$="O" THEN GET #1,BYTE:GET #1,BYTE2:IF BYTE<>255 OR BYTE2<>255 THEN 130 110 GOTO 150 120 ? FILE$;" INVALID FILE,";:GOTO 140 130 ? FILE$;" NOT OBJ FILE,"; 140 ? " PRESS ÒÅÔÕÒÎ";:INPUT D$:CLOSE #1:GOTO 60 150 POSITION 2,9:? "œœ BASIC filename";:INPUT FILE$ 160 TRAP 200:IF FILE$(2,2)=":" THEN FI$=FILE$:GOTO 190 170 IF FILE$(3,3)=":" THEN FI$=FILE$:GOTO 190 180 FI$="D:":FI$(3)=FILE$ 190 OPEN #2,8,0,FI$:GOTO 210 200 ? FILE$;" INVALID FILE, PRESS ÒÅÔÕÒÎ";:INPUT D$:CLOSE #2:GOTO 150 210 POSITION 2,11:? "œœStarting lineno";:TRAP 210:INPUT LINE:TOTAL=0 220 POSITION 2,13:? "œœ Line increment";:TRAP 220:INPUT INC 230 POSITION 2,15:? "œœ Äecimal/Èex";:INPUT DH$:IF DH$<>"D" AND DH$<>"H" THEN 230 240 POSITION 2,17:? "œœ Bytes per line";:TRAP 240:INPUT BLIN 250 POSITION 2,19:? "œœ Checksum (Y/N)";:INPUT CK$:IF CK$<>"Y" AND CK$<>"N" THEN 250 260 COUNT=0:TRAP 420 270 IF OD$="D" THEN LA=0:HA=65535:TOTLEN=65536:TLC=-1:GOTO 310 280 GET #1,LO1:GET #1,HI1:GET #1,LO2:GET #1,HI2:LA=LO1+HI1*256:HA=LO2+HI2*256:TOTLEN=HA-LA+1:TLC=-1 290 IF HA=737 AND LA=736 THEN 420 300 IF COUNT>0 AND LA<>LL+1 THEN ? "}ýÅÒÒÏÒ¡¡¡ MEMORY NOT CONTIGUOUS!":END 310 LL=HA:IF TOTAL>0 THEN 330 320 X=-999 330 TLC=TLC+1:IF TLC=TOTLEN THEN 270 340 GET #1,BYTE:TOTAL=TOTAL+1:COUNT=COUNT+1:GNDTOT=GNDTOT+BYTE:IF CK$="Y" AND GNDTOT>999 THEN GNDTOT=GNDTOT-1000 350 IF X=-999 THEN ? #2;LINE;" DATA ";:LINE=LINE+INC:X=0 360 IF DH$="D" AND X>0 AND X<BLIN THEN ? #2;","; 370 X=X+1:IF DH$="H" THEN BH=INT(BYTE/16):BL=BYTE-(BH*16) #2;HX$(BH+1,BH+1);HX$(BL+1,BL+1);:GOTO 390 380 ? #2;BYTE; 390 IF X<BLIN THEN 330 400 IF CK$="N" THEN ? #2:GOTO 320 410 ? #2;",";GNDTOT:GOTO 320 420 IF PEEK(195)<>136 AND PEEK(195)<>0 THEN ? "}ýABNORMAL TERMINATION (ERROR ";PEEK(195);")":END 430 IF CK$="N" OR X=-999 THEN 490 440 IF DH$="D" THEN 470 450 ? #2;"00";:TOTAL=TOTAL+1:X=X+1:IF X<BLIN THEN 450 460 GOTO 480 470 ? #2;",0";:TOTAL=TOTAL+1:X=X+1:IF X<BLIN THEN 470 480 ? #2;",";GNDTOT 490 ? #2:? #2;LINE;" REM * ";TOTAL;" BYTES":CLOSE #1:CLOSE #2:END BOFFO.BAS Listing for importing into Altirra or the BAS for direct use. Edited February 25, 2019 by rdea6 3 Quote Link to comment Share on other sites More sharing options...
+therealbountybob Posted February 26, 2019 Author Share Posted February 26, 2019 OK, more or less getting there: BOFFO.BAS file on the post above works... (the listing doesn't paste in as it has those spurious chars (which are inverse chars and control codes for text positioning). ... great for anyone using BASIC: tried it with both a DATA file (the MAD Studio graphics screen) and an OBJect file too. BUT it generates lines of data with no spacing if you take the HEX option, so assembler users will need to select DECIMAL output which has the commer separated values, might try and tweak this BOFFO was part of Tom Hudson's Assember Boot Camp. 1 Quote Link to comment Share on other sites More sharing options...
