+Stephen Posted June 20, 2021 Share Posted June 20, 2021 On 3/20/2019 at 8:11 PM, NISMOPC said: On 3/20/2019 at 8:18 PM, Stephen said: Nice Video Music machine. I also have one with original box. Super fun device, but it really needs a composite/s-video out mod. OK - so I replied to this 2.25 years ago. Almost made the exact same reply about the AVM. However, I don't know how I missed it the 1st tie around, but holy $hit. I had that same "professor owl" calculator. Quote Link to comment Share on other sites More sharing options...
Dropcheck Posted June 21, 2021 Share Posted June 21, 2021 17 hours ago, mikesk8 said: I am looking for a similar solution as putting carts horizontally is quite annoying Does it have any support below to make it stable? Is it really easy to use? The boards are designed to be put into a 3d printed case. There are also mounting holes in the top right/left corners for support. Sadly I'm not that great at 3d design and so didn't create a case for it. You can also check out Digikey for rubber standoffs. This link will get you started. Measure the distance from the bottom of the board to the next flat surface (desktop?) and keep the diameter of the standoff/rubber feet to no more than 1/2 in or so. There is some limitation on this type of RA extender. Some Atari original cartridges may be difficult to use since they were designed to open using the ears on cartridge slot. Otherwise there is no real 'operation' other than insert the cartridge into the board with the label facing you and then insert into the cartridge slot with the label facing you. Quote Link to comment Share on other sites More sharing options...
mikesk8 Posted June 21, 2021 Share Posted June 21, 2021 2 hours ago, Dropcheck said: The boards are designed to be put into a 3d printed case. There are also mounting holes in the top right/left corners for support. Sadly I'm not that great at 3d design and so didn't create a case for it. You can also check out Digikey for rubber standoffs. This link will get you started. Measure the distance from the bottom of the board to the next flat surface (desktop?) and keep the diameter of the standoff/rubber feet to no more than 1/2 in or so. There is some limitation on this type of RA extender. Some Atari original cartridges may be difficult to use since they were designed to open using the ears on cartridge slot. Otherwise there is no real 'operation' other than insert the cartridge into the board with the label facing you and then insert into the cartridge slot with the label facing you. Thank you for the fast answer. I will skip this idea till the moment somebody will be selling a complete product ? don’t want to replace one hassle with another 1 Quote Link to comment Share on other sites More sharing options...
manterola Posted June 21, 2021 Share Posted June 21, 2021 (edited) What about @Mr Robot ones : ECI2PBI Case – The Robot Factory I believe this was made specifically for @Dropcheck extender Edit: it says it is compatible with 2019 extender version by @Dropcheck... Edited June 21, 2021 by manterola 1 Quote Link to comment Share on other sites More sharing options...
Nezgar Posted June 21, 2021 Share Posted June 21, 2021 On 6/20/2021 at 2:48 PM, mikesk8 said: Does it have any support below to make it stable? I found rubber feet that appear match my old genuine ICD PBI/ECI adapter here - I measured them 1/2" height, and has the tapered/rounded corners like this on ebay: https://www.ebay.com/itm/254410391310 - I can't easily find similar on jameco or digikey... but I also might not be searching correctly... I presume the right angle PCB would sit at the same height. Looks like a pair of metal standoffs could work too. Quote Link to comment Share on other sites More sharing options...
Mathy Posted June 21, 2021 Share Posted June 21, 2021 Hello Nezgar, guys 48 minutes ago, Nezgar said: I found rubber feet that appear match my old genuine ICD PBI/ECI adapter here - I measured them 1/2" height, and has the tapered/rounded corners like this on ebay: https://www.ebay.com/itm/254410391310 In the link they don't seem to mention how many of those feet you get for that price. Sincerely Mathy Quote Link to comment Share on other sites More sharing options...
Nezgar Posted June 21, 2021 Share Posted June 21, 2021 Just now, Mathy said: In the link they don't seem to mention how many of those feet you get for that price. You have to choose a "pack size" from the dropdown. 8 feet for US $10.79 12 feet for US $13.95 16 feet for US $16.20 24 feet for US $22.50 Problem is shipping to me in Canada is $13.35, (and US $19.76 to Netherlands) but free within the US.... Quote Link to comment Share on other sites More sharing options...
Mathy Posted June 21, 2021 Share Posted June 21, 2021 Hello Nezgar 15 minutes ago, Nezgar said: You have to choose a "pack size" from the dropdown. Thanks! I looked everywhere, except where I should have... Sincerely Mathy Quote Link to comment Share on other sites More sharing options...
NISMOPC Posted June 22, 2021 Author Share Posted June 22, 2021 On 6/20/2021 at 5:18 PM, Stephen said: OK - so I replied to this 2.25 years ago. Almost made the exact same reply about the AVM. However, I don't know how I missed it the 1st tie around, but holy $hit. I had that same "professor owl" calculator. Had it ever since it was new. Missing battery cover, but still works... ? Quote Link to comment Share on other sites More sharing options...
macsonny Posted January 26, 2023 Share Posted January 26, 2023 (edited) On 7/4/2020 at 10:59 AM, BillC said: MEtalGuy66 did years ago when he made reproductions of the MIO, but AFAIK they are no longer available. Dropcheck also sells a new version, the only obvious difference is some jumpers on the left side. https://www.bitsofthepast.com/?product=130xe-ra-extenders-switchers Can these still be purchased? Edited January 26, 2023 by macsonny Quote Link to comment Share on other sites More sharing options...
