eric_ruck Posted June 19, 2003 Share Posted June 19, 2003 Can anyone shed light on a problem I'm having with my Saturn and one particular game, In The Hunt? For some reason when the game starts, or when you end and start over, if there's a joystick plugged in the system hangs. Quite annoying...can anyone shed some light on this and/or a possible solution? Eric Link to comment Share on other sites More sharing options...
chrisbid Posted June 19, 2003 Share Posted June 19, 2003 what kindof controller is it? if its a 3D pad, and its in analog mode, some games will not work properly just a guess? Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted June 19, 2003 Share Posted June 19, 2003 I can't shed any light I am afraid. However, know that your not alone. My saturn will always lock up with an actual PC error listing in Daytona. Doesn't do it all the time..but about once in every 3 times I boot up that game it will. Also, I can only play Virtua Racing for about 10 minutes before the Saturn locks up on that one too. No error codes...just locks up. I suspect the Saturn does have heat related issues which could be causing this. However, there isn't really any room in the saturn to add cooling fans. Link to comment Share on other sites More sharing options...
Tempest Posted June 19, 2003 Share Posted June 19, 2003 That's a known problem with In The Hunt. Strangely it only happens on some Saturns not all. All you can do to get around it is to unplug your controller (lame I know). Tempest Link to comment Share on other sites More sharing options...
Ze_ro Posted June 21, 2003 Share Posted June 21, 2003 This question has been addressed before... Check out this thread for more information on your problem. --Zero Link to comment Share on other sites More sharing options...
eric_ruck Posted June 21, 2003 Author Share Posted June 21, 2003 Thanks...I noticed that it doesn't seem to matter which controller type, whether you're pressing anything or nothing, and, as indicated in the other thread, sometimes it will start with the controller plugged in. Interesting. Eric Link to comment Share on other sites More sharing options...
Archived
This topic is now archived and is closed to further replies.
